Jim & Alice Posted June 16, 2016 Report Share Posted June 16, 2016 I have a standard Kidde fire extinguisher in our motorhome, model FA10G, and today noticed that the Fill Gauge was pointing to empty. I took it off the mount, and turned it upside down... and the gauge then returned to Full. And stayed. Reading the instructions, it states the unit must be removed from service after 12 years. The unit is 10 years old. I am wondering if I want to replace it a little early... Any thoughts? Thanks, Jim 2007 Dolphin Safe-T-Plus Steering Bar Our Blog: Click Here Link to comment Share on other sites More sharing options...
jjwicklund Posted June 16, 2016 Report Share Posted June 16, 2016 There not that expensive to replace. Really nice if they work when you need them. John 2017 F350 King Ranch DRW 6.7 4.10 B&W hitch 2017 DRV MS 36RSSB3 Link to comment Share on other sites More sharing options...
RBH Posted June 16, 2016 Report Share Posted June 16, 2016 I would get three or four of the foam type you can find at hardware or big box stores. Make MUCH less of a mess if you actually have to use it. Link to comment Share on other sites More sharing options...
Kirk W Posted June 17, 2016 Report Share Posted June 17, 2016 I would change it out, and I too prefer the foam type. I kept one in the bedroom, one next to the door and a much larger one in a storage bay with outside access. I also keep one in the car. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
travelinbob Posted June 17, 2016 Report Share Posted June 17, 2016 I just replaced 4 of ours. 2006 Elite Suite 36TK32001 F-550 Starhaulerwww.mytripjournal.com/elitesuitestravelsIN GOD WE TRUST Link to comment Share on other sites More sharing options...
Jack Mayer Posted June 17, 2016 Report Share Posted June 17, 2016 Definitely foam for an RV. Much more functional and easier cleanup. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Jim & Alice Posted June 17, 2016 Author Report Share Posted June 17, 2016 Folks, thanks much for the advice. Time to change to Foam, I think. And an additional one or two. Like jjwicklund said... "Really nice if they work when you need them." Jim 2007 Dolphin Safe-T-Plus Steering Bar Our Blog: Click Here Link to comment Share on other sites More sharing options...
Yarome Posted June 17, 2016 Report Share Posted June 17, 2016 It's a personal call. Because the gauge might have had a little dry chemical buildup at the gauge, and it's reading a full charge now, doesn't mean it won't discharge properly if needed. Dry chemical over foam? You bet! I would jot it down as an upcoming replacement need as the budget allows, but wouldn't be terribly concerned about it failing and run right out for replacements. Personally, I would, but that's more because I don't really have budget constrains and I'm more likely to forget if I put it off. Link to comment Share on other sites More sharing options...
RV_ Posted June 17, 2016 Report Share Posted June 17, 2016 Jim, I rarely see a lot about Mac the Fire Guy here any more but I'd take a look at his website for foam extinguishers. http://www.macthefireguy.com/store I bought one of his 1.5 gallon SS400 units, and still have two big 10 pound CO2 extinguishers for my computer areas. But this is one of the things, like CO and propane alarms that we sometimes forget to maintain. Foam is best to put out a fire as it smothers it for a time enough for less chance of a restart. A big advantage of the owner refillable foam larger units like the SS400 is the ease of filling and pressurizing as well as the ability to practice with it and not fill the area with toxic chemicals or release CO2 in the air unnecessarily. Getting the right refill water is the tricky part (electrical conductivity). So a few of the smaller ones make best sense for vehicles. I want one to fight our way out only and then fight the fire from outside if the fire cannot be contained by CO2. RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
rdickinson Posted June 18, 2016 Report Share Posted June 18, 2016 Mac did a presentation at a Life on Wheels seminar in Moscow Idaho a few years back. His foam product will stick to a vertical surface. Co2 and Halon are Ok for confined spaces like a boat engine room but not out in the open. With vibration either over the road on in a boat on the water, dry chem will cake at the lowest point of the extinguisher depending on how it is stored. If not loosened up, when it comes time to use it all you get could be the propellant and no dry chem. Foam is the way to g o. Link to comment Share on other sites More sharing options...
