Fhkw9DPJ8V1g Posted October 26, 2018 Report Share Posted October 26, 2018 I just wanted to share a solution that I came up with for our Dometic RM1350 reefer. The doors are mounted onto peg like plastic bushings. The cylindrical bushing slides into the corner of the reefer door which is simply molded plastic. Well after years of bouncing and jostling these plastic corners start to break apart leaving the doors just barely hanging on. On some models there is actually a hinge repair kit but when I called a well known Dometic parts dealer they told me that the repair kit wasn't available for the RM1350(4 door model). Their solution was to buy new doors at about $400 dollars each before freight. Basically what I did was create a new corner out of 24g steel. I then drilled a hole for the pin and bushing to go through. The only way to attach this to the door is with screws drilled into the door frame itself. The ones on the bottom will never be seen but I painted the ones on the top black so they aren't very noticeable. Here are three PICTURES of the before and after. The repair is much easier if you remove whatever insert you have on the front of the door to lighten them up. A second set of hands is very helpful when reinstalling. Hopefully this will be helpful to some folks. Link to comment Share on other sites More sharing options...
Ronbo Posted October 26, 2018 Report Share Posted October 26, 2018 Can’t see the pictures on the link. Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Fhkw9DPJ8V1g Posted October 26, 2018 Author Report Share Posted October 26, 2018 I'm not sure why they aren't working for you. They worked for me. Can someone else please try and let us know if they worked or not? Link to comment Share on other sites More sharing options...
orca Posted October 26, 2018 Report Share Posted October 26, 2018 I was lookin at them just as u posted! 2004 Freightliner m2 106 2015 DRV lx450 Fullhouse 2019 Indian Springfield 2014 Yamaha 950 V-Star Link to comment Share on other sites More sharing options...
Darryl&Rita Posted October 26, 2018 Report Share Posted October 26, 2018 Working here. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
bobsallyh Posted October 27, 2018 Report Share Posted October 27, 2018 Excellent job, thanks for sharing. Link to comment Share on other sites More sharing options...
lenp Posted October 27, 2018 Report Share Posted October 27, 2018 I did the same for an older two door dometic several years ago. The refer door broke and a simple piece of aluminum flat stock worked great Lenp USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Ronbo Posted October 27, 2018 Report Share Posted October 27, 2018 Started working for me. Looks good Ron C. 2013 Dynamax Trilogy 3850 D3 2000 Kenworth T2000 Optimus Prime Link to comment Share on other sites More sharing options...
Ray,IN Posted October 31, 2018 Report Share Posted October 31, 2018 Thanks, good to see American ingenuity at work. Hope I can remember your solution when/if I need it. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
