mrsbaatz Posted September 6, 2022 Report Share Posted September 6, 2022 Desperately searching for a solution for internet in a remote area of Michigan. The Hotspot only works sporadically and only if we set it out about 30 feet from the trailer in an open field. Starlink is no longer an option. So what is the solution that doesn't require thousands of dollars upfront just for the equipment? Our trailer is in a permanent spot on a private campground. We are not interested in TV (though we do stream via Netflix, etc.) and use internet for working remotely. Has anyone managed to crack this problem? Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 6, 2022 Report Share Posted September 6, 2022 The only answer that I know of would be to go with salettite internet in an area that is remote. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
LiveWorkDream Posted September 6, 2022 Report Share Posted September 6, 2022 Boy that was our conundrum earlier this year. We have satellite internet with Mobilsat, but couldn't use it because of tree cover in our workamper campsite. We have 3 different carriers, a booster and antenna raised 5 feet above our rig, and that didn't help either. We had to leave the job because of no connectivity. My best advice is to try different carriers to see if that helps. Have you done that yet? Quote Rene & JimExploring North America since 2007. SKP #103,274 Link to comment Share on other sites More sharing options...
Dutch_12078 Posted September 6, 2022 Report Share Posted September 6, 2022 (edited) Just curious, but why is Starlink no longer an option? The fact that you get hotspot service at all suggests that an external antenna setup would likely improve the situation. Since we started using an aimable MIMO Yagi antenna pair mounted above the roof of our motorhome, we've gotten usable signals even in some locations where our previous $600 booster/repeater system was marginal at best. Our antenna set is only about 15 feet off the ground, but if we were in a fixed location, I would probably use PVC pipe to get it up a fair amount higher. I use a cell tower locator site to determine which way to aim the antenna set. Your hotspot does need two antenna inputs and MIMO support of course. Edited September 6, 2022 by Dutch_12078 Quote Dutch 2001 GBM Landau 34' Class A F-53 Chassis, Triton V10, TST TPMS 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/brake system Link to comment Share on other sites More sharing options...
Randyretired Posted September 6, 2022 Report Share Posted September 6, 2022 If all else fails there is Hughesnet and Viasat? sp. We currently have Hughesnet but hope to switch to Starlink. Hughesnet works but is slow and the delay is a pain. Just about every year the dish needs to be readjusted. $175 Quote Randy 2001 Volvo VNL 42 Cummins ISX Autoshift Link to comment Share on other sites More sharing options...
Bobbyb Posted September 6, 2022 Report Share Posted September 6, 2022 Why is Starlink not an option?? Quote Link to comment Share on other sites More sharing options...
Kirk W Posted September 6, 2022 Report Share Posted September 6, 2022 According to BroadbandNow this is the current availability of high speed coverage in MI. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
RV_ Posted September 6, 2022 Report Share Posted September 6, 2022 3 hours ago, Dutch_12078 said: Just curious, but why is Starlink no longer an option? The fact that you get hotspot service at all suggests that an external antenna setup would likely improve the situation. Since we started using an aimable MIMO Yagi antenna pair mounted above the roof of our motorhome, we've gotten usable signals even in some locations where our previous $600 booster/repeater system was marginal at best. Our antenna set is only about 15 feet off the ground, but if we were in a fixed location, I would probably use PVC pipe to get it up a fair amount higher. I use a cell tower locator site to determine which way to aim the antenna set. Your hotspot does need two antenna inputs and MIMO support of course. Ditto, Starlink will only get faster and provide more coverage as time goes on and they get the rest of the world covering constellation up and running. Quote RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
RV_ Posted September 7, 2022 Report Share Posted September 7, 2022 Another one shot member? Quote RV/Derekhttp://www.rvroadie.com Email on the bottom of my website page.Retired AF 1971-1998 When you see a worthy man, endeavor to emulate him. When you see an unworthy man, look inside yourself. - Confucius “Those who can make you believe absurdities, can make you commit atrocities.” ... Voltaire Link to comment Share on other sites More sharing options...
