GlennWest Posted August 27, 2021 Report Share Posted August 27, 2021 Decided to start new topic. Motor not bad. Oil leak. Filter was wet dried and ran engine. Leaking above filter. There is a line there. Hard too tell where coming from. Is that an oil line on a Detroit? There is a device there that has a rubber hose and clamp. It wet to but most everything is there. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 27, 2021 Author Report Share Posted August 27, 2021 Yelp, that oil line. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted August 27, 2021 Report Share Posted August 27, 2021 Take the suspicious filter off, check for rubber o-rings. You should only see one. Make sure to check the filter stem for a hidden o-ring. If you find two, then you've found the problem. If the filter was loose, you've already found the problem. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
GlennWest Posted August 27, 2021 Author Report Share Posted August 27, 2021 (edited) Leaking above filter. Running down the filter. It is the oil line. It ties into filter base. It dry up till the filter and wet above filter. Problem is where it ties in to motor behind the turbo. Just about impossible to get at with turbo there. Shop here can make hose. I just got to get it off. Edited August 27, 2021 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 27, 2021 Author Report Share Posted August 27, 2021 It looks like tire and wheel well removal will allow access to it. Not doable in RV park. Shop here will do it but 2 week wait. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 27, 2021 Author Report Share Posted August 27, 2021 just called them back. talked to manager this time. stated a few days. Going to see if he will replace my freon lines while doing this. Be nice to have ac again. I put a new compressor and dryer on but would not take freon. Line collapsed. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 27, 2021 Author Report Share Posted August 27, 2021 http://aandgdiesel.com/ this is the shop Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted August 28, 2021 Author Report Share Posted August 28, 2021 I think this is the turbo oil line. comes from the oil filter housing to behind turbo. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
rickeieio Posted August 28, 2021 Report Share Posted August 28, 2021 Given the issues you've experienced, it might be wise to let the shop go over the truck and see what else is ready to become a problem. A few more $$ now could easily head of many $$$$ later. Quote KW T-680, POPEMOBILE Newmar X-Aire, VATICAN Lots of old motorcycles, Moto Guzzi Griso and Spyder F3 currently in the front row Young enough to play in the dirt as a retired farmer. contact me at rickeieio1@comcast.net Link to comment Share on other sites More sharing options...
GlennWest Posted August 28, 2021 Author Report Share Posted August 28, 2021 I am. I should have replaced that line earlier. Knew it looks bad, rusted. Didn't realize it is an oll line. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Star Dreamer Posted August 28, 2021 Report Share Posted August 28, 2021 We had a line replaced in that area on our Detroit 14L when we had it inspected when we were buying it. I don't recall what t it was called. I thought it had something to do with the EGR valve. Not sure if I have a picture of it or not. Check out this link for some pictures and item descriptions. The line we had replaced was one of the braided lines. http://www.detroitmanuals.info/series-60-egr/790901.html Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
GlennWest Posted August 28, 2021 Author Report Share Posted August 28, 2021 (edited) By your diagram it is the turbo oil feed line. It seems to be a failure point. I goggled it and found hundreds of lines. Edited August 28, 2021 by GlennWest Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Star Dreamer Posted August 29, 2021 Report Share Posted August 29, 2021 (edited) This is the part they replaced, may be hard to see since it is loading sideways. The picture is clearer in my files but not uploading very clear here. Edited August 29, 2021 by Star Dreamer Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
GlennWest Posted September 9, 2021 Author Report Share Posted September 9, 2021 Just talked to them. Yes it works with the egr valve. It may have to be replaced. Bolts rusted badly. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
jenandjon Posted September 10, 2021 Report Share Posted September 10, 2021 Mine is leaking above the oil filter as well but I dont have a EGR. Quote Farmer, Trucker, Equipment operator, Mechanic Quando omni flunkus moritati-When all else fails, play dead I'm a man, but I can change, if I have to, I guess. Link to comment Share on other sites More sharing options...
GlennWest Posted September 10, 2021 Author Report Share Posted September 10, 2021 2 hours ago, jenandjon said: Mine is leaking above the oil filter as well but I dont have a EGR. Interesting. My oil line actually goes to egr. Supply and return lines. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
noteven Posted September 10, 2021 Report Share Posted September 10, 2021 1 hour ago, GlennWest said: Interesting. My oil line actually goes to egr. Supply and return lines. Paccar MX engines also use(d?) hydraulic egr valves actuated by engine oil. Heat is the enemy of electro magnetical actuators. Quote "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
GlennWest Posted September 10, 2021 Author Report Share Posted September 10, 2021 Would like to delete it but too much work. Think new turbo, ecm program. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted September 13, 2021 Author Report Share Posted September 13, 2021 Picked up my truck today. Had ac system fixed also. New condenser due to lines seized in them. Wrung off. New cabin filter. Didn't realize it had one. Totally clogged. Bolts came out of egr cooler so that a plus. Total bill was $1665.36. Parts were 542.26. Nice to have ac. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 13, 2021 Report Share Posted September 13, 2021 That's not even a bad bill, considering the work involved. Quote I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
GlennWest Posted September 13, 2021 Author Report Share Posted September 13, 2021 I was pleased with it. Was expecting a larger bill. Said egr in good shape. Quote 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Star Dreamer Posted September 16, 2021 Report Share Posted September 16, 2021 On 9/13/2021 at 7:45 PM, GlennWest said: I was pleased with it. Was expecting a larger bill. Said egr in good shape. Great to hear. Quote 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
