runaway parents Posted November 13, 2022 Report Share Posted November 13, 2022 (edited) Well I screwed up used a pressure washer on the passenger mirror peeled a bunch of the Chrome off of it not good how hard is it to remove mirror cover and replace it any advice Edited November 13, 2022 by runaway parents Quote Link to comment Share on other sites More sharing options...
Sculptor Posted November 13, 2022 Report Share Posted November 13, 2022 I think there is a YouTube video on this. Or something close? I’ll see if I can find it. Your photo looks like a gen 2 Volvo right? Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
rickeieio Posted November 13, 2022 Report Share Posted November 13, 2022 This was discussed at length several years ago. A search may reveal answers, or perhaps someone with a better memory will remember the procedure. I think it involved tipping the glass to the extremes to access the screws inside the housing. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted November 13, 2022 Report Share Posted November 13, 2022 Check you tube. The mirror parts has to be removed to get to the clips that hold the back in place. As I recall each mirror just has to be slid up to get out of the fasteners and they will come right out. Then you can access the 4 clips that hold the back on. Quote Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
Sculptor Posted November 13, 2022 Report Share Posted November 13, 2022 (edited) This one isn’t bad for the disassembly. It covers disassembly in the first half or so. I would advise the same as Brad, take the mirror glass off first, then proceed with the housing. https://youtu.be/FJzQI3Tb5gY Another video details the mirror glass removal for an antenna repair. Tilt each mirror up/forward as far as possible. One at a time. Apply GENTLE pressure up with some GENTLE tapping up at the lower edge, just until the glass is up and loose. Then tilt the glass down all the way. Then slide the glass up and off it’s mount. This should help to be able to access the rest of the mounting screws. Hope this helps. Edited November 13, 2022 by Sculptor Quote Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
lappir Posted November 13, 2022 Report Share Posted November 13, 2022 I had one done in a shop in Lawton, OK. Mechanic said it was an easy fix, turned out to be more. I just had the black backing, but it was broke and rattling. I wasn't upset with the overall cost of all the repairs done, but cannot remember the split out for the mirror work. Rod Quote White 2000/2010Volvo VNL 770 with 7' Drom box with opposing doors, JOST slider hitch. 600 HP Cummins Signature 18 Speed three pedal auto shift. 1999 Isuzu VehiCross retired to a sticks and bricks garage. Brought out of storage the summer of 2022 2022 Jeep Wrangler Sport S Two door hard top. 2007 Honda GL 1800 2013 Space Craft Mfg S420 Custom built Toyhauler The Gold Volvo is still running and being emptied in July. Link to comment Share on other sites More sharing options...
runaway parents Posted November 13, 2022 Author Report Share Posted November 13, 2022 53 minutes ago, Sculptor said: This one isn’t bad for the disassembly. It covers disassembly in the first half or so. I would advise the same as Brad, take the mirror glass off first, then proceed with the housing. https://youtu.be/FJzQI3Tb5gY Another video details the mirror glass removal for an antenna repair. Tilt each mirror up/forward as far as possible. One at a time. Apply GENTLE pressure up with some GENTLE tapping up at the lower edge, just until the glass is up and loose. Then tilt the glass down all the way. Then slide the glass up and off it’s mount. This should help to be able to access the rest of the mounting screws. Hope this helps. Got it don't look too complicated I've had worse projects thanks guys Quote Link to comment Share on other sites More sharing options...
