gg923 Posted March 12, 2016 Report Share Posted March 12, 2016 I have worked with copper and PVC plumbing but have never worked with PEX. I am considering purchasing the tool and a few select fittings and tackle a few minor repairs myself. It really appears to be the most simple plumbing there is but the tools carry significant costs. Have any of you purchased the tools (Cinch or Crimp - Brand?)? Alternatively, I am considering just using the push connect sharkbite fittings or something similar (many brands available). My main question has to do with the connections to the back of the docking station (where the pex connects to the docking station). Do any of you know if the connections are just 1/2"NPT or is it some other type of thread? Many Thanks! Gene Link to comment Share on other sites More sharing options...
Kirk W Posted March 13, 2016 Report Share Posted March 13, 2016 I'm not sure what you are calling the docking station? Do you mean the city water connection? If that is what you are thinking of, there are several different ways that they attach. Some of them are threaded for ease of replacement. Link to comment Share on other sites More sharing options...
tinstartrvlr Posted March 13, 2016 Report Share Posted March 13, 2016 I took the plunge and spent around $100 for the tools needed, after paying someone $180 to fix a leaking faucet connection some time ago. I found the pex very easy to work with for the most part. Once clamped, it stays put nicely. The only drawback I found was trying to salvage a tee, as the connection is very hard to break once it has been clamped. There are videos out there showing various ways; none of them were easy in my opinion. Was very impressed with the sharkbite fitting, after having to replace the very same faucet connection a second time, because the so-called-upgrade to brass failed miserably. The sharkbite went together nicely and would not come loose without properly releasing it. All and all, a good investment since nearly all the plumbing in my TT is pex. I keep two 5' sections of red and white pipe, some fittings, etc around just in case. Plus, the big box stores carry pex too...not hard to find. Can't speak to the docking question..sorry. Link to comment Share on other sites More sharing options...
budeneighe Posted March 13, 2016 Report Share Posted March 13, 2016 I have used cinch and crimp. I prefer cinch just because it is easier to undo if you need to without cutting the pex off. If you go with crimp, an offset head is really a lot more flexible. Gets into much tighter spaces. http://www.amazon.com/Crimpers-Plumbing-Crimping-Copper-Gonogo/dp/B00LSF14DS/ref=sr_1_3?ie=UTF8&qid=1457829484&sr=8-3&keywords=pex+crimping+tool+set If you are only interested in doing a few crimps, maybe the Vise-Grip shortie crimper would do for you. It does work but is more difficult in limited spaces. Sharkbite type connectors are usually the easiest (if you have the room and flexibility in the pipe). Many types can also be used to connect different types of pipe, like copper to PEX, PEX to PVC, Copper to PVC, etc. Ck the specs on the particular brand. Though I carry a cinch tool and clamps, I always have a 1/2" Sharkbite with me for quick repairs in emergency circumstances. The best tool I have found for removing crimp rings is Dremel tool and disks. Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 13, 2016 Report Share Posted March 13, 2016 I just bought the fittings and the ratcheting cinch tool for the clamps at Lowes. A small grinder or a Knipex small bolt cutter will remove the fittings fairly easily but you do need some spark control if you use the grinder. Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 13, 2016 Report Share Posted March 13, 2016 I also prefer the Oeticker fittings (cinch), although I have both. And as others have said - keep some Sharkbite around. Sometimes you have to use them because you simply don't have enough access. All the threaded are pipe. Link to comment Share on other sites More sharing options...
pugsly Posted March 14, 2016 Report Share Posted March 14, 2016 If you just have a few connections to do, go with the sharkbite (or similar) and save the investment in the tool. I have a big-a** crimper but only because I had a big job to do (running new airlines at my shop). PEX is probably the easiest/best material to work with (compared to CPVC, Poly, Copper, etc) - easy to cut, bendable, and very high burst strength. Link to comment Share on other sites More sharing options...
gg923 Posted March 14, 2016 Author Report Share Posted March 14, 2016 Thank you all for your guidance! I have found an affordable cinch tool and chosen to go that route. The ROI for a selection of fittings, the tool and the rings are still less than 1 service call fee. Very much appreciated! Gene Link to comment Share on other sites More sharing options...
