Kevin H Posted June 20, 2016 Report Share Posted June 20, 2016 I'm thinking about putting on a new differential cover on my 2011 Ram 3500 SRW. I want one that increases my fluid capacity and has cooling fins. Anyone have a suggestion or preferred brand? I may put in a temp sensor and gauge too. Truck is 2011 Ram 3500 SRW 4x2 Long Bed Crew Cab 373 rear end 6 speed manual 6.7 L Cummins 103k miles I tow a 14K Montana 5er I am not having any problems with the stock setup. Just thinking of doing it for increased lubrication and heat dissipation. The richest are not those who have the most, but those who need the least. Link to comment Share on other sites More sharing options...
Truckman Posted June 20, 2016 Report Share Posted June 20, 2016 I have used Mag-Hytec on the last 3 trucks. Link to comment Share on other sites More sharing options...
skp51443 Posted June 20, 2016 Report Share Posted June 20, 2016 Check the temp on your stock setup and see if there is an issue, no sense spending money to fix something that isn't a problem. First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 20, 2016 Report Share Posted June 20, 2016 Mag-Hytec as well on my last Dodge. Gave me 2 Qts or so more fluid and it did run cooler. I used Royal Purple gear lube in it. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
SCClockDr Posted June 21, 2016 Report Share Posted June 21, 2016 Genos Garage for the Mag-Hytec once you are convinced you need it. Ensure the spare will sufficiently clear when the new cover is installed. BTDT had to move the spare a bit. Link to comment Share on other sites More sharing options...
bobsallyh Posted June 21, 2016 Report Share Posted June 21, 2016 Kevin H, with 206,706 miles on the clock of our 2003 Dodge Dually and pulling a 40' fiver with a stock AAM cover, to me it is just another aftermarket product that I sure don't need. The only thing I wish manufactures would do, is to put a drain plug on the bottom of the housing so you wouldn't have to pull the whole stupid cover with I think 10 bolts. Link to comment Share on other sites More sharing options...
mptjelgin Posted June 21, 2016 Report Share Posted June 21, 2016 I look at aftermarket differential covers as shiny "bling" more than anything else. I agree that having a drain plug would be convenient, but don't think that any of the big three trucks need extra gear lube or cooling. They work just fine as designed. When I had the gears in my 1999 F-250 swapped from 3.73 to 4.30 I asked the shop (which did nothing but rebuild differentials all day, every day) if I needed to consider an aftermarket cover. His answer was essentially "The factory rear end has plenty of gear lube and cools just fine. Aftermarket covers are pretty, but do nothing to improve performance or durability". Mark & Teri 2021 Grand Designs Imagine 2500RL, 2019 Ford F-350 Mark & Teri's Travels Link to comment Share on other sites More sharing options...
gjhunter01 Posted June 22, 2016 Report Share Posted June 22, 2016 I have 290k on a chevy dually and the diff temp runs at 150F when checking with a heat gun. I use synthetic oil and change at 50k miles and so far everything is running fine. I once considered an over sized cover with fins but couldn't justify the $200+ cost. Most issues with diff's are caused by low fluid level and not following the owners manual for fluid change intervals. Greg Link to comment Share on other sites More sharing options...
Kevin H Posted June 22, 2016 Author Report Share Posted June 22, 2016 Thanks everyone. I guess I'll get a infrared temp reader before dropping a couple hundred on something I may not need. Â Good tip SCClockDr on making sure a new cover clears the spare tire. The richest are not those who have the most, but those who need the least. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 22, 2016 Report Share Posted June 22, 2016 When I installed the MagHytec on the Dodge, I mainly did it so I could monitor temps. They have the drain plug as well as a top port for a temp probe. The "Optional" reason was I was pushing a whole bunch of HP and Torque- 600+hp 1100tq thru the driveline. Granted the transmission was all aftermarket, the driveshaft was a 1 piece all aluminum with huge u-joints on both ends. And I figured that the extra fluid wouldn't hurt either. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
GlennWest Posted June 23, 2016 Report Share Posted June 23, 2016 For a stock truck just a waste of money. But lots of people waste money. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
