reed and elaine Posted May 15, 2016 Report Share Posted May 15, 2016 We just purchased a 2002 Roadtrek 190 to compliment our 34' fifth wheel. There are places we wish to go that we could not go to with a 34' fifth wheel in Mexico and Canada, and if we could, we probably could not get out (just about happened in San Miguel del Allende). We have an Olympic Wave 8 in the fifth wheel and it is extremely useful. We are interested in something similar for the Class B. The fifth wheel has approximately 3400 cubic feet to heat and the Roadtrek has only about 600 cubic feet. Even the Olympic Wave 3 is probably overkill for the Roadtrek. Want to know if anyone knows of something smaller. Hooking into propane line should be simple (but would have it done by a professional). Have noted that some use very small catalytic heaters that utilize 1 and 2 lb propane canisters. If anyone knows how effective these are, and how long they last, we would appreciate knowing about them. Reed and Elaine Link to comment Share on other sites More sharing options...
SWharton Posted May 15, 2016 Report Share Posted May 15, 2016 We just bought a Mr. Heater and it could be converted from the propane canisters to a propane line which we did. This was the larger one for our MH. Link to comment Share on other sites More sharing options...
teacher's pet Posted May 15, 2016 Report Share Posted May 15, 2016 We have a Buddy Heater, by Mr Heater that we bought for our Alaska trip in 2013. Plumbed it with a gas line disconnect in our 21' B+, heated great when tested, have never had to use it. Teacher's Pet '06 40' Phaeton QSH 350 Cat. '04 R-Vision B+ Model 213, 6.0 Chevrolet. http://www.skoolzoutforever.blogspot.com http://map.datastormusers.com/user3.cfm?user=3912 Link to comment Share on other sites More sharing options...
reed and elaine Posted May 15, 2016 Author Report Share Posted May 15, 2016 Thanks for the replies. Will look into the Buddy Heater as well as the Olympic Wave 3 (which we had on our earlier 28' trailer). We plan to do Trans-Labrador and take ferry to Newfoundland (or the other way around). This will be July-September time frame, and it can get chilly in Labrador. Reed and Elaine Link to comment Share on other sites More sharing options...
dzwiss Posted May 15, 2016 Report Share Posted May 15, 2016 We also use the Mr. Heater described above that has 4000 BTU and 9000 BTU settings. We have a 35 foot fiver and find that the 4000 BTU setting is more than adequate for our winter use southern AZ. I think it may be more that what you would need in a class B. At times it roasts us out of our 5er. We end up manually cycling it on or off since it has no thermostat. You can turn it off and leave the pilot lit so restarting it is not an issue, the pilot alone supplies a small amount of heat. Rather than run a hose in from the outside on short stays and overnights we frequently just run it off of a 1 lb canister that we refill with a Harbor Freight adaptor for simplicity. We have been using ours for over 8 years with no issues except having to replace the control knob due to my own fault. 2019 Airstream Flying Cloud 27FB 2011 Ford F350 CC SRW "Be thankful we're not getting all the government we're paying for." Will Rogers Link to comment Share on other sites More sharing options...
reed and elaine Posted May 15, 2016 Author Report Share Posted May 15, 2016 The Olympic Wave 3 does have setting from 1600 to 3000 BTU (470 to 880 W). Probably have to set it on the kitchen counter when in use and tie into the stove propane line. Question in Little Buddy. Is it a catalytic heater? Reed and Elaine Link to comment Share on other sites More sharing options...
dzwiss Posted May 15, 2016 Report Share Posted May 15, 2016 Question in Little Buddy. Is it a catalytic heater? Reed and Elaine No, it is a ceramic brick heater and glows red when lit. It provides a bit of ambience. :-) 2019 Airstream Flying Cloud 27FB 2011 Ford F350 CC SRW "Be thankful we're not getting all the government we're paying for." Will Rogers Link to comment Share on other sites More sharing options...
reed and elaine Posted May 15, 2016 Author Report Share Posted May 15, 2016 dzwiss Thanks. Will be stopping by the Roadtrek dealer in Denver to ask further questions. Need to find out about emissions from a Mr. Buddy. The emissions from a catalytic converter are carbon dioxide and water. The only danger is oxygen depletion and possibility of anoxia if vents are not left open. Reed and Elaine Link to comment Share on other sites More sharing options...
dzwiss Posted May 15, 2016 Report Share Posted May 15, 2016 dzwiss Thanks. Will be stopping by the Roadtrek dealer in Denver to ask further questions. Need to find out about emissions from a Mr. Buddy. The emissions from a catalytic converter are carbon dioxide and water. The only danger is oxygen depletion and possibility of anoxia if vents are not left open. Reed and Elaine I don't know what the emissions from the Mr Heater are but it requires 9 square inches of venting per the instructions. According to their website one of the intended uses is for campers. 2019 Airstream Flying Cloud 27FB 2011 Ford F350 CC SRW "Be thankful we're not getting all the government we're paying for." Will Rogers Link to comment Share on other sites More sharing options...
