Connecting a Hopper 3 to a New Network
LindaH
I ordered a Visible phone and am trying to get it and the Hopper connected, but haven't been successful.
Here's what I tried:
1. Turned on Visible phone's hotspot
2. Went to Menu>Settings>Internet
3. Then Wireless Setup>Wi-Fi Setup Wizard
The next screen says "No wireless networks were found."  Selecting the "Rescan" button doesn't do anything...this on the 2nd try.  On the first try, the "Wireless Network" did start a scan, but it never found the phone.
Now what?
LindaH
2014 Winnebago Aspect 27K
2011 Kia Soul
2 hours ago, LindaH said:
Oh, it's transmitting.  I used it as a hotspot all morning to get my computer online.
Ok, shooting in the dark here.
Edit for additional question: Can you take the Hopper closer to a known WiFi network, or get another hotspot? Even if you don't connect to the network, just to prove your Hopper is scanning WiFi.
Edited by Darryl&Rita
The Hopper is scanning for WiFi.  When I was trying to get the Visible phone recognized, it apparently lost the information on the original WiFi, so I turned on the hotspot of my other phone (the one that was used originally when the Hopper 3 was installed) and used "Reset Network" (I think) and it found that signal and reestablished the link.
LindaH
2011 Kia Soul
Since Visible can only support one device on its hotspot, you might get one of those under $30 GL.iNET mini travel routers that have been mentioned many times, hook it to Visible and then see if the Hopper sees that wifi.
This is what I do, only I use a Asus router. I then run a Cat 6 cable from router to TV so it is hard wired. Visible only see one device. Everything else connects to the router.
2917 Keystone Montana 3720 Legacy
14' Ram 3500 DRW
I do have one of the GL.iNET mini travel routers on order through Amazon, but it may not be here until the end of the month!
I don't have anything else connected to the Visible Hotspot when I've tried doing this.
LindaH
2011 Kia Soul
Since Visible can only support one device on its hotspot . . .
If you're using your Visible phone for voice as well as data, then buy another Visible plan/phone. Remove the SIM from this phone, buy an 8800 hotspot (sans SIM), and put Visible SIM is the 8800.
Multiple connections, works like a charm.
www.rvSeniorMoments.com
DISH TV for RVs
So you're saying that voice and data count as two connections?  If so, then why am I able to use the phone as a hotspot?
LindaH
2011 Kia Soul
So you are saying buy another phone for $80 and $200 for an 8800 JetPack plus another $25/month rather than a one-time cost of a travel router? Doesn't make a whole lot of sense.
Tom
2005 Born Free 24' Rear Bath
Towing 1978 VW Bug convertible
Minneapolis, MN
The Visible phone only allows it's hotspot to connect to one device at a time.  So turn off your computer, then cycle the Visible phone's hotspot off and then back on so it clears the computer connection and will accept the Hopper as a new connection.  Repeat the process in reverse when you want to use the laptop.
Then get the $30 wireless mini travel router mentioned above.  Connect it to the phone as it's single device and use the router's signal to connect the laptop and router.
Edited by Lou Schneider
When I tried this, the computer was OFF.  The hotspot on the phone was also OFF before I turned it on to try and connect it to the Hopper.
I already have one on order.  Don't know when it's going to be here.
LindaH
2011 Kia Soul
Success, at last!
This morning the Hopper *finally* showed a list of wireless networks (which it hadn't done before).  I found my phone and the Hopper ran through it's setup process.  So now I have the Visible phone connected to the Hopper!
LindaH
2011 Kia Soul
19 hours ago, Darryl&Rita said:
Yay, take that as a victory. You're the resident expert on Visible and Hopper connections.
Yea, except this morning I had to change the Hopper back to my other phone since my computer wouldn't connect to the Visible phone!  That problem should be solved once I get the travel router I've ordered.  Hopefully.
LindaH
2011 Kia Soul
