Tire pressure
house
How much air are you running on your drive axles? I just got back from my first trip with my new to me HDT and it seemed Like the rear end was a bit "loose" the previous owner towed a relatively light TT and had taken off the inside dual tires. After adding a new tire and wheel to it the Truck shop told me that i should only run 100psi because I am just pulling a horse trailer. I have not weighted it yet but my FL50 was about 20K loaded so I would guess the HDT would be all of that and maybe a bit more.
The other though I had is that the outside tire the PO had on it was a china brand tire that is brand new, but I have never had great luck with them and am debating replacing them with a kumo tire. I guess I will try 120 psi first and see if that makes a difference.
Also I am going to take the truck in to an alignment shop near me to have the front end gone through, it seems like there is a bit more slop in the wheel than i would like.
I agree with Rick and Trey. According to most manufacturers' charts, which typically don't go any lower than 70 PSI, the vast majority of us will be somewhere between 70 and 80 PSI, according to our tire loads.
You'd have to have far more pin weight than any fifth wheel could impose to come anywhere close to needing 100 PSI in duals, unless you've downsized to an MDT-appropriate tire on your drive axle.
Nick are you saying the previous owner removed the inside duals so that you are only running the outside tire at the rear? Are you still tandem axle? (we hope so).
You also mentioned a new outside tire, is this on all rear axles or just one tire? Also is this a drive type tire with large lugs? If so, you may experiencing an issue like 1Rod had when he got new tires, the real deep lug was giving him an unusual feel and took some miles to wear in.
Also you did not say what China brand tire you had, just curious why you think Kumho's which is a Korean manufacturer (not sure if that is where they are made at) is better than Chinese made? Most comments we see are to go to USA made. We are not knocking either, just curious.
Dave
Star dreamer, the truck just had the outside dual when i bought it, I put on a yokohama ty517(sorry i thought it was a kumo tire) on the inside. so it has duals now and is singled, in my experience the name brand tires do better than the yellowseas brand tire that was on there.... as for US made i have had my fair share of issues with US(g614) tires but the no name china brands are worse.
I checked my load rating and like i said my rear axle was over 20k on my fl50 so unless my c112 is lighter i think i am at or near the tire pressure rating for the tire. I think i am going to try to bring the tires up to 120 psi and see if that makes a difference. I am curious to know what some off your rear axle weights are if you only running 70 or lower psi.
Kumo's are mostly made in China even though they are a Korean company. Just because they are made in China does not mean they are inferior or the proverbial "China Bombs" similar to what ends up of many towable RV's. IMHO, you can get a decent tire from China IF the tire construction is controlled by a reputable known tire manufacturer and not some company trying to save a buck by not having good QC or taking shortcuts on construction. I have Crossfire equalizers set to 80 psi installed on my drives and they are wearing well.
This is a link to an interesting web site that you can use to identify where a specific tire was made.
If he has 20k on the single rear axle then he is correct that 100psi is the right psi for the tires.
Two totally different things... Yes your axle may be "rated" for over 20K lbs, but you only need tire pressure to support the "actual" load the tire is carrying.
When I drove my fl50 over the scale on 70 in Colorado last year my rear axle weight was 20,400. on a side note why on earth does everyone have to stop there? I have never seen that sign that says all towed vehicles must stop. I think it is pretty new.
  • 3 weeks later...
When you added the 2nd tire to the dual position did you do a proper "matching" of the tires in the dual application?
i.e. same size, brand, design AND have a measured OC within 3/4" of each other?
If not then you may be asking for problems as the load and traction will not be the same for both tires in the dual position.
RV Cable Grip
RV Cable Grip
RV Air.
