CHIEFWAHO Posted June 14, 2016 Report Share Posted June 14, 2016 Inspired by bmzero's seat install http://www.followmybuild.com/bmzero/Volvo-730-HDT-RV-Hauler/Interior-Upgrades/Photo-Gallery-3442 I decided it was time to knock this out before the upcoming trip to South Dakota. The Toyota Sienna seats were sourced from eBay http://www.ebay.com/itm/162065240798?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT I believe the same source bmzero used. Opted for the same exact seat for both sides, no drive and passenger. Seats were delivered promptly in 2 well packaged boxes. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted June 14, 2016 Author Report Share Posted June 14, 2016 After some discussion with bmzero it was time to start hacking. Trim and bottom seat cushion removed. While stripping these down I found a build date of March of this year. Here is where the hacking begins To get these to fit over the Volvo base nearly all the center section of donor seat frame structure must be removed. Can't begin to count how many time we had the seat back and bottom cushion on and off to achieve a height we liked. Ending up using a 13.5" long piece of 2" x 2" x 3/16" angle to butt up against the existing donor framework at the rear slider mount. The front was 1/4" x 2" x 18" bar with 1/2" x 1" x 3" bar on top of it to space away from the slider lever. 1/4" thick tabs were welded to the spacer bar to enable bolting to the front sliders. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted June 14, 2016 Author Report Share Posted June 14, 2016 Shots of the modified bracket left and the OE on the right 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted June 14, 2016 Author Report Share Posted June 14, 2016 Piss poor shot of the first seat bracket painted and ready for reassembly. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 14, 2016 Report Share Posted June 14, 2016 Nice Job! So how much would a "Modified" set of seats cost for a '98 Volvo.... Gray interior..... Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
noteven Posted June 15, 2016 Report Share Posted June 15, 2016 What advantage are van seats vs replacing worn out seats with heavy duty truck seats? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted June 15, 2016 Report Share Posted June 15, 2016 You didn't talk to zero long enough. If you had, he would have added an airbag under the seat and then used the handle under the bottom seat cushion as an ejection handle. Other than that, nice fab job. 2023 Thor Magnitude XG32 Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted June 15, 2016 Author Report Share Posted June 15, 2016 What advantage are van seats vs replacing worn out seats with heavy duty truck seats? The advantage for me is I have 2 brand new leather seats and am only out around $350 and some time. Plus we now have seats that recline and have armrest all around. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted June 15, 2016 Author Report Share Posted June 15, 2016 Nice Job! So how much would a "Modified" set of seats cost for a '98 Volvo.... Gray interior..... We have so many projects we usually don't hire out. But if you want to come hang out for a few days I bet we could get you fixed up. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted June 15, 2016 Author Report Share Posted June 15, 2016 More progress last night. Driver base cleaned up with new frame work attached. Installing driver side Passenger reclined Trim fitting 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
HERO Maker Posted June 15, 2016 Report Share Posted June 15, 2016 Nice clean job. Looks great. Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
forxlr8n Posted June 15, 2016 Report Share Posted June 15, 2016 I mounted 2010 Mustang seats in my 84 Mustang. I think i wore the seats out in out in out. put the seat back together check fit. remove start over and over and over. I feel your pain. "If you can not measure it, you can not improve it." Lord Kelvin Link to comment Share on other sites More sharing options...
hdonlybob Posted June 15, 2016 Report Share Posted June 15, 2016 Very nice job !! I did a similar switch when I had my 610 Volvo using Buick bucket seats from a junkyard. Loved them, and to answer a previous post about what the advantage is....the cost it was minuscule compared to new semi seats. 1989 Safari Serengeti 34'Towing a 1952 M38A1 Military Willys Past HDT owner Link to comment Share on other sites More sharing options...
bmzero Posted June 15, 2016 Report Share Posted June 15, 2016 Looks great! You're going to love them on the long drives. "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
CHIEFWAHO Posted June 16, 2016 Author Report Share Posted June 16, 2016 Nearly complete. Just letting some glue dry. Where the blue tape is, was a lever that was not longer to be used. We just decided to glue it in place to cover the hole. 1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF' Custom flatbed with TrailerSaver air hitch. 3 cyl 8000 watt Kubota diesel generator. Link to comment Share on other sites More sharing options...
bmzero Posted June 16, 2016 Report Share Posted June 16, 2016 Nearly complete. Just letting some glue dry. Where the blue tape is, was a lever that was not longer to be used. We just decided to glue it in place to cover the hole. Looks good. I was thinking about making aluminum sheet metal covers for mine that fit the seat and base. That looks a lot easier! "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
