faucettdds Posted March 30, 2017 Report Share Posted March 30, 2017 Lifestyle 5th wheel has a water pump that continuously when 12v is on. Removed water pump rocker switch and it appears to be working properly? Need to pull fuse at pump to get it to stop, any suggestions? Tks Bob Link to comment Share on other sites More sharing options...
Dutch_12078 Posted March 30, 2017 Report Share Posted March 30, 2017 There's a pressure switch on the pump that should shut it off when the system reaches the preset pressure limit. Is that not happening? Are there multiple pump switch locations? Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted March 30, 2017 Report Share Posted March 30, 2017 Are you getting water out of the faucets? It takes a while too fill the water heater and pressurize the system. Link to comment Share on other sites More sharing options...
jblo Posted March 30, 2017 Report Share Posted March 30, 2017 These pumps only stop running when pressure builds--no pressure, pump will keep running. Sounds like the pressure switch is faulty. Have you determined if it is pumping water or just running and not moving any water? ` Link to comment Share on other sites More sharing options...
Kirk W Posted March 30, 2017 Report Share Posted March 30, 2017 It should be possible to turn the pump off with the pump switch. If you remove the switch and lift one lead, does the pump run when the fuse is put back? If so, there has to be another path but if not, that indicates that the switch has failed and needs to be replaced. If it doesn't shut off when pressure builds up, I suspect that your RV has one a valve that allows you to fill the fresh water tank with the hose connected to city water. If you leave that valve open when you are trying to use the water pump to supply water from the potable water tank, the pump will draw water from the bottom of the tank, push it out into the water system, where it then passes by the city connection and through the tank fill valve, returning back to the potable water tank at the top. If that valve is open, the pump will run constantly because it can't build up the required pressure in the lines to shut off. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
lenp Posted March 30, 2017 Report Share Posted March 30, 2017 Is all the air purged out of the system? Sometimes an air leak can occur on the suction side of the pump and the pump is just sucking air and will never build pressure. Lenp USN Retired 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited 2024 HD Triglide Link to comment Share on other sites More sharing options...
DuffMan Posted March 30, 2017 Report Share Posted March 30, 2017 Why do you have to pull a fuse to stop the pump from running? Why won't it stop when you turn it off with the switch? How is the pump getting any power with the switch off? Link to comment Share on other sites More sharing options...
faucettdds Posted March 31, 2017 Author Report Share Posted March 31, 2017 Turns out there was a 2nd independant on/off switch located at the outside shower. Owned the 5th 4 years and never knew or read about it. Problem solved. Tks all. Link to comment Share on other sites More sharing options...
Kirk W Posted April 1, 2017 Report Share Posted April 1, 2017 Great news! Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
jblo Posted April 4, 2017 Report Share Posted April 4, 2017 Sorry I did not mention that--all my units have had that feature. Still doesn't answer why it did not build pressure and stop? Link to comment Share on other sites More sharing options...
Ray,IN Posted April 6, 2017 Report Share Posted April 6, 2017 jblo that's what I was thinking as I read his last post. It's quite possible his pump requires a rebuild, a failed back-flow prevention valve in the pump would cause constant running. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
