(Not HDT related) Laying Laminate flooring (COMPLETED)
Brad & Jacolyn
On ‎7‎/‎25‎/‎2017 at 9:39 PM, Vegas Teacher said:
That looks really great! Must have taken a lot of time
3 1/2 days on my knees and they were barking. On the edges of the slides where it met the carpeting I left a strip of carpeting the width of my level. Then I removed the padding under the strip and folded the carpet back under itself so the slide carpet edge covered it and stapled the carpet back down.
I also put some staples into the edge of the planks where they bumped against the carpet edge that I just described.
Other than that the floor is all floating. No glue.
Before I started I read everything I could find about installing these floors and I found something about this particular flooring and it said not to put it under cabinets. So I was going to just float it up to the edge and then cover with 1/4 round (just for the record the trim is not in place yet but I have it and when I get someplace where I can rent a chop saw AND my knees quit barking I'll install it). However, when I removed the original kitchen flooring it ran under the cabinets and then cleats were added inside the cabinet frame. When I pulled out the original flooring the cabinets stayed up on the cleats so I just slid the new floor into the space left by the old floor. I will put trim around that also.
One big trick that I learned. If at all possible lay the flooring in the direction they recommend (groove to the wall and then left to right). My problem was the flooring ran under the kitchen slide so I had to start there instead of in the back corner on the same side of the rig. My big fear was that I would not be able to slide the material under the kitchen slide (I was right. It was a real bitch as it was). Then I had to lay the kitchen floor out to the edge of the cabinets and then extend the floor back until I cleared the cabinets so I could measure to the wall and try to extend a line all the way to the back of the rig. So I had to work some pieces backwards. The locks work about twice as hard coming in backwards.
Once I got the alignment correct (there was a lot more worrying than there should have been) all the way from the back to front the rest popped in quick because I was working the locks in the proper direction.
What did I learn?
1) Depending on the brand the WEAR LAYER is different. I used 8mm planks with attached cork padding. The wear layer is 20mil. Thickest I found.
2) DON'T go cheap. I ended up paying $4.49 per sq. ft.
3) DON'T rush. You will get aggravated at some point. Walk away and take a break. Otherwise you will get frustrated and make mistakes.
4) This one is JMO. When you buy the install tools (you will need spacers, and tapping block and a pull bar) don't buy the kit. The pull bar in my kit was thin and soft. The bar bent easy and will fight the entire job. Spend a little more and buy individual tools. You will probably be happier in the end and have less buggered fingers.
5) Measure carefully. I figured on having a 1/2 box left. Turns out my waste fell good enough that I had a full unsealed box left. Now they are telling me it was special order and won't take it back.
If you have any questions I'll try to answer them and no I won't install yours.
Brad
P.S. My knees have recovered.
Edited by Brad & Jacolyn
Brad and Jacolyn
2009 Smart "Joy"
2004 VNL630 "Vonda the Volvo"
Fulltiming and loving it.
  • Brad & Jacolyn changed the title to (Not HDT related) Laying Laminate flooring (COMPLETED)
I have done a few RV floors.  First one was with Pergo in a Dolphin.  I went OK.  I agree with your comment about walking away when frustrated.  I actually built that into my schedule.  I would do a couple hours each day after work and while waiting for dinner. That way it was not too much at once.  I am a contractor, but this was a job on my stuff.  Harder to get around to doing it, you know the mechanics cars are always last to get serviced.  The most recent, which I plan on redoing, is on a Newmar 5er, and I used 13mm laminate.  It looks to be too thick for the slides to work right.  I will re-evaulate this when I have time to get back to it.  I do like your choice of material.  It looks GREAT.  A small area is tough to do right, SO MANY CUTS.  A captured areas too.  Good tools are definitely a benefit.  GREAT JOB.  Now enjoy it.
Marcel
Thank you and we are definitely enjoying it. I was afraid I would get something to thick for the slides so I contacted NUWA and asked what they used. They told me that the box said .32" plus they used a pad. The handy dandy internet conversion said 8MM was .314961". So I felt safe using the 8MM with the pad already attached.
Brad
Brad and Jacolyn
2009 Smart "Joy"
What did I learn?
Brad
Well it looks incredible. I like what you said about not getting in a hurry. I have started many projects at my house thinking, "Well this should only take a couple of hours" three days later and still not finished with the wife on my back side I sometimes have to rethink my decision, but I am always happy after I am done and I can say," I did that myself! "
You did a great job, and when I do mine I know I can post questions on the forum and you can answer them for me!
Later,
Vegas Teacher - 2 weeks and counting to the first day of meetings
  • 4 years later...
