Volvo Auxiliary Switch connection point
DG N. AL
My 2012 Volvo VNL 630 has 3 auxiliary switches on the dash.  Can anyone tell me where the connection point for those switches is at.  I can't find anything behind the dash.  I have a couple of things I want to control with those switches.
So idk what your switch connections look like.  IF you have loose wires, maybe you can use them.  You said you can’t find any connection points, so there are no wires in the vicinity of the aux switches, or no loose unused connections anywhere behind the dash?
I found one or 2 of these were live when the key is on.  One was connected to The 12 volt outlet, one was live, one was dead.  I took a photo of these connectors but it was two or three years ago.  I wanted to find a matching connector for some reason.  Might have been because some are live and usable.
Kevin and June
2014 DRV 36TKSB3
After further investigation, I found connectors like you have pictured that went to the aux switches.  But all of these connectors were full.  The wires are labeled with "Pin" numbers (Pin 181, Pin 208, etc.)  I don't know where these wires go and they are impossible to trace.  One of the aux switches is in use (lights and a camera power).  As far as I can tell, the other 2 aux switches don't appear to control any thing.  I suspect they terminate at empty connectors some where on the frame as part of the "body builders" provisions.  The few online schematics I have have found are very vague.
  • 3 weeks later...
Just a follow up.  After asking 3 Volvo techs one finally showed me where the dash "Auxiliary Switch" wiring terminates.  There are 3 single pole Metripak 280 series plugs on the firewall under the steering column.  These are your connection points for the 3 "Aux" switches that are on the dash.
Thank you for this.  I will have to check that out on mine.  I have 1 Aux switch installed.  I have no idea what it is connected to, if anything.  I did find the switch connectors in the date for Aux 2 and 3, but not where they came out either.
2014 Volvo 630. 2016 Fuzion 325T, RZR 900 Trail
675ah AGM, MSH 3012 inverter, 960w Solar.  (2016 Chevy 3500 DRW, backup)
