Iamhopeful Posted March 15, 2016 Report Share Posted March 15, 2016 What chemical or product is needed to remove old seal adhesive? Link to comment Share on other sites More sharing options...
Pat & Pete Posted March 15, 2016 Report Share Posted March 15, 2016 The seals on our slides simply slip over a lip and are held in place via the seal grip channel . What RV do you have ? Goes around , comes around . Link to comment Share on other sites More sharing options...
Iamhopeful Posted March 15, 2016 Author Report Share Posted March 15, 2016 An Alfa. Backing of the seal is about 1" wide and sticks on the flat surface Link to comment Share on other sites More sharing options...
hemsteadc Posted March 15, 2016 Report Share Posted March 15, 2016 Mine just peeled right off leaving almost no residue. Maybe a teeny bit left on the coach. Of course I'm presuming you mean 'removal from the side of the coach', not from the seal itself. Link to comment Share on other sites More sharing options...
Iamhopeful Posted March 15, 2016 Author Report Share Posted March 15, 2016 Yes. Even tho I scrapped the old adhesive it still has gummy sticky residue on the coach. Link to comment Share on other sites More sharing options...
hemsteadc Posted March 15, 2016 Report Share Posted March 15, 2016 Ok, then I'd recommend rubbing alcohol, or Ronsonol lighter fluid. Resealing is not that easy. Don't know if you've done this before, but I 'went to school' on the first slide. I ended up with a seal that was too tight, then some rough edges after trimming. Works fine, just doesn't look that good in places. Link to comment Share on other sites More sharing options...
KodiakJack Posted March 15, 2016 Report Share Posted March 15, 2016 I removed many feet of seals last summer. Acetone worked the best for me to clean up after removal. Later, J 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
Iamhopeful Posted March 15, 2016 Author Report Share Posted March 15, 2016 Thank You. Don't have any of the two on hand. I'll go and get some. Link to comment Share on other sites More sharing options...
MT_flyfisher Posted March 15, 2016 Report Share Posted March 15, 2016 I used mineral spirits and lots and lots of elbow grease on mine. Link to comment Share on other sites More sharing options...
budeneighe Posted March 15, 2016 Report Share Posted March 15, 2016 No matter what one uses it is a good idea to use alcohol (70%+_isopropyl) to go over it all afterwards to be sure there is no residue from the solvent you used. That can cause adhesion problems to start occurring long after the seal is initially replaced. RVBuddys Journal Our progress into full-timing.Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogsClifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise Link to comment Share on other sites More sharing options...
Iamhopeful Posted March 16, 2016 Author Report Share Posted March 16, 2016 Thank you to all of you. I ended up using industrial strenght GOOF OFF + some elbow grease Link to comment Share on other sites More sharing options...
bobsallyh Posted March 17, 2016 Report Share Posted March 17, 2016 lamhopeful, I replaced the seals on our Alfa three years ago. I used Goof-Off and a plastic putty knife. The longer it was on the easier it removed. The adhesive is 3-M Red. When replacing the seals if the new are also red adhesive there is little room for error when applying them to the side. Applying pressure and they are tight. Warm and hot temperatures really accelerate the adhesive. Link to comment Share on other sites More sharing options...
