johnschnee Posted April 12, 2015 Report Share Posted April 12, 2015 We're thinking of installing an "EZ hose carrier" (resembles an approx.. 12" diameter plastic pipe) somewhere on our 14 Bounder 35K to hold our most-user pieces of sewer piping but unsure where best to install this - thinking mounted under the driver's slide if we can find a suitable place to mount it & looking for any suggestions? THANKS!!! Link to comment Share on other sites More sharing options...
oldjohnt Posted April 12, 2015 Report Share Posted April 12, 2015 I usually buy big enough thin wall PVC drain pipe and make my own with adequate end bells etc. I have mounted them,,,,,,,,,,,,,On the rear up against the coach on top the bumper,,,,,,,,,,,,,,,Under the rear bumper,,,,,,,,,,,under the RV just behind the duals,,,,,,,,,,,,Of course it all depends on what's there like gas tanks and tow hitches etc etc but usually you can find a good place out of the way THAT WONT DRAG OR CATCH THE GROUND YA KNOW. I have used hanger iron as well as heavy duty zip ties and never had a problem. Another handy item is take 4 inch thin wall PVC and rip/cut in half long ways to use as a trough to hold the sewer hose maybe from the RV to where the hose fits into one of those slinky type sewer hose guides in case the guide wasn't long enough or even from RV to the dump fitting itself, its easy and lightweight. I actually have two such holders under the RV, one for a 10 ft sewer hose the other for a 20 ft. which works out real well depending on location of dump station to the RV. John T Link to comment Share on other sites More sharing options...
skp51443 Posted April 12, 2015 Report Share Posted April 12, 2015 No idea on a Bounder... Up out of the way so you don't scrape it off is my suggestion, we unintentionally removed ours when I decided we could drive over a bush to get to a boondocking spot that looked nice. We used the PVC drain pipe too, try to mount it with one end a bit low and drill a 1/4 or larger drain hole. First rule of computer consulting: Sell a customer a Linux computer and you'll eat for a day. Sell a customer a Windows computer and you'll eat for a lifetime. Link to comment Share on other sites More sharing options...
docj Posted April 12, 2015 Report Share Posted April 12, 2015 Try 5" vinyl fence post. It holds modern sewer hoses with bulky connectors (even the right angle connector.) Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Kirk W Posted April 13, 2015 Report Share Posted April 13, 2015 Try 5" vinyl fence post. It holds modern sewer hoses with bulky connectors (even the right angle connector.) That is a great idea! Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Smitty77_7 Posted April 13, 2015 Report Share Posted April 13, 2015 Also not sure on a Bounder, but many RV owners able to do the fence post holder idea in their LP Tank bay. Used for sewer or folding up ladder storage, or other. Worth a look... Best of luck, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
johnschnee Posted April 14, 2015 Author Report Share Posted April 14, 2015 Thank you all very much for your advice - we just see great benefit to being able to store our sewer hoses OUTSIDE our coach - for obvious reasons! :-) Link to comment Share on other sites More sharing options...
Smitty77_7 Posted April 14, 2015 Report Share Posted April 14, 2015 Another tip if you end retaining the storage inside a lower cabinet, is to hook the male end to the female end after rinsing. This at least keeps the residual inside the hose stuff, inside the hose:)! Best, Smitty Be safe, have fun, Smitty 04 CC Allure "RooII" - Our "E" ride for life! Link to comment Share on other sites More sharing options...
