How much is too much?
mkvacik
I have a Pete 387 I am trying to decide on how I want it set up.
The main question, how far behind the axle is too far as far as the hitch goes? I looked at several at the rally, but didn't really think to measure. Pretty sure I have measured one that is about 7' behind the rear axle.
I don't have a distinct single purpose for the bed at this point for sure. Ideally I would like room for my 4 seat rzr back there, keep the wheelbase as short as I can for maneuverability.
If the truck is singled think of the rear axle a the fulcrum point of a teeter totter, the farther away you place the load the more you unload the front axle. To keep the front suspension from becoming too bouncy it is best to have 65~70% of the capacity on the springs.
Steve
Steve
So your saying I almost need to make up my mind on how much junk I want to haul on the bed and ahead of the axle before I decide on that totally.
You should have at least a rough idea of fixed weight and moveable weight ie fuel, people toys etc. The most significant issue is, with a long moment arm the additional force in a bump for example, could unload the front axle. Best guess is factor in 1.4G acceleration for the pin weight.
Steve
Steve
And think about how much it will load the rear axle. Think of your truck's frame as a simple lever, so for every pound of pin weight you apply to the fifth wheel, you'll end up with [front axle to pin distance]/[wheelbase] pounds on the rear axle.A 6k pin weight can easily translate to a 9k bonus on the rear axle (which also means 3k unload on the front axle). If you single the truck, you likely end up with a 20k rear axle, but probably had 8-9k on it empty. 9k of apparent trailer weight only leaves you ~2k for bed plus other cargo.
Some folks have been using my live data weight & balance spreadsheet to do "what-if-loadings" to determine the actual axle loadings for both truck and trailer axles.........
Like Trey says .......actual wheel positions loading needs to be considered......
If you would like to use the live-data-spreadsheet just send me a email at mmcdan3189@aol.com and I will email you the spreadsheet.
The spreadsheet lets you move loads, hitch locations, axle locations and see the effects live.
Drive on..........(lets see where are my axles and hitch and trailer loads ......today)
I don't want to hi-jack this thread, but I have a stupid here: what is the reason to move the hitch past the rear axle ? Isn't the weight preferred to be above the rear axle? or do you move it back for more cargo space on the truck?
just trying to prepare my self for a future conversion :-)
Using the HDT, there is so much weight capacity even singled that the pin weight doesn't have to be centered over the axle like you would on a normal 3500 light duty truck. Moving the hitch towards the rear also makes the trailer react faster when backing, and track better around turns. A fifth wheel hitched 5-6 feet behind the axle acts like a bumper pull when towing, but no sway.
Jim's Adventures
Old Spacecraft.... Who knows whats next
