khantroll Posted April 30, 2017 Report Share Posted April 30, 2017 Hi all, I have a couple of questions regarding tankless hot water heaters. I am in the process of renovating my RV, and one of the things that I'd like to do is upgrade to a tankless hot water heater. Initially, I thought my only choice was the Girard Tankless Hot Water heater, but I have seen several videos of vans, buses, and even fifth wheels using one of the small cabin residential tankless hot water heaters. Example: https://www.amazon.com/Ridgeyard-4-75GPM-Propane-Tankless-Instant/dp/B01N9TWZJH/ref=sr_1_6?ie=UTF8&qid=1493589337&sr=8-6&keywords=d+batteries+tankless These are less then half the cost of the Girard., and somewhat smaller. As a follow up, would it be possible to use a plumbing vent as a flue? Thanks in advance for your thoughts! Link to comment Share on other sites More sharing options...
Ranger Smith Posted April 30, 2017 Report Share Posted April 30, 2017 Problem with is you get what you pay for. When it breaks where do you get parts. I had a Rv with a Girard water heater and we took it out and put in a conventional one. It was very finicky. Open the handle less for more hot water. We were lucky if we coud get it set right to take a shower. Little too warm . . . Little too cool. It is also dependent on incoming water temperature. We scrapped it and went back to an Atwood. Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
baloo Posted April 30, 2017 Report Share Posted April 30, 2017 I was also interested in a tankless heater -- but not to replace my present 6GAL propane water heater, but to use in tandem with it. Since our water heater is only 6 gallons, in the event that we would need more hot water in a short amount of time, I'd like the tankless to kick in to meet sudden extra demans. If it's only about $200, it seems worth the money for just those times when more is needed. It certainly would be cheaper than installing a 10 or 15gal tank, in that there would not be the need to heat up and maintain the heat in a whole 10/15 Gal holding tank as it sits there unused. Link to comment Share on other sites More sharing options...
khantroll Posted May 1, 2017 Author Report Share Posted May 1, 2017 Ranger Rick: The poor reviews of the Girard are one of the reasons I'm looking at other avenues. As for parts availability, I totally see your point; however, in my home area, I'd have to order any part other then plumbing valves or an anode rod for a regular hot water heater. Baloo: here is a guy who did something similar to what you are proposing: Thanks! Link to comment Share on other sites More sharing options...
baloo Posted May 1, 2017 Report Share Posted May 1, 2017 Khantrall, excellent info. Thanks. Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 1, 2017 Report Share Posted May 1, 2017 The current gold standard in on demand water heaters for RV's is Truma. They have been in the European market for a while and have been moving into the Armerican market over the last few years. Many manufacturers now offer it as an option. I have one and am very happy with it. It has all the benefits of an on demand system and has engineered out the draw backs as described above with temperature issues. Truma did this by adding a small temperature stabilizer tank in the unit. They are not the cheapest option out there, but they are the best. 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
khantroll Posted May 1, 2017 Author Report Share Posted May 1, 2017 Hi Chad, Can you purchase a Truma unit? I thought they were only available as options in specific RVs. If you can, how much are we talking? Thanks! Link to comment Share on other sites More sharing options...
