Method to calculate weight transfer to axles
noteven
Weight transfer for payload or equipment added situated between the axles can be calculated using:
(A x PL) = LR
WB
PL - LR = LF
Where:
A = Payload item cg distance in WB dimension units (such as inches) to front axle
PL = Payload (or added equipment) item weight
WB = Wheelbase dimension (center line of front axle to center of rear axle or rear axle group - i.e. center of tandems)
LR = Load to rear axle.
LF = Load to front axle.
For loads like the hitch and pin weight behind the rear axle - I can cipher out the answer with placemat math but I cannot express it as a proper formula. Need help. :(
(A x PL) = LR
WB
PL - LR = LF
Where:
Would'nt you simply replace LF with LH (load to Hitch) for the trailing unit?
I'm a work'n on it.
A is then a negative number should all calculate the same.
That sounds right:
(- R x PL) = FLR
WB
Where:
R = Payload item cg distance in WB dimension units (such as inches) behind the center of rear axle group
FLR = Front Load Reduction.
There is no second calculation as all the weight is carried by the rear axle(s) as the fulcrum.
So a 5000lbs ET & trailer pin set 36 inches behind the axle on a 230" wheelbase truck would be:
(-36 x 5000) = 782lbs - weight removed from front axle.
230
