Buscrusher Posted March 17, 2016 Report Share Posted March 17, 2016 Ain't this group great?! I agree...a real group of stand-up folks! DougFrequent "lurker"Occasional posterFirst step towards the RV setup complete: 1 smart car Link to comment Share on other sites More sharing options...
Broncohauler Posted March 17, 2016 Report Share Posted March 17, 2016 Sure sounds like a bad air governor is over pressurizing the system, causing the first telltale sign of the air dyer popping off frequently and resulting in finally the weakest link being your airline that broke. ( Think of a home water regulator that goes bad, usually the icemakers tubing is the first thing to blow.) Normally the way I check this is 1st off as you said frequent air dryer popping off. When that occurs I will watch my air gauge. How far is my air dropping before the air compressor turns on and how high is the pressure building before it cuts out. Normally my compressor turns on before 90 psi and back off at 120-125 psi. If my governor is bad it will either go above 125 or only cycle down to maybe 110 and turn back on. Popping off every minute or more. This is true with all my trucks and brands I've driven. As for where your governor is? I'm sure the dealer can tell you or I will look tonight on my 2015 when I get into work. My peterbilt like most older trucks is on the air compressor on the side of the motor. But I know a lot of them are now down low to the driver side rear and the governor is remote. Not smart for a part that dose go bad. Link to comment Share on other sites More sharing options...
Broncohauler Posted March 17, 2016 Report Share Posted March 17, 2016 Typed that up and see you found a real parts guy finally Cool? After it's together watch your air gauge for normal cycling. Link to comment Share on other sites More sharing options...
bmzero Posted March 17, 2016 Author Report Share Posted March 17, 2016 Sure sounds like a bad air governor is over pressurizing the system, causing the first telltale sign of the air dyer popping off frequently and resulting in finally the weakest link being your airline that broke. ( Think of a home water regulator that goes bad, usually the icemakers tubing is the first thing to blow.) Normally the way I check this is 1st off as you said frequent air dryer popping off. When that occurs I will watch my air gauge. How far is my air dropping before the air compressor turns on and how high is the pressure building before it cuts out. Normally my compressor turns on before 90 psi and back off at 120-125 psi. If my governor is bad it will either go above 125 or only cycle down to maybe 110 and turn back on. Popping off every minute or more. This is true with all my trucks and brands I've driven. As for where your governor is? I'm sure the dealer can tell you or I will look tonight on my 2015 when I get into work. My peterbilt like most older trucks is on the air compressor on the side of the motor. But I know a lot of them are now down low to the driver side rear and the governor is remote. Not smart for a part that dose go bad. I did buy a governor yesterday. It is located on the firewall in a very easy spot to reach, just as MrSeas said. I will replace it today. The truck ran for about an hour yesterday with no issues. I'll take it out this weekend, probably pulling the trailer to a MX track and see how it goes. Thanks again for all of the feedback. "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
Brad & Jacolyn Posted March 17, 2016 Report Share Posted March 17, 2016 The governor on my 630 is on the firewall under the hood. And easy to access. Brad Brad and Jacolyn Tucker the Wonder dog and Brynn the Norfolk Terrier 2009 Smart "Joy" 2004 VNL630 "Vonda the Volvo" 2008 Hitch Hiker 35 CK Champagne Edition VED12 465 HP, Freedomline, 3.73 ratio, WB 218" Fulltiming and loving it. Link to comment Share on other sites More sharing options...
bmzero Posted March 18, 2016 Author Report Share Posted March 18, 2016 For anyone interested in the location of the governor on my truck, probably the same on most Volvo VNL models, here it is. View High Resolution Photo Replacing the governor was pretty simple since it was so easy to get to. After replacing the governor, the purge from the dryer has a significantly reduced interval. It is also significantly less pressurized when it purges. The governor was definitely in need of replacement. "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
JPL Posted March 18, 2016 Report Share Posted March 18, 2016 bmzero, Don't forget to give Ratchet a treat! Will see you at the ECR. Pat The Old Sailor Link to comment Share on other sites More sharing options...
