Zulu Posted April 30 Report Share Posted April 30 Can someone steer me to such a chart. I'm interested in stranded copper rated at 105 C. Quote Link to comment Share on other sites More sharing options...
William Anderson Posted April 30 Report Share Posted April 30 Web site with wire size vs amp chart. https://www.engineeringtoolbox.com/amps-wire-gauge-d_730.html William Quote Link to comment Share on other sites More sharing options...
sahively Posted April 30 Report Share Posted April 30 https://www.bluesea.com/resources/1437 Quote Link to comment Share on other sites More sharing options...
oldjohnt Posted April 30 Report Share Posted April 30 Thers a ton of them out there, when I practiced I just used the NEC but had plenty of other shorter basic references such as Uglys. HOWEVER what most non electricians or non engineers may not realize THE AMPACITY DEPENDS ON MANY FACTORS OTHER THEN THE WIRE SIZE ALONE. It has to do with how much current can be carried WITHOUT DEGRADING OR HARMING OR MELTING THE INSULATION IE how well heat can be dissipated from the conductors to the surroundings For example a conductor in free air has a much higher ampacity then one enclosed or jacketed and if enclosed how many conductors in what size raceway plus the type and class of Insulation etc etc etc on and on lol its worse then reading a law book. Regardless, when it comes to sizing low voltage DC conductors in high current applications such as for inverters or chargers, bigger is better to reduce line voltage drop which is a function of Current,,,,,,,Wire Size,,,,,,,,Distance Best wishes yall John T Quote Link to comment Share on other sites More sharing options...
Randyretired Posted April 30 Report Share Posted April 30 (edited) Just one more thing to consider. Many of us use welding wire which has very high temperature ratings but most terminals unless marked are not rated for high temperatures. To account for this the wire capacity needs to be derated for the terminal temperature rating. Fuses for instance do not play well with high temperatures. Blue Sea has an app that helps to size wire for fuses and other conditions. Edited April 30 by Randyretired Quote Link to comment Share on other sites More sharing options...
Ray,IN Posted May 8 Report Share Posted May 8 The number of plugs/connections in a specific wire size also affects the outcome. Somewhat like the number of elbows in a water line affects total flow. Quote Link to comment Share on other sites More sharing options...
GlennWest Posted May 8 Report Share Posted May 8 On 4/30/2022 at 3:52 PM, Randyretired said: Just one more thing to consider. Many of us use welding wire which has very high temperature ratings but most terminals unless marked are not rated for high temperatures. To account for this the wire capacity needs to be derated for the terminal temperature rating. Fuses for instance do not play well with high temperatures. Blue Sea has an app that helps to size wire for fuses and other conditions. My tig rig that i weld with uses #4 cable. I run at 250-290 amps with it for hours, gets warm but that's all. Quote Link to comment Share on other sites More sharing options...
oldjohnt Posted May 8 Report Share Posted May 8 25 minutes ago, GlennWest said: My tig rig that i weld with uses #4 cable. I run at 250-290 amps with it for hours, gets warm but that's all. As I discussed above, a single conductor IN FREE AIR has a higher ampacity versus if enclosed. Again it has to do with the ability to dissipate heat without degrading the insulation.... John T Quote Link to comment Share on other sites More sharing options...
Randyretired Posted May 8 Report Share Posted May 8 Determining wire capacity is a complicated process because so many factors need to be considered. This is one description that helps to explain some of the factors. https://iaeimagazine.org/features/wire-temperature-ratings-and-terminations Quote Link to comment Share on other sites More sharing options...
Zulu Posted May 9 Author Report Share Posted May 9 FYI - OP here. I ended up just asking the vendor. Quote Link to comment Share on other sites More sharing options...
oldjohnt Posted May 9 Report Share Posted May 9 Here's even more NEC Ampacity data: NECAmpacityWorkflow.pdf (nfpa.org) Back in the day I spent hours wading through all that stuff lol The NEC was our Bible John T Quote Link to comment Share on other sites More sharing options...
