Cotreker Posted January 25, 2019 Report Share Posted January 25, 2019 My problem was that when attempting to open the passenger door the handle moved up but was not connected to the rod any longer. For those that have this issue or run into the issue the fix will cost you $14.00 from Volvo. My dealer sells about 100 of these plastic attachment parts per month. When I went to the counter with my broken part the parts person did not even need to look up the part number he just laughed. Since I have had the door panel off previously to replace the speakers that part went pretty fast. My connecting rod also came off the top ball attachment. This is well hiden behind the electric door opener. Remove the rail screws (2) and the (3) screws that hold the opener and you have easy access. Pray open the pin side of the plastic connector to remove and carefully do reverse on new one. Snap together the plastic connector and put on at least one tie wrap, ok use two. Volvo sells these for $5 each, no I did not purchase one. Longer term fix which I will do on the drivers door when it fails or maybe do this summer. Reinforce the plastic Volvo part with JB Weld epoxy. These fail, so I am told when the handle is pulled on too hard over and over. The heat and cold do not help this type of plastic either. What can be really expensive is if both fail at the same time and you cannot get into your truck, don't let this happen. Small picture attached. New news to me could be old news to many of you. Dennis Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Cotreker Posted January 25, 2019 Author Report Share Posted January 25, 2019 My picture resolution was poor, second attempt from Jack's hints. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Chad Heiser Posted January 25, 2019 Report Share Posted January 25, 2019 Glad you got this all fixed up. Hopefully you are getting the truck ready to go for the WCR in June. Are you going to make it again this year? 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Cotreker Posted January 25, 2019 Author Report Share Posted January 25, 2019 Hello Chad, Looking forward the WCR in June. Working on a solar project, might need to pick your brain soon please. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Chad Heiser Posted January 25, 2019 Report Share Posted January 25, 2019 2 hours ago, Cotreker said: Hello Chad, Looking forward the WCR in June. Working on a solar project, might need to pick your brain soon please. No problem, just let me know. 2000 Kenworth T2000 w/ Cummins N14 and autoshift 2017 DRV Mobile Suite 40KSSB4 with factory mods, dealer mods and personal mods - now in the RV graveyard 2022 DRV Full House MX450 with customized floor plan 2018 Polaris RZR Turbo S (fits in the garage) 2016 Smart Car (fits in the garage or gets flat towed behind the DRV when the RZR is in the garage)My First Solar Install ThreadMy Second Solar Install Thread & Photos and Documents Related to the buildMy MX450's solar, battery and inverter system - my biggest system yet! chadheiser.com West Coast HDT Rally Website Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 25, 2019 Report Share Posted January 25, 2019 Do you have a part number for that plastic part? I'm in need of one as well. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted January 25, 2019 Report Share Posted January 25, 2019 1 hour ago, Alie&Jim's Carrilite said: Do you have a part number for that plastic part? I'm in need of one as well. Jim I have one I ment to give you. Might b able to hookup on my way home in 2 weeks. Roger Link to comment Share on other sites More sharing options...
Cotreker Posted January 25, 2019 Author Report Share Posted January 25, 2019 8143976 Description: Rod $13.67 If anyone needs one installed at WCR i will assist, get the part. Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Parrformance Posted January 25, 2019 Report Share Posted January 25, 2019 59 minutes ago, Cotreker said: 8143976 Description: Rod $13.67 If anyone needs one installed at WCR i will assist, get the part. https://class8truckparts.com/volvo-truck-rod-8143976.html Part availability https://www.google.com/search?q=8143976&safe=strict&rlz=1C1EJFA_enUS784US784&tbm=isch&source=iu&ictx=1&fir=YOhqb3AxDOR3UM%3A%2C93eS6oXsL9POoM%2C_&usg=AI4_-kS1gpv6JjgXtpFTvzncSy-ax2mloQ&sa=X&ved=2ahUKEwi_zMSb4YngAhVJ1oMKHV4PAA8Q9QEwAXoECAYQBg&cshid=1548447817027947#imgrc=YOhqb3AxDOR3UM: 2006 Volvo VNL 780, " Arvey" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift 2003 Jeep Wrangler Rubicon 2010 Forest River Coachman Freedom Express 280RLS Jackalopee Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted January 26, 2019 Report Share Posted January 26, 2019 5 hours ago, Hewhoknowslittle said: Jim I have one I ment to give you. Might b able to hookup on my way home in 2 weeks. Roger I'll send you an address. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted January 26, 2019 Report Share Posted January 26, 2019 6 minutes ago, Alie&Jim's Carrilite said: I'll send you an address. 👍 Link to comment Share on other sites More sharing options...
