mike5511 Posted December 1, 2022 Report Share Posted December 1, 2022 The LCD readout does not work. I've had the rest of the dash re-soldered and everything works, but this didn't come to life. Finding a new one to replace it has proved impossible. I don't want to spring for a whole new dash board. This hasn't worked since I've had the truck so I haven't missed it. But, I would like to have/know what information I could learn from it. Does anybody know where to find a used one maybe, or some other work around? Maybe a tablet set up? This truck has a Cummins M11. It has a pretty complete set of gauges......except for a volt gauge. I'm guessing if the truck throws a code, this is where it would show up. I'm open to any ideas. Quote Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted December 1, 2022 Report Share Posted December 1, 2022 When mine was not working I found it was burned out light bulbs that were not easy to find and replace. Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted December 1, 2022 Report Share Posted December 1, 2022 A ScanGauge KR will effectively give you much of the information normally found in the driver's information display. There are also tablet/software solutions, but the name escapes me at the moment. Jay Quote Link to comment Share on other sites More sharing options...
mike5511 Posted December 1, 2022 Author Report Share Posted December 1, 2022 5 hours ago, Mark and Dale Bruss said: When mine was not working I found it was burned out light bulbs that were not easy to find and replace. The place I sent it off to replaced light bulbs and did some re-soldering. The back light illuminates, but the panel is dead. Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted December 1, 2022 Report Share Posted December 1, 2022 (edited) 11 minutes ago, mike5511 said: The place I sent it off to replaced light bulbs and did some re-soldering. The back light illuminates, but the panel is dead. I would also check the wiring harness behind the display. The contacts can get weak and sloppy with time. Can you swap it with a known good one to check the harness? Jay Edited December 1, 2022 by Jaydrvr Quote Link to comment Share on other sites More sharing options...
mike5511 Posted December 1, 2022 Author Report Share Posted December 1, 2022 36 minutes ago, Jaydrvr said: I would also check the wiring harness behind the display. The contacts can get weak and sloppy with time. Can you swap it with a known good one to check the harness? Jay I do not have a good to check with. They re-soldered all the pins when I had the dash re-done. They said most of the time that was the issue but not always. They told me the LCD panel was apparently dead. Quote Link to comment Share on other sites More sharing options...
mike5511 Posted December 1, 2022 Author Report Share Posted December 1, 2022 (edited) 49 minutes ago, Jaydrvr said: A ScanGauge KR will effectively give you much of the information normally found in the driver's information display. There are also tablet/software solutions, but the name escapes me at the moment. Jay Since my gauges all work, I'm thinking of just adding the volt gauge, which it lacks, and maybe by a scan tool that will read any codes should I need to. This truck also has the Road Relay which works. Basically just a trip/leg meter, but does give your oil pressure and temp. Edited December 1, 2022 by mike5511 Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted December 1, 2022 Report Share Posted December 1, 2022 (edited) 2 hours ago, mike5511 said: Since my gauges all work, I'm thinking of just adding the volt gauge, which it lacks, and maybe by a scan tool that will read any codes should I need to. This truck also has the Road Relay which works. Basically just a trip/leg meter, but does give your oil pressure and temp. Sounds good. Here is a link to the ScanGauge KR, if you decide to use it. They ScanGauge will give you fault codes, which I think is already worth the price of admission. Jay https://www.google.com/aclk?sa=l&ai=DChcSEwjJpKOzotn7AhVOyYYKHTq1DlkYABAHGgJ2dQ&sig=AOD64_0VH79VtgdrfIfmWQS96gkW_FMv2w&ctype=5&ved=2ahUKEwiN-pqzotn7AhWuSjABHeYcCWQQwg8oAHoECAwQBg&adurl= Edited December 1, 2022 by Jaydrvr Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted December 1, 2022 Report Share Posted December 1, 2022 If you have a working Road Relay, you're gold. It will also pull any fault codes for you. They're usually paperweight candidates, and an aftermarket reader like ScanGauge is needed. We use a "D" model on one of the farm trucks, to keep track of the blinky CEL. Quote Link to comment Share on other sites More sharing options...
mike5511 Posted December 2, 2022 Author Report Share Posted December 2, 2022 8 hours ago, Jaydrvr said: Sounds good. Here is a link to the ScanGauge KR, if you decide to use it. They ScanGauge will give you fault codes, which I think is already worth the price of admission. Jay https://www.google.com/aclk?sa=l&ai=DChcSEwjJpKOzotn7AhVOyYYKHTq1DlkYABAHGgJ2dQ&sig=AOD64_0VH79VtgdrfIfmWQS96gkW_FMv2w&ctype=5&ved=2ahUKEwiN-pqzotn7AhWuSjABHeYcCWQQwg8oAHoECAwQBg&adurl= Thanks for the link! Quote Link to comment Share on other sites More sharing options...
mike5511 Posted December 2, 2022 Author Report Share Posted December 2, 2022 (edited) 7 hours ago, Darryl&Rita said: If you have a working Road Relay, you're gold. It will also pull any fault codes for you. They're usually paperweight candidates, and an aftermarket reader like ScanGauge is needed. We use a "D" model on one of the farm trucks, to keep track of the blinky CEL. I'll have to look at it closer and figure out how to use it. I just use the trip odometer and the fuel average fuel mileage function now. Occasionally check the oil temp and pressure, but the truck as a oil pressure gauge. I'll probably just put some aftermarket volt meter on it. There is no space in the cluster to put it. I figured the LCD panel showed the battery volts. Can't imagine the truck not having someplace to monitor the volts when it was new. Â Edited December 2, 2022 by mike5511 Quote Link to comment Share on other sites More sharing options...
ARGO Posted December 2, 2022 Report Share Posted December 2, 2022 I put a small square LED in the upper left corner of the dash panel. Can be seen from the ground, too. I have some dash parts left over from mine, switches etc. PM me if needed. Quote Link to comment Share on other sites More sharing options...
Darryl&Rita Posted December 2, 2022 Report Share Posted December 2, 2022 10 hours ago, mike5511 said: I'll have to look at it closer and figure out how to use it. I just use the trip odometer and the fuel average fuel mileage function now. Occasionally check the oil temp and pressure, but the truck as a oil pressure gauge. I'll probably just put some aftermarket volt meter on it. There is no space in the cluster to put it. I figured the LCD panel showed the battery volts. Can't imagine the truck not having someplace to monitor the volts when it was new. Â Start here:RoadRelay manual Quote Link to comment Share on other sites More sharing options...
mike5511 Posted December 14, 2022 Author Report Share Posted December 14, 2022 On 12/2/2022 at 9:23 AM, Darryl&Rita said: Start here:RoadRelay manual Mine is not the one in the link. I guess it is an older model. I've been thru all the menus and haven't seen anything about codes in it. It's function are pretty basic. Quote Link to comment Share on other sites More sharing options...
