OldWO3 Posted October 11, 2023 Report Share Posted October 11, 2023 Good day all, I have a 2000 Roadtrek 190 Popular. It hah a dometic model RM2333 refrigerator installed. The "pilot" light goes out when travelling at highway speeds. Around town it's fine. Due to the placement of the fridge and the outside access panel I am unable to get to the burner to clean it. I am thinking of covering the access panel but I'm sure that would affect the operation. I have removed the front mounting screws but I cannot locate how the back of the fridge is secured to the RV. Any thoughts, Ideas or experiences would be greatly appreciated. The RV is new to me and I do not know if the previous owners had this issue. Thanks in advance for your help Quote Link to comment Share on other sites More sharing options...
Kirk W Posted October 11, 2023 Report Share Posted October 11, 2023 Welcome to the Escapee forums! Here is a copy of the Owner's Manual which you can download, if you do not have them. The operating instructions begin on page 8. There are several things that could be related to the problems and a lack of service is one of them. You should be able to gain access to the burner area from the outside access panel. It is also possible that you do not have proper propane supply pressure so you may want to have that checked. With an RV that is now 23 years old, it seems unlikely that the problem was always there but I have no experience with one like it so am only guessing. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wrknrvr Posted October 11, 2023 Report Share Posted October 11, 2023 Just a quick guess to look at. Is the burner itself. Where the propane comes out of several slots. Sometimes they sorta grow shut with deposits, or oxidation. I normally use a small 90 degree pick to clean the slots. One of those orange handle little picks with a point on it. If they need cleaning, normally the flame will be a little bigger when operating. Just be careful about doing the work. Quote Link to comment Share on other sites More sharing options...
OldWO3 Posted October 17, 2023 Author Report Share Posted October 17, 2023 On 10/11/2023 at 12:56 PM, Wrknrvr said: Just a quick guess to look at. Is the burner itself. Where the propane comes out of several slots. Sometimes they sorta grow shut with deposits, or oxidation. I normally use a small 90 degree pick to clean the slots. One of those orange handle little picks with a point on it. If they need cleaning, normally the flame will be a little bigger when operating. Just be careful about doing the work. Quote Link to comment Share on other sites More sharing options...
OldWO3 Posted October 17, 2023 Author Report Share Posted October 17, 2023 On 10/11/2023 at 12:56 PM, Wrknrvr said: Just a quick guess to look at. Is the burner itself. Where the propane comes out of several slots. Sometimes they sorta grow shut with deposits, or oxidation. I normally use a small 90 degree pick to clean the slots. One of those orange handle little picks with a point on it. If they need cleaning, normally the flame will be a little bigger when operating. Just be careful about doing the work. Access to the burner is virtually impossible. It's about 6 inches to the right of the access panel. I'm unable to attach pictures for some reason. Thanks for your suggestion. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted October 17, 2023 Report Share Posted October 17, 2023 9 hours ago, OldWO3 said: Access to the burner is virtually impossible. If your RV doesn't have the standard access panel that is full width of the refrigerator you may have to pull it out of the mounting inside of the RV to gain access. .. Before you do that, have you had the propane supply pressure checked to be sure that it is at the required 11" of water column? It might be that you need to have the propane pressure regulator replaced as a low supply would make it more likely to blow out. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Wrknrvr Posted October 17, 2023 Report Share Posted October 17, 2023 I am wondering about driving with a window open. Or a vent open? Could that situation leave wind blow the flame out. What year is the unit. Also which side of the rv is the fridge on? Quote Link to comment Share on other sites More sharing options...
