dewilso Posted December 23, 2016 Report Share Posted December 23, 2016 My Pressure Pro is ~5yrs old and about needing replacement sensors. The price of 10 sensors will be ~ $400, for about the same price I can get a replacement system. The question, is do I get another PP, or another brand? One thing I want to keep is the ability to check pressures without moving. One thing I want to add is ability to replace batteries. Your suggestions or recommendations? Dave W. KE5GOH Stuck in the 70's --- In E. Texas Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted December 23, 2016 Report Share Posted December 23, 2016 We went 7.5 years before we preemptively changed the sensors for our PressurePro system. We used 18 sensors which put most of the alternative systems out of the game. We never wanted to change batteries. Getting replacement sensors meant newer technology like the significantly improved seals as well as new batteries. And replaceable batteries means O-rings susceptible to damage. We preferred the LED display over the LCD and the fact that we could direct wire the monitor,no concerns about the batteries being charged. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 24, 2016 Report Share Posted December 24, 2016 We've been very pleased with our 10 sensor TST 507 system. I hardwired the monitor using the supplied harness, and replacing the batteries for less than $1/battery is a simple process. The TST monitor displays the most current pressure and temperature readings at any time whether the vehicle is in motion or not. Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Jack Mayer Posted December 24, 2016 Report Share Posted December 24, 2016 I switched from PP to TST. Mainly because of sensor issues with the "new" sensors. No regrets.The TST works more reliably, at least in my situation. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
remoandiris Posted December 24, 2016 Report Share Posted December 24, 2016 I'm pleased with my TST 507 with flow thru sensors. No repeater needed on my 40' 5er. Be careful using a long torque wrench when tightening the lug nuts. Bumping a sensor can be bad. Link to comment Share on other sites More sharing options...
dartmouth01 Posted December 24, 2016 Report Share Posted December 24, 2016 I have the 507 system (or is it the 510, whichever one is the replaceable batteries) been used at least 100k miles/5 years and the sensors and the receiver are still going strong. I've replaced the batteries several times, and I actually only operate the receiver on battery power (just recharge when needed). The receiver battery still will last at least 2-3 days of solid driving 8 hrs a day before needing a recharge. I did install the repeater in the front of the rig. Link to comment Share on other sites More sharing options...
billr Posted December 25, 2016 Report Share Posted December 25, 2016 Went to TST after 7 yrs with PP. I like the 507 syst with replacement batteries. Repeater is recommended with most big rigs. PP is a great syst too. Cost initially and sensor replacement when batts die make the TST a better value. Also temp indication on the TST is nice feature. Bill and Joan and 3 Collie pups 2001 Volvo VNL 770 "The Doghouse" Singled short, "ET" hItch VED12 465HP Gen 1 Autoshift 3.58 ratio 2005 Mobile Suite 38RL3 2011 Smart Passion loaded piggybacK Weigh-It Portable RV Scales http://www.weighitrv.com/ Link to comment Share on other sites More sharing options...
richfaa Posted December 25, 2016 Report Share Posted December 25, 2016 My Pressure Pro is ~5yrs old and about needing replacement sensors. The price of 10 sensors will be ~ $400, for about the same price I can get a replacement system. The question, is do I get another PP, or another brand? One thing I want to keep is the ability to check pressures without moving. One thing I want to add is ability to replace batteries. Your suggestions or recommendations? We were faced with the same situation a couple of years ago we had a 7 year old PP system that needed new sensors. We purchased the TST system at a RV show for less than the PP sensor replacement and got a upgraded system .Our PP system batteries lasted 7 years so we did not worry about replaceable batteries. You can check pressure by just activating the system in place. The PP system served us well as is the TST system. It was just a matter of cost. Helen and I are long timers ..08 F-350 Ford,LB,CC,6.4L,4X4, Dually,4:10 diff dragging around a 2013 Montana 3402 Big Sky SKP 100137. North Ridgeville, Ohio in the summer, sort of and where ever it is warm in the winter. Link to comment Share on other sites More sharing options...
Biker56 Posted December 26, 2016 Report Share Posted December 26, 2016 I replaced my Pressure Pro sensors when they were 9 years 6 months old, That was 2 years ago. at that time the 10 replacements were $368 Today 10 replacements are $398.50 In 8 years I will probably still replace with PP again. But I only use them 5 months a year and never had a problem with them. A new 10 sensor 507 TST Flow Thur system is $559 plus $50 for a year extended warranty. Plus changing the batteries once a year. Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
teacher's pet Posted December 26, 2016 Report Share Posted December 26, 2016 Have two RVs, a Class A & B+. Started with PP in January 2006 and had some sensors fail at 3-4 years, on the Class A. When we bought the B+ in 2012, I equipped it with the PP system that was on the A since several of my 10 sensors were failing again. I switched the Class A & our Sport Trac toad to TST507, worked great. When the PP on the B+ failed to less than 6 sensors I replaced them with a 10 sensor (setting up a Miata as a toad) TST507 system also. I have one range extender and extra monitors for each of our toads, which works great when unhooked from the motorhomes. Yes I have had to change a batteries since 2012, I'm on my second set of 20 - Energizer CR1632 that I order from Amazon for around $15 for 20 which is less than 1/2 the price of 1 PP sensor. I like the temperature function on the TST507 also Teacher's Pet '06 40' Phaeton QSH 350 Cat. '04 R-Vision B+ Model 213, 6.0 Chevrolet. http://www.skoolzoutforever.blogspot.com http://map.datastormusers.com/user3.cfm?user=3912 Link to comment Share on other sites More sharing options...
remoandiris Posted December 26, 2016 Report Share Posted December 26, 2016 I replaced my Pressure Pro sensors when they were 9 years 6 months old, That was 2 years ago. at that time the 10 replacements were $368 Today 10 replacements are $398.50 In 8 years I will probably still replace with PP again. But I only use them 5 months a year and never had a problem with them. A new 10 sensor 507 TST Flow Thur system is $559 plus $50 for a year extended warranty. Plus changing the batteries once a year. I don't know where you're shopping, but here, a 10 sensor system with 3 yr warranty is $475. http://www.infotechrvsolutions.com/TPMS.html Link to comment Share on other sites More sharing options...