Kirk W Posted May 1, 2017 Report Share Posted May 1, 2017 I was just looking at them and found this list of dealers in this part of the US. In doing searches, I find that there are now at least 4 manufacturers in the US with Suburban, Atwood, and Precision Temp also offering them. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
khantroll Posted May 1, 2017 Author Report Share Posted May 1, 2017 I obviously can't compare any of them based on performance (as I have never had any of them), but: Truma AquaGo: 60000 BTU - 2 gallons per minute flow rate - $1100 Atwood Tankless Hot Water Heater: 50000 BTU - 1.5 gallons per minute - $825 Suburban IW60: 60000 BTU - 1-2 gallons per minute: $610 Precision Temp RV-550: 55000BTU - 1 gallon per minute: $1070 Girard GSWH-2: 42000BTU - 1.6 gallons per minute: $514 Based on the above, if I had to choose one of those I think I'd opt for the Suburban, but just for the sake of comparison: Ridge Yard 12L: 80000BTU - 3.2 gallons per minute: $143 Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 1, 2017 Report Share Posted May 1, 2017 3 hours ago, khantroll said: Hi Chad, Can you purchase a Truma unit? I thought they were only available as options in specific RVs. If you can, how much are we talking? Thanks! The Truma's are available in the aftermarket. I have not priced one out, but Jack Mayer had one installed in his New Horizon's from the aftermarket. He wrote a review on it after using it for some time (which you can see here) and was very pleased with its performance. When I ordered my new DRV, I opted to have the Truma installed in it and am very happy with it. 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
baloo Posted May 1, 2017 Report Share Posted May 1, 2017 7 hours ago, khantroll said: I obviously can't compare any of them based on performance (as I have never had any of them), but: Truma AquaGo: 60000 BTU - 2 gallons per minute flow rate - $1100 Atwood Tankless Hot Water Heater: 50000 BTU - 1.5 gallons per minute - $825 Suburban IW60: 60000 BTU - 1-2 gallons per minute: $610 Precision Temp RV-550: 55000BTU - 1 gallon per minute: $1070 Girard GSWH-2: 42000BTU - 1.6 gallons per minute: $514 Based on the above, if I had to choose one of those I think I'd opt for the Suburban, but just for the sake of comparison: Ridge Yard 12L: 80000BTU - 3.2 gallons per minute: $143 Khantroll, I have to agree that the cheaper heaters, as on EBay for example, have higher GPM than those 2-4X as expensive. If you put one of the cheaper ones in tandem with an exisiting conventional water heater, they should be rarely used (only when you max out the 6, 10, or 15GAL capacity), so thus not overly stressed -- and thus not leaving you stranded should the cheap version fail. I think we all like to tout buying quality, but after a while, one realizes that it just doesn't matter if you have a Vacheron-Constantin and drive a Rolls, when you just want to go to the grocery store and back in your 87 Tercel with a Timex. We aren't talking about traveling in outer space, where you have no chance to pull over to a Lowes, ya know. Link to comment Share on other sites More sharing options...
LindaH Posted May 2, 2017 Report Share Posted May 2, 2017 On 4/30/2017 at 3:15 PM, Ranger Smith said: Problem with is you get what you pay for. When it breaks where do you get parts. I had a Rv with a Girard water heater and we took it out and put in a conventional one. It was very finicky. Open the handle less for more hot water. We were lucky if we coud get it set right to take a shower. Little too warm . . . Little too cool. It is also dependent on incoming water temperature. We scrapped it and went back to an Atwood. We, too, have a Girard tankless water heater which I hate. I'd love to replace it with a "regular" water heater. How much did it cost you to make the switch? You can PM me if you wish. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
baloo Posted May 2, 2017 Report Share Posted May 2, 2017 9 minutes ago, LindaH said: We, too, have a Girard tankless water heater which I hate. I'd love to replace it with a "regular" water heater. How much did it cost you to make the switch? You can PM me if you wish. Linda -- as per above posts, been thinking about adding a cheap tankless IN TANDEM (as per the OP's video). Can you give more detail about what you hate about your tankless heater? Too hot? Breaks down? etc.? Thanks. Link to comment Share on other sites More sharing options...
Ranger Smith Posted May 2, 2017 Report Share Posted May 2, 2017 38 minutes ago, LindaH said: We, too, have a Girard tankless water heater which I hate. I'd love to replace it with a "regular" water heater. How much did it cost you to make the switch? You can PM me if you wish. I believe it was 300 to 400 dollars to buy a regular water heater. I installed it myself Steve and Joy Amateur Radio Operator WZ1T . . . Flex 6600 M, Flex PGXL, Flex TGXL, 2014 Itasca Suncruiser 38Q . . . Lincoln MKX Toad The Kids . . . Yogi the Yorkie passed 10/20/2018. . . Cookie the Chihuahua passed 11/30/2017 . . . Cooper the Aussie Doodle passed 3/10/2020 Abbie and Abel the Doodles . . . Brother and Sister Born 02/02/2020 . . . Lucy the Yorkie . . . and Axel . . .The Bernie Doodle Where We Are Now Link to comment Share on other sites More sharing options...
