chiefneon Posted April 6, 2019 Report Share Posted April 6, 2019 Howdy! I recently purchased a new TV a 3500 Chevrolet HD/LTZ/DRW 2L Custom Hauler. Yesterday I was preparing for our trip and checking all the tires for air pressure and going to install my PresurePro TPMS on the new truck. To my surprise the two front tire had medal value stems, but the rear duels had rubber value stems. I took the truck into Premier Tires in Livingston, TX to have the rear value stems replaced with metal value stems and was told that they could replace the inter duel stems but not the outer tires value stems. They stated they could not replace them because the stem area was to small to get a socket wrench into the area the tighten the steam. I don’t want to run the TPMS in a rubber steam. I don’t think I can even if I tried because the stem is so short I don’t think it will screw on to the rubber stems. The tire store recommended that a dealership may have a metal tire stem for the rims. Has anyone had this type of problem, or have any suggestions I would appreciate the help. ” Happy Trails “ Chiefneon "Class of 2007 Fulltimer's" Gary & karen Smoochie & Michaela (fur babies) 2018 Chevorlet 3500 HD/LTZ 2L Custom Hauler 2014 Heartland Cyclone 4000 2016 Smart Car Prime Link to comment Share on other sites More sharing options...
D&J Posted April 6, 2019 Report Share Posted April 6, 2019 Go somewhere else. Denny Denny & Jami SKP#90175 Most Timing with Mac our Scottie, RIP Jasper our Westie 2013 F350 SC DRW 6.2 V8 4.30 Gears 2003 HH Premier 35FKTG Home Base Nebraska Link to comment Share on other sites More sharing options...
DesertMiner Posted April 6, 2019 Report Share Posted April 6, 2019 Call 2L they might have some info..... Link to comment Share on other sites More sharing options...
Ray,IN Posted April 7, 2019 Report Share Posted April 7, 2019 Any large automotive store will have metal stems, be sure to buy the shape you need for access if you plan to rotate tires. I had 2" straight metal stems in my dually. The TST 507 transmitters fit just right on my truck,(2" stems-2" flow-through transmitters) whether I rotated tires or not. Be sure to place stems 180° apart to make access easier. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
chiefneon Posted April 8, 2019 Author Report Share Posted April 8, 2019 Howdy! Thanks for the replies. I took the truck into Discount Tires in Livingston this morning and they had no problems installing metal valve stems on the outer rear duel wheels. ” Happy Trails “ Chiefneon "Class of 2007 Fulltimer's" Gary & karen Smoochie & Michaela (fur babies) 2018 Chevorlet 3500 HD/LTZ 2L Custom Hauler 2014 Heartland Cyclone 4000 2016 Smart Car Prime Link to comment Share on other sites More sharing options...
bobsallyh Posted April 9, 2019 Report Share Posted April 9, 2019 chief, hopefully Discount Tire situated the valves at the proper location. I use Discount all the time but several of their shops have no idea about the valve spacing on dualies. Link to comment Share on other sites More sharing options...
