homelesshartshorns Posted November 10, 2020 Report Share Posted November 10, 2020 I have a 20 year old suncruser that has calcium build up in stim of vanity foist. Old plastic lines will not come loose with out breaking. Any suggestions as to how to get calcium out or how to cut old lines and replace with new fittings? Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
Chalkie Posted November 10, 2020 Report Share Posted November 10, 2020 (edited) Only way I know of to get lime out from the inside out would be white vinegar and because it is considered an industrial cleaner you can get it in gallons just like the pink RV antifreeze. So, you could pretend to winterize but use vinegar. And just like the pink stuff you will need to flush the lines thoroughly to get rid of the taste. Having said that, if the faucet is a standard vanity faucet with 4" o.c. fittings it might be time to visit Lowes or HD, or Walmart even and get a new faucet. Presuming the plastic lines are PEX or similar in a standard size (3/8" or 1/2") you can cut back the pipe and with some new bits of pipe use Sharkbite fittings, which require no special tools and can be found at Lowes or HD or just about any plumbing supply, and then replace it. I did this to ours since the original faucet was so low to the sink you could hardly get your hands under it. I replaced with a higher rise faucet I found at Lowes. Edited November 10, 2020 by Chalkie Quote Link to comment Share on other sites More sharing options...
Kirk W Posted November 10, 2020 Report Share Posted November 10, 2020 26 minutes ago, Chalkie said: Having said that, if the faucet is a standard vanity faucet with 4" o.c. fittings it might be time to visit Lowes or HD, or Walmart even and get a new faucet. Presuming the plastic lines are PEX or similar in a standard size (3/8" or 1/2") you can cut back the pipe and with some new bits of pipe use Sharkbite fittings, which require no special tools and can be found at Lowes or HD or just about any plumbing supply, and then replace it. That is pretty much what I would do as well. I found that faucet sets from Lowe's were of better quality and cost less than the ones in RV supply stores. As to the new fittings, there used to also be some compression fittings available if you don't like the Sharkbite ones but I've not shopped for either lately. If you aren't sure what your water lines are made of, it will be printed on the sides of the tubing. Quote Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Bill Joyce Posted November 10, 2020 Report Share Posted November 10, 2020 Sharkbite fittings did the job for us on our 2004 RV. My wife didn't like the faucets she found at the hardware stores, so she ordered what she wanted on Amazon. Quote 2004 40' Newmar Dutch Star DP towing an AWD 2020 Ford Escape Hybrid, Fulltimer July 2003 to October 2018, Parttimer now. Travels through much of 2013 - http://www.sacnoth.com - Bill, Diane and Evita (the cat) Link to comment Share on other sites More sharing options...
Ray,IN Posted November 10, 2020 Report Share Posted November 10, 2020 (edited) I like Chalkie's suggestion "winterize" with white vinegar. Allow to soak overnight so the vinegar reacts with the calcium deposits. It is OK to "winterize" the commode with that solution too. Once cleaned, the faucets should work normally, if not it will make replacing them easier. Edited November 10, 2020 by Ray,IN Quote 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
homelesshartshorns Posted November 12, 2020 Author Report Share Posted November 12, 2020 On 11/10/2020 at 6:52 AM, Chalkie said: Only way I know of to get lime out from the inside out would be white vinegar and because it is considered an industrial cleaner you can get it in gallons just like the pink RV antifreeze. So, you could pretend to winterize but use vinegar. And just like the pink stuff you will need to flush the lines thoroughly to get rid of the taste. Having said that, if the faucet is a standard vanity faucet with 4" o.c. fittings it might be time to visit Lowes or HD, or Walmart even and get a new faucet. Presuming the plastic lines are PEX or similar in a standard size (3/8" or 1/2") you can cut back the pipe and with some new bits of pipe use Sharkbite fittings, which require no special tools and can be found at Lowes or HD or just about any plumbing supply, and then replace it. I did this to ours since the original faucet was so low to the sink you could hardly get your hands under it. I replaced with a higher rise faucet I found at Lowes. Thanks for the tips with Shark bite and the winterizing option. Quote Still seeing Places we have never seen before and others that we thought we would never see again! . homelesshartshorns | Trying to spend the last Dollar on the Last Day! (wordpress.com) George Hartshorn | Facebook Link to comment Share on other sites More sharing options...
