trimster Posted August 9, 2020 Report Share Posted August 9, 2020 How does one open the passengers side mirror? The last owner ran their own CB coax, disconnecting the factory run into the cab. Now the FM radio picks up almost nothing. Bob Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 9, 2020 Report Share Posted August 9, 2020 There should be 2 small caps on the forward side. There are allen wrench screws under the caps. That gets the back off. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
trimster Posted August 9, 2020 Author Report Share Posted August 9, 2020 (edited) Mine has chrome covers. Don't see any access covers for screws. Guess those covers snap into place? Bob Edited August 9, 2020 by trimster Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
jenandjon Posted August 9, 2020 Report Share Posted August 9, 2020 (edited) I have the same problem my freightliner. I went to Napa and get a new radio antenna to put on the mirror bracket. It worked great. The hard part was finding a place to get the antenna wire out of the dash on the passenger side. I had to buy the antenna, bracket, and an extension because the wire on the antenna was too short to reach the radio. Edited August 9, 2020 by jenandjon Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
alan0043 Posted August 9, 2020 Report Share Posted August 9, 2020 (edited) 13 hours ago, Alie&Jim's Carrilite said: There should be 2 small caps on the forward side. There are allen wrench screws under the caps. That gets the back off. On the gen 2 trucks there is no screws on the back of the cover like the gen 1 trucks. One of the guys here on the forum posted a video how to take your mirrors apart. Don't hold this on me. If I can remember right, you have to remove the mirror it's self. You need to tilt the top of the mirrors all the way in toward to mirror cover. This should bring out the bottom of the mirror. Then you need to be real careful about pushing the bottom of the mirror upward. There are tabs on the plate or backing that the mirror is mounted to. You can break those tabs. Hopefully someone will post the video. I think Google can help find the video. I hope this can help. Al Edited August 9, 2020 by alan0043 Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
trimster Posted August 9, 2020 Author Report Share Posted August 9, 2020 Quote Robert & Lisa '14 Keystone Fuzion 315 38' 5er 2015 Volvo VNL 670, D13, iShift 'The Tartis' (ours) 2013 Smart Fortwo Passion 'K-9' 2011 CanAm Spyder RT Limited (Ours) We are both USAF vets. Link to comment Share on other sites More sharing options...
alan0043 Posted August 9, 2020 Report Share Posted August 9, 2020 44 minutes ago, trimster said: That's the video. Good luck. Quote 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Sculptor Posted August 9, 2020 Report Share Posted August 9, 2020 (edited) Tip the mirror out at the bottom, lift/tap up a short distance, (Think it click releases) then tip out at the top, slide up. Then you decide which screws will remove the housing etc, if needed. The video is the same one I used. Edited August 9, 2020 by Sculptor Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
