Chuck Posted August 5, 2018 Report Share Posted August 5, 2018 I have had my 2003 VNL 610 for approximately 3 weeks. Been going through as many of the systems as I can to learn. Prior to purchase, I had a DOT and pre purchase inspection. What is normal in regards to air leak down. I hear no air leaks, however, the system looses all air over night. The air bags are all soft in the morning. Upon start up, the compressor builds up to 90 pounds in approximately 1 minute and stops beeping at 90 pounds. Is this over night leak down normal.? Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 5, 2018 Report Share Posted August 5, 2018 You do have some leaks. Check the pass-thru under the dash by your left foot. Need to remove the kick panel to get to it. The O-rings are easily replaceable. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted August 5, 2018 Report Share Posted August 5, 2018 Overnight is not uncommon for an older truck to lose its air. What did your gauges read? i worked on my 99 Volvo and got it to hold more than 75 lbs after 3 days. My Freightliner will hold better than 100 lbs for weeks. Link to comment Share on other sites More sharing options...
Chuck Posted August 5, 2018 Author Report Share Posted August 5, 2018 Haven't started since yesterday. One tank reads 0, the other reads about 10. Link to comment Share on other sites More sharing options...
NeverEasy Posted August 5, 2018 Report Share Posted August 5, 2018 If you can't get hold of a Whisper leak detector, go to Wally World and buy a two-quart bottle of kid's bubble maker. Get a sprayer and start looking. Just spray all the connections you can find. Some leaks bubble right away. Others will look like they are growing fur in 2 or 3 minutes. If the air springs (rear and cab) look cracked/checked then spray them and wait a few minutes. My biggest leak was on the side of the transmission. Other leaks were under the dash where there is a tee fitting for the air lines from the tanks to feed the dash air gauges. Be careful spraying a lot of bubble solution under there. It might run down the wires to the throttle position sensor (connected to the foot throttle pedal) and ruin it. Had to buy the whole throttle assembly. Not cheap. If you are going to the National HDT Rally, a couple of us will have Whispers to look for leaks. I have been successful at finding my leaks. Came home from the WCR on June 27th. Started it last week (about July 29th) and it was still holding enough air that the air alarms did not sound (over 90 psi). Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
Chuck Posted August 5, 2018 Author Report Share Posted August 5, 2018 Kind of a side note. You mentioned your transmission. I have a gen 2 Eaton 3 pedal. Having intermittent issues with locking in gear. I thoroughly cleaned all connection in the battery compartment. Have not driven yet to test further. My next step is to have all harness connections cleaned. Is air a component of this transmission.? Link to comment Share on other sites More sharing options...
NeverEasy Posted August 5, 2018 Report Share Posted August 5, 2018 Yes. I have the same tranny. Air comes into the left side, close to the top. Closer to the back than front. Look for an airline that runs over from the frame on the left side. Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
jenandjon Posted August 5, 2018 Report Share Posted August 5, 2018 If its going down overnight its not a big deal. I have had brand new trucks that go down over a few hours and old pieces of junk that would hold for 2 days. As long as you can walk up to the truck and not hear a air leak thats good enough for me. I believe that is what DOT requires. No audible air leaks. You will drive yourself crazy chasing every single little tiny air leak. Once you do find and stop them all you will hit a pot hole and one will come back. Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
hone eagle Posted August 5, 2018 Report Share Posted August 5, 2018 mine holds air for 3 days in summer and 1 day in winter - go figure.worst leak I ever found was passenger side seat. 2005 volvo 670 freedomline singledNewmar Torrey Pine 34rskswoot woot Link to comment Share on other sites More sharing options...
solo318 Posted August 6, 2018 Report Share Posted August 6, 2018 If the bags are going down over night than that is the first place you should look. Spray the bags down and the leveling valve. The bags should actually hold air even if the tanks are empty. The next really common problem is the o rings as was mentioned earlier. After that (on a first gen vnl) check the trolley valve. they bypass and tend to leak out the vent tube under the hood. Click For Full-Size Image. Link to comment Share on other sites More sharing options...
beemergary Posted August 6, 2018 Report Share Posted August 6, 2018 My 1984 Pete will hold air for a week. The suspension a coup;e months and the seats the same. If the suspension is down and tanks are down you have a leak from the air leveler too the bags. Kids bubbles in a spray bottle worls great for finding leaks. Link to comment Share on other sites More sharing options...
