Broncohauler Posted February 24, 2020 Report Share Posted February 24, 2020 Wired in a couple battery jumper posts so now I don’t need to remove the battery box cover to hookup a battery tender or for jump starting. So far real happy just need a higher out put tender. One thing I did notice though is that for some reason both the main ground cable and positive to the starter are coming from the same battery?? I would think the negative wire be at the last battery of three in the battery bank? Quote Link to comment Share on other sites More sharing options...
rickeieio Posted February 24, 2020 Report Share Posted February 24, 2020 I would agree, though I'm no 'lectric whiz. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
DJohns Posted February 24, 2020 Report Share Posted February 24, 2020 I think you opened up a can of worms! I have the same battery tender you have. I move it from one battery to the next when charging. Some say charge all the batteries at once some say one battery at a time. This will be fun to watch the engineers on this on. Quote 2002 Beaver Marquis Emerald C-12 Cat 505 HP 2014 Volvo 630 D-13 I Shift SOLD 2017 New Horizons SOLD Link to comment Share on other sites More sharing options...
RayJay Posted February 24, 2020 Report Share Posted February 24, 2020 If the batteries are connected in parallel, connect the charger to any one battery, it will charge all, only at a slower rate. Quote -- Ray & Wendy Full time wanna be - finally! 2014 Entegra Anthem 42RBQ 2018 Jeep Wrangler JLU Link to comment Share on other sites More sharing options...
Imurphy907 Posted February 24, 2020 Report Share Posted February 24, 2020 (edited) The Battery cables should be on different batteries. The + on the front battery and the - on the back or vise versa. What you are looking to do is have all the batteries be the same electrical path length so they share the load equally. Having both connections on one battery puts that one under more load since its the shortest electrical path. This is more important under high loads like turning over a cold 14 liter diesel. Where I come from in the Telco world this type of thing is even written into our codes. And as far as charging with a small charger it does not really matter. Even if hooked to one battery they are all connected together. I usually do the same with my charger as the main leads thou. offset them end to end. but again a lot of that is just habit. Edited February 24, 2020 by Imurphy907 Quote 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
noteven Posted February 24, 2020 Report Share Posted February 24, 2020 (edited) I was learned to treat batteries connected in sets as one battery re: charging / maintaining etc. I also saw an article I can’t find with a diagram of how to connect multiple batteries and the science behind the recommendations. It kind of showed poles connected together and load connected each at opposite ends of the batteries...kinda factory Kenworth style... Edited February 24, 2020 by noteven Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted February 25, 2020 Report Share Posted February 25, 2020 The engineers know how to build it, properly. The accountants know how to make money off of it. The marketers know how to sell it at a set profit margin. Guess who won the 3 way tug-of-war when it came time to spec the battery cables. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
noteven Posted February 25, 2020 Report Share Posted February 25, 2020 A first drive in a Mack with a Triplex compound transmission is a humbling thing. Many “busy signals”. now back to the thread subject... Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Big5er Posted February 26, 2020 Report Share Posted February 26, 2020 (edited) Dumb question: Why don't you just mount your charger and hardwire it to the battery posts, just like the starter should be, positive on one battery and negative at the other end? That is a much better connection than those clamps to a battery post. As far as a charger/maintainer I use a Noco Genius G26000 Edited February 26, 2020 by Big5er Quote MY PEOPLE SKILLS ARE JUST FINE.~It's my tolerance to idiots that needs work.~ 2005 Volvo 780 VED12 465hp / Freedomline transmission singled mid position / Bed by Larry Herrin2018 customed Mobile Suites 40KSSB3 2014 smart Fortwo Link to comment Share on other sites More sharing options...
Broncohauler Posted February 29, 2020 Author Report Share Posted February 29, 2020 On 2/25/2020 at 5:47 PM, Big5er said: Dumb question: Why don't you just mount your charger and hardwire it to the battery posts, just like the starter should be, positive on one battery and negative at the other end? That is a much better connection than those clamps to a battery post. As far as a charger/maintainer I use a Noco Genius G26000 Not a dumb question at all Phil. This charger is actually temporary until I get one specifically for the truck. When I decide what charger I want, I’ll hard wire and mount it in the battery box. the posts are more for emergency jump starting without taking off the battery box cover. Quote Link to comment Share on other sites More sharing options...
Steve from SoCal Posted February 29, 2020 Report Share Posted February 29, 2020 I have an Anderson plug in the left saddle box on my truck. With jumper cables and a charging harness. In my truck it is imperative I have a remote battery connection, my batteries are behind my fifth wheel under the deck. The chargers I have would drain the batteries IF left connected and unplugged. Steve Quote 2005 Peterbilt 387-112 Baby Cat 9 speed U-shift 1996/2016 remod Teton Royal Atlanta 1996 Kentucky 48 single drop stacker garage project Pulls like a train, sounds like a plane....faster than a Cheetah sniffin cocaine. Link to comment Share on other sites More sharing options...