LindaH Posted May 2, 2017 Report Share Posted May 2, 2017 5 hours ago, Ranger Smith said: I believe it was 300 to 400 dollars to buy a regular water heater. I installed it myself Thanks. We'd have to have someone install it, so that would probably at least double the price. We may get a quote to do this when we take our RV in for servicing before we head out for our winter travels. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
LindaH Posted May 2, 2017 Report Share Posted May 2, 2017 6 hours ago, baloo said: Linda -- as per above posts, been thinking about adding a cheap tankless IN TANDEM (as per the OP's video). Can you give more detail about what you hate about your tankless heater? Too hot? Breaks down? etc.? Thanks. We did have a problem when it totally quit working. Of course, we were on our way home and had no place to get it repaired until we got home! But that was a one-time occurrence. What I don"t like about it is that it won't keep a constant temperature when running water. We take Navy showers even when in an RV park (which isn't often). When we turn the water back on to rinse off, We've learned to step back, otherwise we get sprayed with cold water! And even once the water gets hot again, the temperature fluctuates. Never had that problem with a regular water heater. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
57becky Posted May 2, 2017 Report Share Posted May 2, 2017 When our Suburban 12 gallon water heater developed a leak last year, I considered replacing it with a Suburban tankless unit. The downside of this, which changed my mind, was in replacing a conventional unit with the tankless, they have an annual maintenance requirement that necessitates access to the rear of the water heater, and on our rig, that would be impossible to do. So, before you jump at the tankless option, be sure to check everything about the unit you want, and what is needed for maintenance. Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 2, 2017 Report Share Posted May 2, 2017 45 minutes ago, LindaH said: We did have a problem when it totally quit working. Of course, we were on our way home and had no place to get it repaired until we got home! But that was a one-time occurrence. What I don"t like about it is that it won't keep a constant temperature when running water. We take Navy showers even when in an RV park (which isn't often). When we turn the water back on to rinse off, We've learned to step back, otherwise we get sprayed with cold water! And even once the water gets hot again, the temperature fluctuates. Never had that problem with a regular water heater. You won't have that problem with a Truma on demand heater either. Their system has resolved this issue that other tank-less water heaters have. 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
LindaH Posted May 3, 2017 Report Share Posted May 3, 2017 14 hours ago, Chad Heiser said: You won't have that problem with a Truma on demand heater either. Their system has resolved this issue that other tank-less water heaters have. Well, if we replace our current water heater, it will be with an Atwood 6-gallon propane-only water heater, not another tankless. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
lockmup68 Posted May 5, 2017 Report Share Posted May 5, 2017 Truma is $1495 installed. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 5, 2017 Report Share Posted May 5, 2017 Luckily for me it was a lot cheaper than that OEM. 2009 Volvo 670 with dinette/workstation sleeper - Walter 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage) My First Solar Install Thread My Second Solar Install Thread & Photos and Documents Related to the build My MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Jack Mayer Posted May 5, 2017 Report Share Posted May 5, 2017 9 hours ago, Chad Heiser said: Luckily for me it was a lot cheaper than that OEM. Yeah, it is more likely in the $700-800 range when ordering it in a rig. Retrofit will be more, of course. The Truma works very, very well. I've got two years on mine and it has been reliable and maintenance free. There are some "nuances" in its use which I cover in my review document that Chad referenced above. Here it is again...LINK. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
khantroll Posted May 7, 2017 Author Report Share Posted May 7, 2017 Hi all, I decided against the the residential tankless hot water heater; in my particular rig, it would have required major modification that I wasn't comfortable with. So I made some phone calls, and I found a used Atwood On-Demand hot water heater for a very affordable price. If someone has a rig with large storage bays where they could mount that residential heater, or something that isn't basically foam and plywood like my rig is, the heater could work. Link to comment Share on other sites More sharing options...
