grendel Posted January 8, 2016 Author Report Share Posted January 8, 2016 In another thread you talked about putting a 10-speed in it...did that ever work out? There may be a little confusion... RB and I are always confused until the truck shows itself. This truck, the green <T> got a 10 speed. RB's got an Allison that was matched to the military spec Cummins 8.3L 6CTA. That engine got a little love, too. Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 8, 2016 Report Share Posted January 8, 2016 Doug yeah, i may confused things with posting my DiamondT in Johns DiamondT thread but yes, John convinced me to try the MIL non-electronic Allison after riding shotgun in his friends 5 ton (same 8.3 cummins/Allison) while flat towing "my" engine donor (what was another 5ton truck).... ... i really liked how quick & crisp it shifted (the MIL spec Allison is definitely not a slushbox) i dreamed about a 13 speed for its tight ratio split ... but not about shifting it so we will see how the Allison works out Johns combo of 650 hp 15 liter Cat & super10 is definitely another story ... he will need a lot less physical shifts than i would need with a 8.3/13 speed combo " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
Buscrusher Posted January 8, 2016 Report Share Posted January 8, 2016 Doug yeah, i may confused things with posting my DiamondT in Johns DiamondT thread but yes, John convinced me to try the MIL non-electronic Allison after riding shotgun in his friends 5 ton (same 8.3 cummins/Allison) while flat towing "my" engine donor (what was another 5ton truck).... ... i really liked how quick & crisp it shifted (the MIL spec Allison is definitely not a slushbox) i dreamed about a 13 speed for its tight ratio split ... but not about shifting it so we will see how the Allison works out Johns combo of 650 hp 15 liter Cat & super10 is definitely another story ... he will need a lot less physical shifts than i would need with a 8.3/13 speed combo Actually, I wasn't confused. Jealous, maybe...lol...?. You guys with your fabrication skills impress the heck out of me. I worked for a charter bus company that had mostly old MCI MC8s and one MC9 with the Allison 754 and 755 (I think that's the right model #...most of them were 4-speeds, one was a 5-speed that would run 85+mph on level ground with a 318 Jimmy!). Adjusted right they are a pleasure to drive, for sure. On the subject of the 10-speed, I was thinking it might have been fun to drop the one you had behind a warmed-up Cummins B 12 valve in a 90s Dodge pickup... DougFrequent "lurker"Occasional posterFirst step towards the RV setup complete: 1 smart car Link to comment Share on other sites More sharing options...
grendel Posted January 10, 2016 Author Report Share Posted January 10, 2016 Here's a perspective shot. Link to comment Share on other sites More sharing options...
oscarvan Posted January 11, 2016 Report Share Posted January 11, 2016 I assume that since you're mixing aluminum and steel you are intimately familiar with Tefgel? Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
noteven Posted January 11, 2016 Report Share Posted January 11, 2016 Grendel and Roosters most excellent fabricating adventure "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 11, 2016 Report Share Posted January 11, 2016 Is an AC unit going on that roof, or will it be "basement" air? Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
grendel Posted January 11, 2016 Author Report Share Posted January 11, 2016 Basement air/generator. Roof will be for your solar panels Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 11, 2016 Report Share Posted January 11, 2016 I assume that since you're mixing aluminum and steel you are intimately familiar with Tefgel? no , but POR and Sikaflex steel contact surfaces got a good coat of POR prior to assembly with Sikaflex adhesive/sealer there will also be a consumable "anode" in a hidden place full aluminum construction would be preferable ... but we decided on a steel air ride subframe mainly for the reason that we could make it lower profile in steel when deflated it is really hugging the frame ... and another pic of the front pivot points (we used Peterbilt spring hangers with PU bushings); " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
grendel Posted January 11, 2016 Author Report Share Posted January 11, 2016 A bunch of consumables. There will be no uncontrolled galvanic corrosion. <-- is a retired, US Navy. Link to comment Share on other sites More sharing options...
