Cotreker Posted January 22 Report Share Posted January 22 Adding a standard pickup 5th wheel hitch to my Volvo 670. Cannot use the ET Hitch because my pin weight is only 2200 lbs. Henry with ET Hitch tells me to look for a Pinbox that has cushion or dampening built in to protect the RV. Will the GenY hitch do this? Who else makes a good Pinbox? RV Brinkley Z3100 GVRW 15,000lbs Bonus Points: Which hitch should I mount on the semi? Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
rickeieio Posted January 22 Report Share Posted January 22 I'd be looking for a nice used TrailerSaver hitch for the truck. Plenty of capacity for your use, and fine for a mid sized fifth. We used one for about 10 years (bought used) and had no issues. Just add a leveling valve and forget it. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
Cotreker Posted January 22 Author Report Share Posted January 22 Rich, cannot use an air ride hitch with the low pin weight of 2200 lbs. Henry with ET does not recommend his product or other type hitches. So I will go with the Pinbox that will give flex or cushion. Maybe GenY…. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Nigel Posted January 22 Report Share Posted January 22 Buy what you think will work best for you. I have at least thirty thousand miles using a Trailsaver TSLB2H with a trailer that has a 1500 lb pin weight from the factory. I’m sure my actual pin is a couple of hundred pounds heavier with all the stuff I have packed up front. What can I say the combination works well. Best of luck searching out the options. Nigel Quote 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
phoenix2013 Posted January 22 Report Share Posted January 22 GenY will certainly work for you. I saw on their website one that goes .5-2K, but I saw one that seem to go higher (didn't see specs). H Quote Link to comment Share on other sites More sharing options...
Cotreker Posted January 22 Author Report Share Posted January 22 Looks like Trailer Saver TSLB is the correct product for my RV. Thanks All. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Av8r3400 Posted January 23 Report Share Posted January 23 (edited) As I put on Facebook, this is a video of my old Carbon 364 on my ET senior. It's also a 16k gross trailer, but it was between 3000 and 3500 pin weight. As I mentioned on Facebook I would suggest confirming that 2200 pound pin weight. That's only 12% of a 16k trailer and even for a poorly designed RV, that is really light. Edited January 23 by Av8r3400 Quote Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
phoenix2013 Posted January 28 Report Share Posted January 28 I had a conversation with the folks at Youngs Welding about the lower capacity ET hitches (besides the ones I'm working on for pickups), with four 1,500 lbs. bags to make these work with the 2,500 - 3,000 lbs. pin weights. Chance remembered it, I forgot (!!!) that I solved that problem years back. I redesigned the ET Junior to accept four of these bags and do the job. The other part of the redesign was to build the Junior with a Senior style mounting plate ready for install in the semis. I'll see if I can dig out these drawings. Quote Link to comment Share on other sites More sharing options...
Cheyenne1 Posted January 28 Report Share Posted January 28 I ran a trailer saver TS3 on my last truck. Had it for 12 years and pulled over 225,000 KM ( 140,000 miles ) Worked great. Only a few maintenance things need to be done. Nothing wrong with that hitch in my opinion. I have another TS3 ready to install on my new truck as soon as I get around to it. Quote Link to comment Share on other sites More sharing options...
Cotreker Posted January 28 Author Report Share Posted January 28 I am getting ready to pull the trigger on a Trailer Saver hitch just debating between the TS3 and TSLB. The TSLB gives me more room for growth in the future but not sure I need it. The TS3 mounts differently on rails as I understand reading about it. So each product will require me to mount a metal plate between my frame rails and then mount the rails to the plate. Do I have the process correct? All of the height requirements need to be carefully thought out in order to get the plate to the correct height. I think this target height is 48" please confirm. Goal is to get the 5er level or noise down slightly so it has a bit more pin weight. My pin weight will be 2200 lbs. My Brinkley comes out of production mid March. Quote Volvo 670 / 2006 10-Speed ATV's & Sleds 2017 Host Mammoth Slide-In Camper on Deck Jackalopee Build article published here Link to comment Share on other sites More sharing options...
Av8r3400 Posted January 28 Report Share Posted January 28 I did my truck at 48". This was a huge mistake. My Momentum Toy Hauler is more like 52-54". I wound up needed to extend and modify the pin box on the trailer to get it to ride level. I'd highly suggest measuring your pin height at level to see what you really need. Quote Av8r34002012 Volvo VNL 730 D13 iShift & 2021 Grand Design Momentum 397TH I'd rather die trying to live - Than live trying not to die. -Leonard Perry Link to comment Share on other sites More sharing options...
