zipposrv Posted May 11, 2016 Report Share Posted May 11, 2016 Hi all, we are going to "test load" the car this afternoon, are there any special steps we need to take. Thanks Mary MAHEATH Link to comment Share on other sites More sharing options...
Jack Mayer Posted May 11, 2016 Report Share Posted May 11, 2016 Not really. Just be careful. Double check everything. No one should stand in front of the car. Make doubly sure that the line is in the pulley's correctly. I assume you have watched the loading video's. Try to make sure you are on a level "plane" before loading....or that the ground rises on the car side (less angle on the deck and bottom of ramps). Most important - take your time. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
GlennWest Posted May 11, 2016 Report Share Posted May 11, 2016 We just drove ours up. Did have stops on deck to stop us. Did fold my mirror in. I drilled a hole thru ramp and deck and installed a pin so they couldn't kick out. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Jim & Wilma Posted May 11, 2016 Report Share Posted May 11, 2016 If you're winching the car up the ramps, watch for the cable rubbing the deck when you first hook up. Depending on the angle that Jack mentioned, we may drive the Smart up the ramp a foot or so to raise the cable off the deck. Some people put a piece of HDPE plastic on the deck for the cable to glide over. This all depends on your setup and may not be necessary, just look out for it. Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
rdickinson Posted May 11, 2016 Report Share Posted May 11, 2016 A plastic load corner protector works for the cable, the slot in it fits over the T handle of the ramp compartment. Make sure the car is perpendicular to the deck or it will load crooked and will hit one chock at the back before the other. Be careful the underbelly doesn't catch on the deck bolts. I put a pce of 1/8" thick angle iron in the ramp hinge to reduce breakover angle. Don't load with the truck deck out of level so the car runs downhill backwards when going onto the deck. Link to comment Share on other sites More sharing options...
zipposrv Posted May 11, 2016 Author Report Share Posted May 11, 2016 Thanks everyone, do I need anything to the car itself. We have a tow bar for the back, and will be winching it on. Safety is always first, as my husband is an owner operator, that specializes in over sized loads. MAHEATH Link to comment Share on other sites More sharing options...
rdickinson Posted May 11, 2016 Report Share Posted May 11, 2016 I'd use a pulley on the back bumper then run the cable from the winch thru the pulley then back to the winch or A frame. It will take the jerkiness out of the winching and slow the load speed by 50%, giving you more time to check and/or adjust things as the go up the ramps. Link to comment Share on other sites More sharing options...
zipposrv Posted May 11, 2016 Author Report Share Posted May 11, 2016 Well, everything went as planned. Just a few more things to finish up, them off to Yellowstone for the summer. Thanks for the input. MAHEATH Link to comment Share on other sites More sharing options...
sclord2002 Posted May 11, 2016 Report Share Posted May 11, 2016 Congratulations.....enjoy your trip !! Charlie Don't ever tell a soldier that he doesn't understand the cost of war. Link to comment Share on other sites More sharing options...
Chad Heiser Posted May 12, 2016 Report Share Posted May 12, 2016 Well, everything went as planned. Just a few more things to finish up, them off to Yellowstone for the summer. Thanks for the input. Where will you be in Yellowstone? We are going to be heading through there in early June. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
zipposrv Posted May 12, 2016 Author Report Share Posted May 12, 2016 I'll be working at Grant Village until September. MAHEATH Link to comment Share on other sites More sharing options...
noteven Posted May 12, 2016 Report Share Posted May 12, 2016 Generally when we winch a wheeled something we set up a bit of a lean if possible so the winch has tension the whole distance, loading or unloading to keep the wheeled something under winch control at all times... if that makes sense "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