oldjohnt Posted March 14, 2016 Report Share Posted March 14, 2016 I like the so called Sharkbite type for fast easy repair and replacement, and although they are a bit pricey, I've NEVER had one leak. Of course if I ever had to completely re plumb an RV Id likely go the PEX route (maybe borrow my buddys crimping tool lol). Remember the old gray polybutelyne I believe? tubing they used to use???????? The city water inlets (and maybe the check valve etc., I prefer brass) can be threaded NPT in which I use Teflon thread tape or liquid pipe dope and again I never had a leak after that. I don't like to connect the water hose to a short stub out female hose connection just barely outside the camper surface, so like one of those 90 degree or strain relief fittings and use Brass in any of those type applications. John T NOT in any sense of the word a plumber so take the above advise at your own peril lol Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 14, 2016 Report Share Posted March 14, 2016 I've actually never seen a properly installed Sharkbite fitting leak....and I've probably installed hundreds of them. But you are better off using PEX crimp fittings if you can. Sometimes you cannot get them in, though, even with the mini-crimpers. I carry Sharkbite for those situations. And also Sharkbite stops for capping pipes that may be leaking or damaged. Quick, easy and replaceable. Link to comment Share on other sites More sharing options...
Ray,IN Posted March 14, 2016 Report Share Posted March 14, 2016 I'm still wondering what the docking station actually is???? Link to comment Share on other sites More sharing options...
oldjohnt Posted March 14, 2016 Report Share Posted March 14, 2016 "I'm still wondering what the docking station actually is????" I took a wild guess he meant the city water inlet???????????? If not its not the first nor last time my guess was wrong lol John T NOT a professional plumber Link to comment Share on other sites More sharing options...
RV_ Posted March 14, 2016 Report Share Posted March 14, 2016 Guys, whether you have the tool or not, you should at least try the Flair-It brand fittings. They avoid the difficulty in tight spaces in getting a tool on the crimp/band. I started using them in 1999, when the check valve in my water heater went out. They weigh nothing, are inexpensive, and even a newbie can use them if they can cut a straight cut in plastic tubing. I carried one of each type connector in my tubing size (1/2" then), and the adapters connectors for the 3/4 etc. one or two oddball connections I needed, and a couple of elbows, straight and T connectors. The Pro is great but I just used the plastic. See that line here: http://flairit.com Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted March 14, 2016 Report Share Posted March 14, 2016 I'm still wondering what the docking station actually is???? I thought he had one of these and needed water lines at the dock: Link to comment Share on other sites More sharing options...
gg923 Posted March 15, 2016 Author Report Share Posted March 15, 2016 The docking station is where all the water connections come together, where your valves are for filling your FW tank, draining your black/Gray, City water connection, etc..... May not be the correct term but I have heard them called that..... I just have a fitting leaking on the backside.....Jack mentioned that the threaded fittings were NPT which answered my question. thanks again all! Link to comment Share on other sites More sharing options...
Shadow Catcher Posted March 16, 2016 Report Share Posted March 16, 2016 I have modified some of the plumbing in our teardrop to accommodate a Bullfinch shower point and to add a couple of quick disconnects for the hot water heater heater, I am using it to heat the cabin through an automotive heater core. Link to comment Share on other sites More sharing options...
Ray,IN Posted March 16, 2016 Report Share Posted March 16, 2016 Most call it the "wet-bay". This is the first time I've ever heard it called a docking station. Then again, I once heard a man refer to his sewage hose and fresh water hose as "tackle"??? Made me wonder what he was fishing for. Link to comment Share on other sites More sharing options...
RV_ Posted March 16, 2016 Report Share Posted March 16, 2016 Bottom feeders Ray, bottom feeders! Link to comment Share on other sites More sharing options...
Ray,IN Posted March 16, 2016 Report Share Posted March 16, 2016 Bottom feeders Ray, bottom feeders! I shoulda seen that coming! Link to comment Share on other sites More sharing options...
RV_ Posted March 17, 2016 Report Share Posted March 17, 2016 Link to comment Share on other sites More sharing options...
