Shallow Draft Posted October 29, 2016 Report Posted October 29, 2016 I just noticed my voltage show between 13.3 and 13.6. Is this normal? Also when you blow a trailer tire and it tears off the wires as it shreds be sure to check that the two wires don't touch each other. Otherwise you will not have trailer brakes going through Vegas in rush hour. Very thankfull for lots of truck brakes. 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!!
Mark and Dale Bruss Posted October 29, 2016 Report Posted October 29, 2016 Yes, 13.3-13.6 is normal Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com
Yarome Posted October 29, 2016 Report Posted October 29, 2016 I just noticed my voltage show between 13.3 and 13.6. Is this normal? At the alternator or at the battery? At the battery that's probably considered "normal", but I would consider it a touch low. I would like to see 13.8-14.2, but anything between 13.5-14.5 would be "acceptable". If you're getting 13.3-13.6 at the alternator.. it's getting time for a trade out.
Shallow Draft Posted October 29, 2016 Author Report Posted October 29, 2016 Thanks for the help. Stress relief! !! 2004 Volvo 630, Freedomline, Rear view camera, Max Brake, Jackalopee, 38 ft 4 horse LQ Platinum, 40ft Jayco Talon toy hauler Http:/www.flickr.com/photos/shallow_draft/ Https://flic.kr/p/fqhyAN You are not lost if you don't care where you are!!
Dollytrolley Posted October 29, 2016 Report Posted October 29, 2016 At the alternator or at the battery? At the battery that's probably considered "normal", but I would consider it a touch low. I would like to see 13.8-14.2, but anything between 13.5-14.5 would be "acceptable". If you're getting 13.3-13.6 at the alternator.. it's getting time for a trade out. Huston, my "heavy-electrical dictator" used to give me hell for complaining about charging voltage....... I would say "Huston, this darn alternator is only putting out this much charge"........Huston would respond "Forget the charge rate....what was the temperature of the alternator??" Many alternators "performance" degrades sharply as the alternator temp rises.....some become pretty pathetic units as the come up to operating temp. As a general rule you see that largest body alternators on stationary equipment that tend to have hot engine compartments. Many truck manufactures tend to size alternators small hoping that the truck drives fast enough to keep the airflow somewhat cool on the small body alternators........often a poor bet, but it keeps cost down...and charge rates down when hot... Drive on........(Keep cool and well .....charged) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S
Alie&Jim's Carrilite Posted October 29, 2016 Report Posted October 29, 2016 On most vehicles the voltage is read at the starter, I assume this is correct on our trucks as well. If the connections are getting corroded, or if a cable end has split allowing corrosion inside the wire jacket, it will affect the voltage. Jim's Adventures Old Spacecraft.... Who knows whats next
MrSeas Posted October 29, 2016 Report Posted October 29, 2016 If you have the time..... charge up the batteries using a battery charger and make sure your batteries will charge and maintain voltage. Run the truck and check for proper voltage. Sometimes the alternator will get " overwhelmed" when your batteries are too low voltage wise. Might save you an alternator change.
Dirt Posted October 30, 2016 Report Posted October 30, 2016 replaced mine a while back and the new one is about a volt higher...13.8 is normal old was weak and i though so....food for though......FYI.... 97 9200 cornbinder super 10 M11E cummins 1350 ftlbs 81 CJ7 jeep 2000 36ft nuwa king dome onan 6500LP gen/remote start 94 sport Nautique 2007 dyna wide glide 6 speed N7UVW 2007 30ft work&play-LK-- toy hauler by forest river 2006 Alfa toyhouse 40 ft 2010 42kz Escalade toyhauler
NoDirectionHome Posted October 30, 2016 Report Posted October 30, 2016 Unless you're using a sharp pointed probe on the alternator output lug you're reading through a dirty window. As with most issues on these old trucks, CLEAN the TERMINALS first, then let us know what you're seeing. "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740
Mark and Dale Bruss Posted October 30, 2016 Report Posted October 30, 2016 I once had a poor terminal connecting to the alternator. With a digital meter I read 14 volts at the starter and only 13 volts at the battery. Illogical until you consider analog signal voltage (sine wave). Replaced the terminal and the voltage became constant at starter and battery, The dash data display shows the voltage at the batteries. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com
