Help, seat belts fully retracted, how to release ? 1999 Volvo VNL610
CHIEFWAHO
During our side window install, (not thinking) we let the seat belts fully retract.
Is there any way to get them to release ?
Did a few google searches but nothing we found has been any help.
Truck is a 1999 Volvo VNL610
1999 Volvo VNL610, Cummins M11 - 350/400 HP, 10 speed Rockwell - 'CHIEF'
Custom flatbed with TrailerSaver air hitch.
3 cyl 8000 watt Kubota diesel generator.
They're the regular retractor, locking activated by a pendulum. loosen the mounting bolt and slowly move it around, while trying to pull the belt out. Don't pull on the belt continuously, more of a "try-release, try-release". When the pendulum swings the right way, the release will ... release.
2007 32.5' Fleetwood Quantum
Please e-mail us here.
You may have to totally remove the recoil from its location to rotate it in different directions, then continue with Darryl&Rita's technique.
I've had this happen to me before with different vehicles.
Av8r3400
Thunderstruck - 2012 Volvo VNL 730 D13 iShift
Slick - 2021 Grand Design Momentum 397TH
I'd rather die trying to live - Than live trying not to die.   -Leonard Perry
As was mentioned, there is a pendulum mechanism with a little weight on it, the braking action causes it to swing everso slightly allowing the belt to move freely except under braking. In older vehicles, it isn't beyond the realm of possibility that some debris has gotten down in the mechanism and "gummed up the works" From a safety standpoint it would probably be wise to remove the assembly and inspect them. I am sure you will find the problem.
Jeff Beyer temporarily retired from Trailer Transit
2000 Freightliner Argosy Cabover
2008 Work and Play 34FK
Homebase NW Indiana, no longer full time
Thanks for posting video forxlr8n. I'm in the process of doing the same as ChiefWahoo. I will check mine when I get home maybe I can head off the Issue.
CHIEF WAHOO hope you got yours fixed.
2011 CAN-AM Spyder Rt SE5, 2010 Alpine 5th wheel, 1998 Vovlo VNL610
Hopefully 2 years 6 month till full time retirement.
Thanks for all the tips.  Problem solved.
I secured the lower portion of the seat belts to there original positions, gave them a good yank and they started working.
Re-installed the top and am good to go!
  • 1 month later...
Just getting to my seat belts took the truck to body shop to cut and install windows . Ran into a few issue's. 1 being worker took way to long and took some sick days. 2 rubber that came with windows would not work did not support was way to loose. Had to re cut a little and use new rubber looks great will post pics soon. Still need to reinforce inside of cab and reinstall interior and insulate.
