Deezl Smoke Posted January 20, 2015 Report Share Posted January 20, 2015 Going thru the HH with a fine tooth comb as they say, I finally got around to turning on the third switch on the panel at the entry door. It slightly dims the other lights, but I can not figure out what it activates. It is not the water pump, nor the outside lights. I read the entire owners manual and it does not reference these switches anywhere. The first one, which is on, operates two lights just as you enter the coach. The middle one operates an outside yellow light. The third is what I wish to figure out. All three toggle on or off, not momentary. I took the multi tester around to all the outlets with the switch in the off position and they all have power, so that;s not it. What might this switch operate? Link to comment Share on other sites More sharing options...
GR "Scott" Cundiff Posted January 20, 2015 Report Share Posted January 20, 2015 On mine the mystery light was on the driver's side of the camper, above the water/sewer hookups. Link to comment Share on other sites More sharing options...
Big Greg Posted January 20, 2015 Report Share Posted January 20, 2015 Maybe an outside scare light on the other side of the 5W? If you don't get an answer here try the NuWa Owners Forum, post the year and model and an owner with the same unit will probably respond. Greg http://nuwaowners.org/ Link to comment Share on other sites More sharing options...
GR "Scott" Cundiff Posted January 20, 2015 Report Share Posted January 20, 2015 Maybe an outside scare light on the other side of the 5W? If you don't get an answer here try the NuWa Owners Forum, post the year and model and an owner with the same unit will probably respond. Greg http://nuwaowners.org/ And what am I, chopped liver? Link to comment Share on other sites More sharing options...
Ronbo Posted January 20, 2015 Report Share Posted January 20, 2015 Nobody trusts a retired preacher. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted January 20, 2015 Author Report Share Posted January 20, 2015 Does not appear to be a scare light. But I'll see if there is a light in the compartment. My HH is a 1990 year model 30' RK. Thanks. Link to comment Share on other sites More sharing options...
GR "Scott" Cundiff Posted January 20, 2015 Report Share Posted January 20, 2015 Does not appear to be a scare light. But I'll see if there is a light in the compartment. My HH is a 1990 year model 30' RK. Thanks. The owner's forum is a good suggestion - although I'm surprised it isn't the outside light on the driver's side. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 20, 2015 Report Share Posted January 20, 2015 I wish you would stop flipping that switch, every time you do my garage door opens and closes! Link to comment Share on other sites More sharing options...
Big Greg Posted January 20, 2015 Report Share Posted January 20, 2015 Nope, not chopped liver, I was writing my post as you posted yours. "Butcher" Greg Link to comment Share on other sites More sharing options...
GR "Scott" Cundiff Posted January 20, 2015 Report Share Posted January 20, 2015 Nope, not chopped liver, I was writing my post as you posted yours. "Butcher" Greg I guessed it was something like that. I couldn't help but laugh at the wording of your post right under mine. Once in awhile we'll be driving along and two or three people, one after another, will pull out in front of us - I always say, "I hate it when our cloaking mode gets turned on" - that's kind of what crossed my mind when your post about "if no one answers" came up right under my answer. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted January 20, 2015 Author Report Share Posted January 20, 2015 I wish you would stop flipping that switch, every time you do my garage door opens and closes! Ah,......that would explain it. Link to comment Share on other sites More sharing options...
Just Don Posted January 29, 2015 Report Share Posted January 29, 2015 I wish you would stop flipping that switch, every time you do my garage door opens and closes! That was a good one. Link to comment Share on other sites More sharing options...
duallyman Posted March 6, 2015 Report Share Posted March 6, 2015 Maybe a outside light by the steps.. I have one and unless your looking right at it you would never know its there. Link to comment Share on other sites More sharing options...
Jimalberta Posted March 6, 2015 Report Share Posted March 6, 2015 Any chance it is bringing on lights in your awning? Link to comment Share on other sites More sharing options...
rockintom Posted March 6, 2015 Report Share Posted March 6, 2015 Maybe a outside light by the steps.. I have one and unless your looking right at it you would never know its there. X2 only shows at night......or maybe the bulb is burned out on it. rockin' Link to comment Share on other sites More sharing options...
Just Don Posted March 7, 2015 Report Share Posted March 7, 2015 Deezl Smoke did you figure out what it was and did you go join the NUWA forum.. Going thru the HH with a fine tooth comb as they say, I finally got around to turning on the third switch on the panel at the entry door. It slightly dims the other lights, but I can not figure out what it activates. It is not the water pump, nor the outside lights. I read the entire owners manual and it does not reference these switches anywhere. The first one, which is on, operates two lights just as you enter the coach. The middle one operates an outside yellow light. The third is what I wish to figure out. All three toggle on or off, not momentary. I took the multi tester around to all the outlets with the switch in the off position and they all have power, so that;s not it. What might this switch operate? Link to comment Share on other sites More sharing options...
RV_ Posted March 7, 2015 Report Share Posted March 7, 2015 Deezl, We had the same year HH for our first rig and both of us remember that three switch box at the door. Take the box off and see if the third switch has any wires that come from it. We can't remember what the switch turned out to be or not. But we did have a second scare light in the back or driver side of the rig. There are pics of that rig on our website. Sorry both of us are drawing a blank. Link to comment Share on other sites More sharing options...
Deezl Smoke Posted March 11, 2015 Author Report Share Posted March 11, 2015 I did find out. It was a light on the drivers side that was intermittent in operation. A yellow light just like by the entry door. But had a bad bulb or something. I have sold the trailer now though. Thanks. Link to comment Share on other sites More sharing options...
