Can someone tell if I block their number?
Excerpt:
"If you find yourself in the awkward position of having to block someone else's number, you may have wondered what happens next. We'll walk you through the ways someone may be able to tell if their number was blocked.
Most of us have gotten those calls: "Your car's warranty is about to expire...", whether we have a car or not. Aside from going to DoNotCall.gov or calling 1-888-382-1222 to be added to a do-not-call list, you can also block specific phone numbers from your phone.
But what if you need to block someone you know, like a coworker, a neighbor, or an old flame? Can they tell you've blocked them? We'll walk you through the ways someone may be able to tell if their number was blocked.
First things first, if you block someone's number, they won't find out right away, if at all. They won't get a notification saying they were blocked and won't be able to see it plainly anywhere, but they can infer it. There are ways a person can figure out if they were likely blocked, like sending you texts and calling you.
1. Sending you a text
If you and the other person you blocked both use iPhones, your text message exchange is through iMessage, so they show up in blue.
This text is delivered as an iMessage so it comes up in blue and says Delivered, which means your number isn't blocked
Image: Maria Diaz / ZDNet
If they weren't blocked and decided to send you a text message, it'd come up as Delivered.
The signs are in the colors
After blocking my number on the other phone, the message was delivered as a text instead of an iMessage
If the sent text message looks green instead, it means it was sent as an SMS instead of iMessage. They may also see Not Delivered in red under the green text bubble or the message may go through as an iMessage and just not show if it was Delivered. These can all be clues that they may have been blocked by the other person.
Review: Apple iPhone SE (2022): You simply can't find a better phone at this price
However, iMessages can show up in green or not show as Delivered when someone's phone is off or if they don't have a signal or internet connection at the time. So the other party may assume that's the case before realizing they were blocked.
2. If the blocked number calls yours
When someone thinks they're blocked, it's all about putting the pieces together to determine if the other person has in fact blocked their number. If you call someone that hasn't blocked your number, you typically hear several rings before it goes to voicemail.
When you call a number that has blocked yours, you may hear one or half a ring or no rings at all and then the call will go to voicemail. If it goes straight to voicemail, their phone may also be off or out of range, or they may have temporarily turned on Do Not Disturb mode to work, drive, or sleep.
If the person you blocked calls your number, they'll go to voicemail and can leave a message, but you won't get a missed call or voicemail notification.
If the "Someone" you blocked calls your number, they'll probably go straight to voicemail
3. They may hide their number
If the blocked party's messages are delivered as text when they used to be iMessages and their calls go straight to voicemail consistently, they may try calling you from a different number or hiding their number. They can hide their number by dialing *67 before your phone number and the call will come in as No Caller ID.
If the blocked caller gets through from a different number or by hiding their number, then they'll probably be pretty certain you have blocked them.
star-67
Dialing *67 + phone number. So, *67(XXX)-XXX-XXXX, shows up as No Caller ID on the other phone
For my peace of mind, I wouldn't answer No Caller ID calls after blocking someone, unless I was expecting a very important call.
Also: How to find and remove spyware from your phone
If you're the one that was blocked, keep in mind that though no one wants to find themselves being blocked by another person, especially if it's someone you care about, the best thing to do is to allow that person the privacy and time to process their needs for doing so.
Incoming call with no caller ID a hidden phone number using *67
FAQs
Can someone tell if I block their number on Android?
Android is not as straightforward as iPhone when trying to figure out if someone blocked you. Since there is no iMessage in Android, it's a little trickier to determine. Some phones offer read and delivered receipts, so if that's the case for yours and the blocked person's phone and they're not seeing the receipts, they may try doing some digging. "
More and a video in the article here:
https://www.zdnet.com/article/can-someone-tell-if-i-block-their-number/
46 minutes ago, 2gypsies said:
Wow!  I guess I don't care if they know it or not because I blocked them which means that I don't want to hear from them.  😁
Same here. In fact that is a message I would want to send too.
I posted because I had no idea iPhones let folks know in any event. Makes it tough to get away from spam calls if they know to change the numbers. Some do that anyway spoofing numbers.
14 hours ago, durangodon said:
I have iPhone and don't use iMessage.  Lot's of people don't, so that is not a hard and fast rule.
Well for those that do use iMessage now they "iKnow!" ;)
  • 2 months later...
I found this information really helpful. I often feel like I'm in a difficult situation when I need to block a number and I'm not sure what to do. So I'm glad to know that the other person won't be able to tell right away and that it's not so obvious. Understanding the process can help us make more informed decisions. In return, I'd like to share the following- if you're looking for an extra layer of security and privacy when it comes to your personal number, you might want to consider using a temporary number usa. Temporary numbers allow you to keep your personal information confidential and avoid spam calls and texts to your personal number. They're a great way to protect your privacy and your personal information.
Edited by AlexanderFranc
Alexander,
YW glad you found it useful too.
 Share
