T2000 Bumper Hitch Help Needed
dirtrunner0519
I made a bolt on hitch plate using 1/2 x 6" bar stock and a 5/8 plate.     This is for a 20 ton pintle hitch, 3/8 and 1/2" would work for a 20K trailer.
Steve
Build a frame that bolts to the frame. Then get a bolt on class 3 hitch and bolt59 the frame you made. I actually have a square light post for my rear bumper. I have the receiver tubing passing through the post. I goes forward to the frame I built for my bed tilt cylinders and is fastened to this.
Ron C.
2013 Dynamax Trilogy 3850 D3
Steve
The forged 30k 2 5/16 ball will shear off before Steve's hitch will notice any load..
Plenty of geometry to make a very low-pin loading into the frame rails....nice and simple.
Drive on......($imple= Nice...)
I am going to be doing the same thing this winter. I want to incorporate a full with rear bumper with receiver hitch.  I will be using 8X8 square tube. Its bigger than I wanted but the price was right. I will make end caps and store my fishing poles in it. Also will be a step to get up on the bed. I have not figured out how everything will be attached yet. Likely something like what Steve has there.
beemergary that is almost exactly what we have on our farm trucks. I actually have 2 of them laying around off old trucks. They are 1 inch plate with a pintel hitch and receiver. We use to pull a pup trailer with the straight trucks.
Farmer, Trucker, Equipment operator, Mechanic
Quando omni flunkus moritati-When all else fails, play dead
I'm a man, but I can change, if I have to, I guess.
In the pics above you can see the side rails extend down below the hitch plate, the bumper attaches to the truck there.    The bumper on my truck is 2X6 and, I had to notch it to clear the pintle hook.      I don't have a receiver tube on the back, the pintle comes off and a ball mount bolts to the plate.
Steve
