Silicone spray on slide outs?
Sunshine1
The rubber flaps on my slide out sound terrible when moving. Also the rubber flaps tend curl under in some places.
Has anyone else had this issue? How did you deal with it?
I have no water leakage that I am aware of.
Thanks ahead of time!
a lot of people recommend 303 Aerospace protectant
2000 National RV Sea Breeze 5th wheel 30ft.
So.California
1950 F1 street rod
1949 F1 stock V8 flathead
1948 F6 350 chevy/rest stock, no dump bed shortened frame.
1953 chevy 3100 AD for 85 S10 frame
1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc
1970 Baha Bug wihg 2332cc, King coil overs and everything else there is.
1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc.
Best to check first to see what your manufacturer recommends. Different mgf'ers use different type/quality seals. Some seals need lube or protectant, and some don't. Squeaking rubber is not necessarily a bad thing. Winnebago recommended corn starch on mine, but it made them so slick they would not flip when running the slide in and out. Other than the one time with corn starch, I have never used anything on mine. They still look great after 13 years and over 100k miles, over half of it full-time use.
'05 Honda Odyssey
Escapees, FMCA, WIT, SMART
http://www.pjrider.com
They make a product specifically for slide out rubber seals. Just used it yesterday. It's a spray-on foam. I use it on anything rubber on the outside of the RV.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/ Diamond Pkg.
2014 RAM CTD 6.7 Tradesman 4WD Crew Cab Long Bed  😀
Honda eu2200i generators
Daisy May, the Golden Doodle Wonderdog
There's a spray slide out treatment for the seals you can purchase from Amazon or Camping World. I use it every year to prevent cracking. Helps with the sqeeking noise too.
Name of the product(s)?
LindaH
2014 Winnebago Aspect 27K
2011 Kia Soul
Baby powder. Just apply to a small towel and rub on.
Just curious, doesn't baby powder gum up and get all nasty when it gets wet? I mean, it rains every other day where I am.
I've been using cheap silicone spray from Walmart for eight years on my unit and the slide seals look like new.
Sunshine1, on 01 Jul 2016 - 05:15 AM, said:Sunshine1, on 01 Jul 2016 - 05:15 AM, said:
Is the 303 hard to put on? Both my shoulder are bad, I wonder about applying it since it sounds like the same procedure as applying wax?
It is not a wax. It is a liquid that you simply apply with a cloth. No wiping or buffing afterward.
We use 303 for all rubber products around the RV, including tires and slideout seals.
LindaH
2011 Kia Soul
  • 2 weeks later...
Do double-check with the manufacturer. Ken at New Horizons recommends 303 for their coaches.
2001 Volvo 610 HDT with Smart Car bed and ET Junior hitch
2007 New Horizons Summit 38
2013 Smart for Two
2012 Easy Racer Tour Easy recumbent bicycle
"There is no path. Paths are made by walking." – Spanish poet Antonio Machado
