Alie&Jim's Carrilite Posted July 23, 2015 Report Share Posted July 23, 2015 In the big truck world what is normally replaced in a front brake job? Pads, Drums, Cans, ??? I have no idea if the brakes on this truck have ever been rebuilt or changed. Over the last 2-3000 miles I've noticed a pull to the left under hard braking. Not pull you off the road, or uncontrollable, just a steady pull when braking hard. Under lite braking, it's not noticeable. Also, what is a normal price? I really don't want to be taken for looking or sounding green discussing the job with the shop. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted July 23, 2015 Report Share Posted July 23, 2015 When I had mine done, part of the problem was worn "S" cams. Basically I had everything from the hub seals out replaced. The drums were a big cost. There are cheap drums and there are better drums. Unfortunately when I was having this done, only the good drums were available. As I remember, the cost was about $3K. A few weeks later I talked to someone who have his F450 brakes replaces for over $2K. I didn't feel so bad then. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Randyretired Posted July 23, 2015 Report Share Posted July 23, 2015 Its been maybe 9 years ago but I think I remember Volvo charged a little less than $400 for front brakes and drums installed. Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Bob A Posted July 24, 2015 Report Share Posted July 24, 2015 First check brake stroke maybe one slack adjuster has failed causing one brake not to apply 2014 jayco siesmic 3914 1998 volvo 610, singled short ( bought in 2005) 14 speed volvo tranny 2014 Toyota yaris Link to comment Share on other sites More sharing options...
VegasFlyer Posted July 24, 2015 Report Share Posted July 24, 2015 Based on your question, I am going to ask a dumb question. Have you checked your brake condition and adjustment on all of your wheels? John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted July 24, 2015 Report Share Posted July 24, 2015 You may even have a wheel seal that's starting to weap. Link to comment Share on other sites More sharing options...
Broncohauler Posted July 24, 2015 Report Share Posted July 24, 2015 Just did brakes on drive axle. $67. For each drum I think it was $55 for the shoes. I traded out the labor. Keep in mind you will only do this one time. My truck used to be my work truck. A line haul truck running 80,000lbs both ways from sandiego Ca to Las Vegas and back. 1.5 million miles. We replaced the brakes one time on the front and 2 times on the drive axles. Compare that to a pickup truck. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 24, 2015 Author Report Share Posted July 24, 2015 In all the documentation that came with the truck there is no receipt for any brake work. Not saying it wasn't done, but to my knowledge the front is original. For $3-500, its piece of mind knowing I'll never touch them again, all the rubber parts maybe, but not the brakes themselves. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
cactus Posted July 24, 2015 Report Share Posted July 24, 2015 Just did brakes on drive axle. $67. For each drum I think it was $55 for the shoes. I traded out the labor. Keep in mind you will only do this one time. My truck used to be my work truck. A line haul truck running 80,000lbs both ways from sandiego Ca to Las Vegas and back. 1.5 million miles. We replaced the brakes one time on the front and 2 times on the drive axles. Compare that to a pickup truck. Broncohauler As a former "Fleet Control Manager" I would welcome you to drive for our fleet P.S. I still miss my 1973 Bronco Link to comment Share on other sites More sharing options...
Barncats Posted July 24, 2015 Report Share Posted July 24, 2015 Just did brakes on drive axle. $67. For each drum I think it was $55 for the shoes. I traded out the labor. Keep in mind you will only do this one time. My truck used to be my work truck. A line haul truck running 80,000lbs both ways from sandiego Ca to Las Vegas and back. 1.5 million miles. We replaced the brakes one time on the front and 2 times on the drive axles. Compare that to a pickup truck. You weren't hauling a company trailer by any chance were you? ? 2000 W900L KWSingled, C15 CAT 475 HP 18 sp, 3:36 rear, power locker,ET Hitch,,22.5 rubber 2011 Excel 36CFE Limited Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted July 24, 2015 Report Share Posted July 24, 2015 Yes......Wear out the trailer brakes. Link to comment Share on other sites More sharing options...
VegasFlyer Posted July 24, 2015 Report Share Posted July 24, 2015 Before you get serious about spending money changing out your brakes, what is the thickness of the existing brake linings? Your issue could be as simple as just needing to adjust your brakes. John Southern Nevada 2008 Volvo 780, D13, I-Shift 2017 Keystone Fuzion 420 Toyhauler 2017 Can-Am Maverick X3-RS Link to comment Share on other sites More sharing options...
Broncohauler Posted July 25, 2015 Report Share Posted July 25, 2015 You weren't hauling a company trailer by any chance were you? ? Yes and still do haul company trailers. And no I wasn't leaning on the trailer brakes or (broker handle) if you want to call it that. Just pay attention to the hills,use your Jake properly slowdown way ahead of time using Jake and downshifting for all stoplights. My other company truck I put 900,000 miles on it with one set of brakes replaced. That was a city tractor all city work. Link to comment Share on other sites More sharing options...
Broncohauler Posted July 25, 2015 Report Share Posted July 25, 2015 Broncohauler As a former "Fleet Control Manager" I would welcome you to drive for our fleet P.S. I still miss my 1973 Bronco Thank you I appreciate the comment but really don't think it's that big of a deal all our trucks seem to last that long. How can you sell a 1973 ford bronco? My kids are still fighting over who gets mine when I pass on along with my 69 Mustang that I learned how to drive in when I was 16yrs old. Link to comment Share on other sites More sharing options...
Dollytrolley Posted July 25, 2015 Report Share Posted July 25, 2015 I have twice seen a left-pulling-front-brake on a HDT with a rather odd cause......it starts with a power steering leak..... Here is what happened..........on one truck the High-Pressure power steering pump hose burst and flooded the top of the Left front axle leaf spring with power steering oil. The oil penetrated BETWEEN the leaf spring and the front axle mount. The friction-fit of the joint was compromised and the left-brake-force was only resisted by the small alignment dowl-pin from the leaf to axle mount block. I only takes one moderate brake application to shear the pin and now the "Lubed-axle-spring-joint becomes able to slide back thereby steering the axle into a left turn, once the service brake is released the axle slides forward helped by the good right spring /axle joint that has not been compromised. You might think that this is a rare event but I have seen it myself twice and have known truck mechanics that have also seen the problem as well. Might be worth a look........ Drive on.........(not pulling left.......) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 25, 2015 Author Report Share Posted July 25, 2015 Thanks DT, I'll look. As far as I know, there hasn't been a hose rupture, but it never hurts to look. Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