Darryl&Rita Posted May 16, 2016 Report Share Posted May 16, 2016 dzwiss Thanks. Will be stopping by the Roadtrek dealer in Denver to ask further questions. Need to find out about emissions from a Mr. Buddy. The emissions from a catalytic converter are carbon dioxide and water. The only danger is oxygen depletion and possibility of anoxia if vents are not left open. Reed and Elaine Check your high-school chemistry books again. That's some dangerous info you're throwing around. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
SWharton Posted May 16, 2016 Report Share Posted May 16, 2016 There are different sizes of the Mr. Heaters. We just switched to it from the Olympic as it was time to get the pad replaced and that has become such a hassle since Olympic sold out. No pad to replace with the Mr. Heater. We use ours in place of the regular furnace during the day. Don't like the noise of the regular furnace nor the amount of propane it consumes and wastes. We have used heaters of this type for 35 years with no concerns or problems. Link to comment Share on other sites More sharing options...
Yarome Posted May 16, 2016 Report Share Posted May 16, 2016 For that amount of space, and if you're not getting into terribly cold weather, I would probably go with the wave 3. It's quite compact and likely the most fuel efficient option. Although.. if you're looking for something a little more multipurpose, I really do enjoy my Mr. Heater big buddy. I generally only use the lowest 4000BTU setting inside, but it has one feature that others don't.. a fan (internal batteries or adapter). It really helps circulate the warm air so you get a quicker, more even heat throughout (less run time). It can run off an LP line but will also hold 2-1 lb cans and is really great to crank it all the way over (18k BTU) and keep the night chill at bay outside. Enjoying the evening or rig work on a cold day.On the down side.. it's quite large to haul around for the limited use it gets. Even at more than twice the size of your new toy.. 4000BTU gets 'really' warm if you leave it running long.Still a must have for me. Of course.. you can always run a separate fan or roof vents to help circulated the air, but having one built in is very convenient. Especially for outdoor use. Link to comment Share on other sites More sharing options...
Kirk W Posted May 16, 2016 Report Share Posted May 16, 2016 Check your high-school chemistry books again. That's some dangerous info you're throwing around. Answers to propane safety from Propane 101 Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Tom_M Posted May 17, 2016 Report Share Posted May 17, 2016 Keep in mind there are two sizes of Mr Heater Buddy heaters. The Big Buddy can run on either high pressure or low pressure LP. The Buddy is meant to run on only high pressure. I have a Buddy that I plumbed into the line feeding my cooktop which is low pressure. To make this work I removed the regulator from the Buddy and attached a hose. It works well. Tom—————————————————2005 Born Free 24' Rear Bath Towing 1978 VW Bug convertible Minneapolis, MN Link to comment Share on other sites More sharing options...
sandsys Posted May 17, 2016 Report Share Posted May 17, 2016 Keep in mind there are two sizes of Mr Heater Buddy heaters. The Big Buddy can run on either high pressure or low pressure LP. The Buddy is meant to run on only high pressure. I have a Buddy that I plumbed into the line feeding my cooktop which is low pressure. To make this work I removed the regulator from the Buddy and attached a hose. It works well. Isn't there a Little Buddy as well? I'm pretty sure that's the one most van dwellers are using. It uses those little green canisters. I think I have read it can be adapted to use a hose to a bigger tank but I won't promise that is right. Linda Sand Blog: http://sandcastle.sandsys.org/ Former Rigs: Liesure Travel van, Winnebago View 24H, Winnebago Journey 34Y, Sportsmobile Sprinter conversion van Link to comment Share on other sites More sharing options...
Jimalberta Posted May 18, 2016 Report Share Posted May 18, 2016 We use the Big Buddy. It is connected to the main propane line by our stove with a quick connect hose. Our friends use a buddy heater. Both can use the little green bottles but mine has the quick connect low pressure connection as well as a fan if you want to use it.. The Big Buddy is also larger and has 3 heat settings. Top setting is 18000 btu and it heats up the MH fast. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