JPL Posted March 18, 2016 Report Share Posted March 18, 2016 bmzero, I signed up on the Follow My Build tonight. Do you post pictures on that the same as Escapees? How? I haven't a clue. Maybe you could show a Old Sailor how its done. I've been busy this last couple of weeks getting the Pride ready. We just finished some needed body and paint work. The back yard was the paint booth. We pretty much kept the paint on the truck. Interesting. Now just put things back together. Running out of time and not things to do. Boy am I glad I'm now retired. Pat The Old Sailor Link to comment Share on other sites More sharing options...
bmzero Posted March 18, 2016 Author Report Share Posted March 18, 2016 bmzero, Don't forget to give Ratchet a treat! Will see you at the ECR. Pat Ha ha. Will do. I'll have him with me this year at the ECR. bmzero, I signed up on the Follow My Build tonight. Do you post pictures on that the same as Escapees? How? I haven't a clue. Maybe you could show a Old Sailor how its done. I've been busy this last couple of weeks getting the Pride ready. We just finished some needed body and paint work. The back yard was the paint booth. We pretty much kept the paint on the truck. Interesting. Now just put things back together. Running out of time and not things to do. Boy am I glad I'm now retired. Pat The Old Sailor I would like to think posting photos on FollowMyBuild is much easier than on other sites, but I could be a little biased. Here's a short walk through video. "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
JPL Posted March 19, 2016 Report Share Posted March 19, 2016 bmzero, Thanks for the info but the old man still needs help. At the ECR. See you and Ratchet there. Take Care, Pat The Old Sailor Link to comment Share on other sites More sharing options...
alan0043 Posted March 19, 2016 Report Share Posted March 19, 2016 bmzero, Thanks for the info but the old man still needs help. At the ECR. See you and Ratchet there. Take Care, Pat The Old Sailor Hi Guys, I could use some help in this area also. See you guys in a couple of weeks. The Follow My Build walk through on my end, the print was to small to read. I could not make the print bigger for some reason. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
bmzero Posted March 21, 2016 Author Report Share Posted March 21, 2016 Hi Guys, I could use some help in this area also. See you guys in a couple of weeks. The Follow My Build walk through on my end, the print was to small to read. I could not make the print bigger for some reason. Al I would love to give you guys a demo of FollowMyBuild and get your feedback as well. We can have an impromptu session of that at ECR. "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 21, 2016 Report Share Posted March 21, 2016 I would love to give you guys a demo of FollowMyBuild and get your feedback as well. We can have an impromptu session of that at ECR. If you come to the Fall Rally I'd like you to consider doing an informal session there, too. I, for one, would like to use it.... Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
bmzero Posted March 21, 2016 Author Report Share Posted March 21, 2016 If you come to the Fall Rally I'd like you to consider doing an informal session there, too. I, for one, would like to use it.... That would be great, Jack. We should have the mobile apps in the store by then. They're almost ready now. With the app you can update your builds directly from the phone and share out photos from there. "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
alan0043 Posted March 21, 2016 Report Share Posted March 21, 2016 alan0043, on 19 Mar 2016 - 10:10 AM, said: Hi Guys, I could use some help in this area also. See you guys in a couple of weeks. The Follow My Build walk through on my end, the print was to small to read. I could not make the print bigger for some reason. Al I would love to give you guys a demo of FollowMyBuild and get your feedback as well. We can have an impromptu session of that at ECR. Hi Brit, That sounds good to me. I am also up to learn something new. With the new stuff on line, I am technology challenged. See you in a couple of weeks, Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
bmzero Posted March 21, 2016 Author Report Share Posted March 21, 2016 I'm looking forward to it. "Willy Mammoth" - Volvo 730, Sold Heartland Cyclone 4000 Toy HaulerT-Minus 26 years and counting to being a full timer. Link to comment Share on other sites More sharing options...
