freightliner transmission issue
maverick_935
Desert Miner had some good advice for you. You should get a code telling you what the tranny computer thinks is wrong. My 2006 Ultrashift would not go into gear due to a bad input shaft speed sensor.
  Charlie
Don't ever tell a soldier that he doesn't understand the cost of war.
i have one that had some issues, first thing I would do is to clean all of your battery cables, check the wiring and fuses from your batteries to the transmission, I had corroded wire connections in these wires, i repaired them and my problems went away
2004 Volvo VNL 780
2017 Momentum 376TH
2007 Harley Davidson FLHTC
2009 Smart4two
I had some Ultrashift issues that were resolved after cleaning and regreasing with dielectric grease the connections at the transmission.
2006 Volvo VNL 780, " Arvey"  Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift
2003 Jeep Wrangler Rubicon
2010 Forest River Coachman Freedom Express 280RLS
Jackalopee
The Ultrashift is made by Eaton. The OP said he has a Meritor which is the Freedomline.
There is some confusion somewhere :wacko:
2014 smart Fortwo
Phil he also said it was a 10 speed and I don’t think a 10 speed Freedomline exists.  I think the OP needs to go to his door jam and tell us what the plate says he has.  I know the common problem with the Freedomline is the doubler and you have a source for that.
Nigel
2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30'
  • 1 month later...
I have one just like that. The execution is tomorrow at dawn...
Paul & Paula + Daisy the amazing wiggle worm dog...
2001 Volvo 770 Autoshift, Singled, w/ Aluminum Bed - Toy Draggin
2013 395AMP XLR Thunderbolt Toy Hauler
2013 Smart Passion
2012 CanAm Spyder RT
2013 Harley Davidson Street Glide
