West_Coast_Racer Posted February 26, 2023 Report Share Posted February 26, 2023 Could anyone help me out with the wiring on the switch? 3 terminals, and 2 wires. my dumbass knocked both wires off and I'm clueless to figure it out. I would Really like for the exhaust brake to function again. Truck has the volvo motor if that makes a difference? Quote Link to comment Share on other sites More sharing options...
ddm502001 Posted February 26, 2023 Report Share Posted February 26, 2023 Exhaust Brake should be a Disconnect Switch on Clutch. On the old Jakes were three connection points also where One(Usually Center) was Common, one end was NO or Normally OPEN(That is when switch is in Relaxed State, IE Pedal Away from Clutch Pedal applied) and the other connection NC or Normally Closed same position. With pedal in normal operating position check with a Ohm Meter Center to each end, then apply the Clutch and check those Continuity points should have reversed. You Want the one NO to Center and the Center as to normal connection. Again NO when Pedal is Depressed, and closed when pedal in driving full up/released position. Quote Link to comment Share on other sites More sharing options...
NeverEasy Posted February 26, 2023 Report Share Posted February 26, 2023 (edited) https://i.imgur.com/l81LgDBl.jpg If there are only two wires as shown in this schematic, it should not matter. It is just a switch, I will try to PM you with the full PDF. Chet That did not work to send picture. Watch for PM. Edited February 27, 2023 by NeverEasy No link to pic Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
Nigel Posted February 26, 2023 Report Share Posted February 26, 2023 (edited) Lose the [IMG] on both ends of your link Edited February 26, 2023 by Nigel Quote 2006 Volvo VNL 430, 2006 smart cabrio cdi, 2000 Triple E Topaz 30' Link to comment Share on other sites More sharing options...
NeverEasy Posted February 27, 2023 Report Share Posted February 27, 2023 (edited) Did that the first time as I have done it before. Link goes to the site and gives error. https://i.imgur.com/SWhtR39.jpg "target=new"https://i.imgur.com/SWhtR39l.jpg "border=0"[/IMG][/URL] [IMG]https://i.imgur.com/m3zZPvb.png[/IMG][URL=https://i.imgur.com/SWhtR39.jpg "target=new"]Click For Full-Size Image[/URL]. This worked with just the first part of the URL. Edited February 27, 2023 by NeverEasy Quote Chet & Deb '01 Volvo 660 w/ Smart '19 Forest River Columbus 320RS 5th wheel 2022 Chev 2500HD Long Bed Retired CWO4, USN and federal service Electronics Tech/Network Engineer/Welder/Machinist Link to comment Share on other sites More sharing options...
West_Coast_Racer Posted February 27, 2023 Author Report Share Posted February 27, 2023 2 hours ago, NeverEasy said: https://i.imgur.com/l81LgDBl.jpg If there are only two wires as shown in this schematic, it should not matter. It is just a switch, I will try to PM you with the full PDF. Chet That did not work to send picture. Watch for PM. thank you for the help, I have the switch wired correctly now, I will find out thurs if it solves the engine brake issue Quote Link to comment Share on other sites More sharing options...
Jaydrvr Posted February 27, 2023 Report Share Posted February 27, 2023 42 minutes ago, NeverEasy said: Did that the first time as I have done it before. Link goes to the site and gives error. https://i.imgur.com/SWhtR39.jpg "target=new"https://i.imgur.com/SWhtR39l.jpg "border=0"[/IMG][/URL] [IMG]https://i.imgur.com/m3zZPvb.png[/IMG][URL=https://i.imgur.com/SWhtR39.jpg "target=new"]Click For Full-Size Image[/URL]. This worked with just the first part of the URL. You need to use the "Other Media" button and insert the link there. Jay Quote Link to comment Share on other sites More sharing options...
ddm502001 Posted February 27, 2023 Report Share Posted February 27, 2023 Typical Micro Switch has a Common Center Terminal, a NO Terminal and NC Terminal, DOES make a difference if want system to work, also interferes with Cruise when get there if wrong. Quote Link to comment Share on other sites More sharing options...
Anawilliam850 Posted February 27, 2023 Report Share Posted February 27, 2023 In a 1998 Volvo with a clutch switch, the clutch switch should have two wires connected to it. One wire is typically connected to the COM (common) terminal, and the other wire is typically connected to the NO (normally open) terminal. To reattach the wires, you will need to identify which wire was originally connected to which terminal on the switch. Typically, the wire connected to the COM terminal will be a ground wire, while the wire connected to the NO terminal will be the signal wire from the clutch pedal switch. Once you have identified which wire goes to which terminal, you can reattach them to the switch by securing them with screws or clamps on the switch. It's important to ensure that the wires are properly secured and insulated to prevent any electrical hazards. If you're still having trouble or are unsure about how to proceed, it may be best to consult a professional mechanic or electrician for assistance to ensure that the switch is properly installed and functioning safely. Quote Link to comment Share on other sites More sharing options...
West_Coast_Racer Posted April 18, 2023 Author Report Share Posted April 18, 2023 just to update this thread, I got the switch wired correctly, and also found that the plug to the back of the exhaust brake switch wasn't making good contact. I was delighted to hear the 1st stage of engine brake come on. The 2nd stage wasn't working so I was thinking it might be a switch issue. I was happy to have the 1st stage working to be honest. About 120 miles into my next trip I had the switch set for both stages to work an while going down a 6% grade I heard a "pop" and the 2nd stage started working. What a difference it is to drive now with both stages working. At 49k total weight the truck is a lot happier now! Quote Link to comment Share on other sites More sharing options...
rickeieio Posted April 18, 2023 Report Share Posted April 18, 2023 Congratulations!!! Yes, a functioning engine brake is a wonderful thing. Our Volvo had a Cummins, and after the engine brake was fully engaged, the next thing to engage was the fan clutch. It's pretty cool to be going down a mountain and feel each stage kick in. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
