Alie&Jim's Carrilite Posted November 3, 2018 Report Share Posted November 3, 2018 2 hours ago, dan412 said: I layed the wire out next to the ditch and the conduit slid one piece of pipe over the wire at a time then glued until I had all together then put the whole works in the ditch. The insulation is usually PVC based. I did the same as this but wrapped the cables in duct tape at the conduit connections. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 3, 2018 Report Share Posted November 3, 2018 It pulls through the straight sections pretty easily. In fact if you layout the wire you can walk several glued sections down the wire and then walk the sweep and only have to glue the sweep in. if you only put the glue on the male portion of the joint you should not have to worry. Link to comment Share on other sites More sharing options...
Ronbo Posted November 3, 2018 Report Share Posted November 3, 2018 I have pulled 3 strands of 250mcm about 150 ft. Used an excavator attached to the rope. Just don’t break the rope. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Imurphy907 Posted November 5, 2018 Report Share Posted November 5, 2018 thhn nore xhhn will do. For buried or buried on conduit you want RHH/RHW-2/USE. This is specific service entrance wire designed to be placed in conduit or buried. Do not use THHN or XHHN. 2016 Road Warrior 420 2001 Volvo VNL 660 Alaska Based. Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 5, 2018 Report Share Posted November 5, 2018 On 11/3/2018 at 5:13 AM, Chad Heiser said: When I built my shop, I pulled four 2 gauge wires (stranded copper) through 120 feet of conduit with four 90 degree sweeps in the conduit (1 vertical at the supply side, 2 horizontal under ground and another vertical at the load side). I used 3 inch conduit and it was a difficult pull. I don't think I could have pulled the size wire you are looking at through the same conduit. I wish you the best of luck. Chad has it nailed. You are going to have an incredibly difficult time with that pull. I've done a similar pull and we had to dig up one of the bends. Even then it was difficult. But I'm not saying it is impossible....only hard. The other advice - to size the neutral the same - is sound advice. There are things that are "allowed" in the code that are not necessarily the best way to do things. Size the neutral the same. BTW, for others and future reference. You cannot have too big a conduit. I never put in less than 3" EVER. There is a cost difference, but you will be glad you paid that bill. I know it is a moot point in this case....but for others..... Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
ARGO Posted November 5, 2018 Report Share Posted November 5, 2018 OK, I am not NEAR as qualified as you guys on AC current. But I AM cheap. I ran a 30A line about 150 ft house to dock straight pull. Bought a spool (500ft) of copper stranded and cut it in 3 pcs, color coded the ends & pulled it all 3 pcs together. Cheaper than buying 3 conductor wire pre made. You'd have to see the movie to understand.......... Link to comment Share on other sites More sharing options...
dennisvr Posted November 10, 2018 Author Report Share Posted November 10, 2018 Success on pulling the wires yesterday. I built a tripod arraignment with a pulley and bolted a 2500lb winch to the bottom. I dumped a quart of lube down the conduit and had a guy lubing and feeding the line as I worked the winch. I used a flat tape like pull cord rated at 2500lb and spooled it onto the winch. It was a really good feeling when the wire came out of the other end of the conduit. So now I need to install all the breakers, plugs and switches and I'll be set. "It is better to have more truck than you need than to need more truck than you have" 2001 Volvo 660, Cummins 400 ISX, Eaton 3 Peddle Auto Shift 2014 Fuzion 40' Toyhauler 2015 Smart Car Link to comment Share on other sites More sharing options...
Lance A Lott Posted November 10, 2018 Report Share Posted November 10, 2018 1 hour ago, dennisvr said: Success on pulling the wires yesterday. I built a tripod arraignment with a pulley and bolted a 2500lb winch to the bottom. I dumped a quart of lube down the conduit and had a guy lubing and feeding the line as I worked the winch. I used a flat tape like pull cord rated at 2500lb and spooled it onto the winch. It was a really good feeling when the wire came out of the other end of the conduit. So now I need to install all the breakers, plugs and switches and I'll be set. Wonderful news. So what wire did you end up going with? Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 21, 2018 Report Share Posted November 21, 2018 Cool. It is always great when a plan works!!! Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
