Frogman Posted September 6, 2023 Report Share Posted September 6, 2023 Hi Folks, I have another rookie question. My question is about dash warning light. I the center of my instrument cluster I have the word " CHECK " show up in yellow. Right now I do not know what I should check. I need some guidance. My truck is a 2012 Volvo 610 with an I shift transmission. Just last week I put in 4 new batteries. At that time everything seemed to be ok. Another question or too. When the truck is running, what should be the voltage be ? How do I find what codes are causing the "CHECK" light to come on. Thank you for any help or ideas, Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted September 6, 2023 Report Share Posted September 6, 2023 When the truck is running, the voltage should be at least 13.2, or higher. You should be able to run diagnostics in your driver information display by using the buttons on your wiper stalk. Jay Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 6, 2023 Report Share Posted September 6, 2023 Time to read the operators manual. I know it is frustrating at this time, to even think about that. But that will get you on the correct path for understanding how to figure these problems out. More thinking follow. Quote Link to comment Share on other sites More sharing options...
SuiteSuccess Posted September 7, 2023 Report Share Posted September 7, 2023 17 hours ago, Frogman said: Hi Folks, I have another rookie question. My question is about dash warning light. I the center of my instrument cluster I have the word " CHECK " show up in yellow. Right now I do not know what I should check. I need some guidance. My truck is a 2012 Volvo 610 with an I shift transmission. Just last week I put in 4 new batteries. At that time everything seemed to be ok. Another question or too. When the truck is running, what should be the voltage be ? How do I find what codes are causing the "CHECK" light to come on. Thank you for any help or ideas, Does it stay on? Or extinguish when air pressure hits 60 psi? If stays on use stalk to find “vehicle messages” and it should tell you what to check. Quote 2006 Volvo 780 "Hoss" Volvo D12, 465hp, 1650 ft/lbs tq., ultrashift Bed Build by "JW Morgan's Custom Welding" 2017 DRV 39DBRS3 2013 Smart Passion Coupe "Itty Bitty" "Don't go around saying the world owes you a living. The world owes you nothing. It was here first!" Link to comment Share on other sites More sharing options...
Frogman Posted September 7, 2023 Author Report Share Posted September 7, 2023 Hi Guys, Thank you so much the the help and ideas. Sounds like it's time to do so reading. I also plan to take a pen and paper with me when doing this this job. I will report back later what I find. Knowing me there will me more questions later. Thank you again, Quote Link to comment Share on other sites More sharing options...
Frogman Posted September 7, 2023 Author Report Share Posted September 7, 2023 2 hours ago, Frogman said: Hi Guys, Thank you so much the the help and ideas. Sounds like it's time to do so reading. I also plan to take a pen and paper with me when doing this this job. I will report back later what I find. Knowing me there will me more questions later. Thank you again, Hi Guys, I am come across this video. It could help other folks with their Volvo. I have watched it several times now. Looks like to be a big help. Will report back later after I go through the whole menu. Wish me luck. Quote Link to comment Share on other sites More sharing options...
Wrknrvr Posted September 7, 2023 Report Share Posted September 7, 2023 If you take a picture with your phone. Then you will have a date and time, along with what code is showing. Could be helpful with future reference at a glance. Thanks for the update. Quote Link to comment Share on other sites More sharing options...
Frogman Posted September 9, 2023 Author Report Share Posted September 9, 2023 (edited) Hi Folks, Update (9/9). This is the fault that came up. Instrument cluster, MID 140 PSID 239 FM1 12. So far I have no idea what this fault is. I have followed the video with success but no success with resetting the fault. Not sure why. Any ideas guys ? Also I believe the truck has a new problem. I will start a new thread about that problem. I should have added this info. Also on the dash was this message. Volvo Link, Hardware Failure, Use Paper Logbook. Edited September 9, 2023 by Frogman more info Quote Link to comment Share on other sites More sharing options...
Moresmoke Posted September 10, 2023 Report Share Posted September 10, 2023 The two messages are related. You can plug your fault code into Google and get a fairly decent description. The Volvo link is a telematics module. Most likely not needed for HDT use. You will likely need programming done by a dealer to remove it. Quote Link to comment Share on other sites More sharing options...
