DianaD Posted June 6, 2022 Report Share Posted June 6, 2022 (edited) Have a 2004 terry quantum. Trying to manually put slide out . Is their any way? Its electric but, wont let out.Dont know much about rv . Its used but new to me. Edited June 6, 2022 by DianaD Quote Link to comment Share on other sites More sharing options...
durangodon Posted June 6, 2022 Report Share Posted June 6, 2022 Are you plugged into shore power? Is the motor running but the slide just not moving? I had electric slides on a Carriage fifth wheel. It had a manual override that you used a socket wrench to turn, don't know if yours has that or not. If so, it'll be hidden somewhere, probably close by the motor. Quote Link to comment Share on other sites More sharing options...
Kirk W Posted June 6, 2022 Report Share Posted June 6, 2022 Welcome to the forums! If you know what manufacturer built the slide mechanism it may help someone to know that theirs works like yours. It probably does have somewhere that a crank could be used. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
TXiceman Posted June 6, 2022 Report Share Posted June 6, 2022 YEs, we need more info, unless someone happens to own the same RV as yours. If you are not plugged into short power and your batteries are up to full charge, the system will probably not work. When you bought the RV, did someone show you how the slides work? Ken Quote Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
