alan0043 Posted July 26, 2016 Report Share Posted July 26, 2016 Hi Everyone, I have been working on my truck. I needed to remove a seat belt from a 2012 VNL 630 on the passenger side of the truck. Guess what happened after 4 or 5 rotations of the ratchet. One got it, the nut broke loose under the cab. Now I have a BIG problem. Do you think that the rest of the nuts will break loose ? I need to remove more seat belt bolts. The nut on the bottom side of the cab is square. An open end wrench does nut like to stay in place for some reason. The seat belt nut is in a channel under the cab. The nut seems to measure 3/4". The next plan is to try to use a 3/4" to 1/2" adapter on a breaker bar. My neighbor is helping me. This has become a two man job. I do not want to use a cut off wheel or grinder inside the cab because of the grinding dust. Open for ideas, Al Link to comment Share on other sites More sharing options...
NeverEasy Posted July 26, 2016 Report Share Posted July 26, 2016 You have probably already tried this but it is worth saying. Get your biggest vice grips. Clamp them on the head of the bolt inline with the bolt. Then put a big adjustable wrench on the vice grips to hold the bolt. Link to comment Share on other sites More sharing options...
skp51443 Posted July 26, 2016 Report Share Posted July 26, 2016 Maybe an offset jaw nut splitter? One like this that you could rotate the splitting wedge 90 degrees so it would drop into the channel. On Amazon, something similar should be something available locally. https://smile.amazon.com/OTC-4576-Universal-C-Frame-Splitter/dp/B000KSTCGU/ref=sr_1_35?ie=UTF8&qid=1469547121&sr=8-35&keywords=nut+cracker+tool Link to comment Share on other sites More sharing options...
rickeieio Posted July 27, 2016 Report Share Posted July 27, 2016 I have one of those nut splitters, by K-D tools. It works okay, but a hammer and chisel is faster, and easier to get in tight places. Soak the rest of the nuts with a penetrating oil a couple of hours ahead of trying to loosen. Forget WD-40. It's good for removing chewing gum, and little else. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted July 27, 2016 Report Share Posted July 27, 2016 Heat? Judiciously applied? On top of the above mentioned penetrating oil. As a kill shot, add ice cubes. Link to comment Share on other sites More sharing options...
beyerjf Posted July 27, 2016 Report Share Posted July 27, 2016 The caged nut is no longer caged. Just grind the head off the bolt and install a regular bolt in it's place. These are used to speed production assembly with no concern for future problems. If the nut cannot be accessed, then we go to plan B. Link to comment Share on other sites More sharing options...
NoDirectionHome Posted July 27, 2016 Report Share Posted July 27, 2016 Since the square nut is in a channel, just slide a piece of anything between it's flat and the channel to fill the gap and go back up top and continue with your rachet. Link to comment Share on other sites More sharing options...
SIBERNUT Posted July 27, 2016 Report Share Posted July 27, 2016 Good practice for when you try to remove any of the bolts in the cab, inserts embedded in the "fiberglass???" Link to comment Share on other sites More sharing options...
alan0043 Posted July 27, 2016 Author Report Share Posted July 27, 2016 Hi Everybody, Good news to report. With the help of my neighbor, I was able to get the nut removed. I went under the truck with an open end wrench and was able to get ahold of the nut. The nut is over top of the drive shaft. My neighbor was inside the cab with a breaker bar. We did not want to use an impact gun because of the fear that the nut would slip of the wrench. Now I have a few more bolts to remove. Will start a new thread about bolts with lock tight. Thanks to everyone for their help, Al Link to comment Share on other sites More sharing options...
