PEIFamily Posted July 27, 2017 Report Share Posted July 27, 2017 Hi, Been a crazy summer so far, haven't had a moment to work on the truck yet, but I need to pull off my compressor soon to repair a drip from the bottom (Have jb weld on the "frost plugs" but still dripping a bit so want to fix it for good). NOW.. How much of a pain is it to take these off? I saw RandyA's post about it and wondering if anyone has any hints/tips to do it. I am guessing it is a bit more complex then just removing the rubber lines and unbolting the few bolts.... Does the coolant need to be drained? etc? Thanks Jason 2006 Volvo 670 singled long 2011 Heartland Sundance 3300CK 2006 Smart passion 2001 F350 DRW CREWCAB Link to comment Share on other sites More sharing options...
PEIFamily Posted September 15, 2017 Author Report Share Posted September 15, 2017 Bump? Anyone know what is involved.. Hoping to tackle this next week. 2006 Volvo 670 singled long 2011 Heartland Sundance 3300CK 2006 Smart passion 2001 F350 DRW CREWCAB Link to comment Share on other sites More sharing options...
Little Posted September 15, 2017 Report Share Posted September 15, 2017 Coolant needs to be drained to below the compressor. I have changed them on Cummins and Cats, but can't see any difference on my D12. Compressor heads are water cooled in most cases. 2004 Volvo 780 singled long Eclipse Attitude toyhauler 79 Shovelhead Electraglide Link to comment Share on other sites More sharing options...
MrSeas Posted September 15, 2017 Report Share Posted September 15, 2017 Maybe this will help..... Link to comment Share on other sites More sharing options...
PEIFamily Posted September 15, 2017 Author Report Share Posted September 15, 2017 Thanks 2006 Volvo 670 singled long 2011 Heartland Sundance 3300CK 2006 Smart passion 2001 F350 DRW CREWCAB Link to comment Share on other sites More sharing options...
RandyA Posted September 17, 2017 Report Share Posted September 17, 2017 You must have the 37mm wrench - open end. Not something many of us have in our tool bag. Also not at Harbor Freight or Amazon. You can find 36mm and use a 6" bench grinder to open it to 37mm. Replace the L and U hoses while the compressor is off. Read through all of my comments and replies in the compressor replace post. Keep in mind you will need more parts. New O rings for the metal coolant pipes are needed as well. At least you have a repairable problem and don't need to purchase a new compressor. Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
GlennWest Posted September 17, 2017 Report Share Posted September 17, 2017 Just goggled 37mm wrench and found several. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Sculptor Posted September 17, 2017 Report Share Posted September 17, 2017 10 hours ago, RandyA said: You must have the 37mm wrench - open end. Not something many of us have in our tool bag. Also not at Harbor Freight or Amazon. You can find 36mm and use a 6" bench grinder to open it to 37mm. Replace the L and U hoses while the compressor is off. Read through all of my comments and replies in the compressor replace post. Keep in mind you will need more parts. New O rings for the metal coolant pipes are needed as well. At least you have a repairable problem and don't need to purchase a new compressor. No idea why, but I decided I had to find out if a 37mm could be bought somewhere . Handy conversion chart. I even tried 1-7/16" to millimeter and it was .050" off. The good news is Home Despot and several others sell them. Probably online only. Kevin and June 2013 Volvo VNL 730 D13 Eco-Torque @ 425 Ratio 2.47 2014 DRV 36TKSB3 Link to comment Share on other sites More sharing options...
noteven Posted September 17, 2017 Report Share Posted September 17, 2017 those darn mm's "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 17, 2017 Report Share Posted September 17, 2017 Either NAPA or I have chased down a Tool Truck... Mac.... Snap on to buy a tool that was needed. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