Broncohauler Posted January 11, 2016 Report Share Posted January 11, 2016 You guys amaze me with a attention to detail. You just don't see people take the time and put the extra effort in places that may never be seen. Link to comment Share on other sites More sharing options...
oscarvan Posted January 11, 2016 Report Share Posted January 11, 2016 Yup, get some zincs at the boat shop. Nice welds. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
grendel Posted January 11, 2016 Author Report Share Posted January 11, 2016 Yep. Zinc huck bolts Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 21, 2016 Report Share Posted January 21, 2016 due to bitter cold weather the fabrication (and camping) came to a stop i`m riding out the cold spell in a motel room ... next week is supposed to be a "warm" 40 degree , so we should be able to do a couple more things and hopefully move the trucks to a (heated) shop " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
noteven Posted January 22, 2016 Report Share Posted January 22, 2016 Rooster & Grendel "why" would a full timer want a properly insulated FTV again? ... :D The Diamond T's look great side by each visiting... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
jkennell Posted January 25, 2016 Report Share Posted January 25, 2016 Rooster--Is one of those spotlights mine or did ya find a better matched pair? BTW--Love the Black and Burgundy and paint scheme...and I agree, those two noses are definite attention getters. No camper at present. Way too many farm machines to maintain. Link to comment Share on other sites More sharing options...
Broncohauler Posted January 25, 2016 Report Share Posted January 25, 2016 RB I'm sure understands when I say this. A lot of the desert crowd guys love to be the first one up the grades coming home. And I love to see them fly by me at the bottom of the hills just so I can turn around and Cruz back by with the truck hardly working while I hold up a cup of coffee. Can't image what they would do when both of you guys go cruising by there 500k diesel pushers and super dutys with those two super cool hand built trucks? Link to comment Share on other sites More sharing options...
grendel Posted January 25, 2016 Author Report Share Posted January 25, 2016 Well, with 650hp, I should be able to blow by just about anyone I want to Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 25, 2016 Report Share Posted January 25, 2016 Well, with 650hp, I should be able to blow by just about anyone I want to Yeah, nothing like pure brute power.....as long as it does not blow up.... I've been thinking of turning mine back up to 535hp......just because I can. I think I could go higher.....but not too much more with my radiator. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
RickS Posted January 25, 2016 Report Share Posted January 25, 2016 Jack......do you have a 20K or 23K rear axle? I know the engineers wouldn't let me have over 500HP even if I ordered the D16. So, D13-500/1850 it was. I did ask for the 600/2050 when ordering and they said something about ripping out the rear diff. Rick & Carey,Excel W41GKE Wild Cargo Toyhauler Volvo 730, D13, I-shift, 500/1850Brabus Smart Car Link to comment Share on other sites More sharing options...
noteven Posted January 26, 2016 Report Share Posted January 26, 2016 Hi RickS & Jack - When spec'ing class 8's the cooling will be verified by the factory for the max operating conditions - for example full GVWR pulling 8% or more grade at 100F down in the low gears of the trans... the higher the road speed the truck can maintain at full hp the lower the cooling load due to the ram air moving through the cooling package and engine bay... your trucks should handle RV trailer loads easy peasy because the cooling / HP will be matched to your door sticker GVWR... "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Scrap Posted January 26, 2016 Report Share Posted January 26, 2016 Jack's little U-Joint is going to be the thing that breaks first. I don't think I'd turn it up above 1650. Or maybe turn it back down before going to Colorado. Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 26, 2016 Report Share Posted January 26, 2016 Jack's little U-Joint is going to be the thing that breaks first. I don't think I'd turn it up above 1650. Or maybe turn it back down before going to Colorado. It's at 1850, and has been since the truck was built. HP from factory was 535, turned down to 515. I assume that did not affect the torque. 20K axle. I realize the U's are the weak link. This was a heavy haul config and I believe it has heavier U's in it. But I'm not positive of that. In any case, I keep a good eye on them - it makes me feel better. Not sure it does anything else, though. I don't really push the truck up the mountains. I generally let it stay in eco mode and don't kick it down. But I'll let you know when I am roadside in a mountain pass with no pulloff...... I'm sure you have been there. Coasting backwards to get off the road is always thrilling. For what it is worth Volvo engineering said I should have no real issue with the rear axle being slightly overloaded. They did not comment on my torque setting. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Scrap Posted January 26, 2016 Report Share Posted January 26, 2016 Its that last one at the back that went in that was too small, but you didn't have much of a choice two years ago as the right thing just wasn't made. We should revisit sometime soon with a new thread with your detailed specs as they keep talking about making 39 spline ones in the bigger sizes now with all the downspeeding. One might be out now. Or at the least there are 2 more years of guys on here that could re-machine one of the existing large ones for a little science project? Link to comment Share on other sites More sharing options...
noteven Posted January 26, 2016 Report Share Posted January 26, 2016 .. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
