GlennWest Posted June 30, 2019 Report Share Posted June 30, 2019 After I removed my ladder I am left with 4 screw holes 4 sets. For now just dicored it. I would like a more permament repair. Any suggestions. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Lance A Lott Posted June 30, 2019 Report Share Posted June 30, 2019 Depending roof material and hole size you can get several size roofing screws with a rubber washer. If the roof is aluminum you could replace the screw with stainless keeping the steel washer and rubber. You can also just by rubber washers or o rings and ss washers and sheet metal svrews. If you do remember the ss screw brake off very easy and need a pilot hole much bigger than expected. That and your choice of sealant should take care of the problem. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted June 30, 2019 Author Report Share Posted June 30, 2019 (edited) Sorry, didn't make this clear. Rear cap area. Teton used a 3 piece ladder due to rear awning. Center section comes out. I removed the lower secion. I left the top section. Good hand hold to come off of straight ladder. Edited June 30, 2019 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rynosback Posted June 30, 2019 Report Share Posted June 30, 2019 (edited) If the rear cap is made out of fiberglass. Have the screw holes filled and then repaint. If done right, you should never know it was even there. Edited June 30, 2019 by rynosback Quote 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
GlennWest Posted June 30, 2019 Author Report Share Posted June 30, 2019 Just use a resin? Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Randyretired Posted June 30, 2019 Report Share Posted June 30, 2019 For the roof eternabond tape and for the fiberglass either little bondo or gel coat. When I put a new ladder on our Teton I went to a fiberglass repair shop and had them mix a little jar of gel coat to match the color. Filled the old holes then sanded it down even and buffed it out. Bondo and a some touch up paint might also work. Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 30, 2019 Report Share Posted June 30, 2019 With a little fiberglass to stiffen things up. Resin by itself isn't very stable as a repair. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
GlennWest Posted June 30, 2019 Author Report Share Posted June 30, 2019 just small holes. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jblscooper Posted July 2, 2019 Report Share Posted July 2, 2019 Get yourself a pkg of Marine-Tek fiberglass repair kit. this stuff was made for boats and when dry, can be drilled, sanded, etc. West Marine is a good place or Amazon. Jim Quote Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 2, 2019 Report Share Posted July 2, 2019 If their screw holes, put a little caulk/dicor in the hole and put the screw back in. Quote Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
GlennWest Posted July 2, 2019 Author Report Share Posted July 2, 2019 44 minutes ago, Alie&Jim's Carrilite said: If their screw holes, put a little caulk/dicor in the hole and put the screw back in. Did that but don't like looks of it. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
