iam4uk28 Posted April 8, 2019 Report Share Posted April 8, 2019 refrigerator wont cool on ac or gas Link to comment Share on other sites More sharing options...
Kirk W Posted April 8, 2019 Report Share Posted April 8, 2019 That isn't much information for us to go on. Do you have 12V power available? Your refrigerator will not operate in any mode if you don't. Is there any odor of ammonia in the refrigerator or inside of the outside access panel? Any sign of a yellow substance in the back? Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted April 8, 2019 Report Share Posted April 8, 2019 Just a guess since there is very little information to go on; if the frig has been operated outside design limits for long periods the coolant lines may be blocked, which is a permanent condition. The design limits are 3°side-to-side, 6° front-to-back, as looking at the frig door. 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
oldjohnt Posted April 8, 2019 Report Share Posted April 8, 2019 Heres a place to start, or just Google Dometic RM2862 Service Manuals http://www.nancyemmert.com/region6/Resources/NewDometicRefrigeratorManual.pdf https://www.bing.com/search?q=Dometic+RM+2862+Manual&src=IE-SearchBox&FORM=IESR3A&pc=EUPP_UE04 In the rear compartment where the 120 VAC cord plugs in, is there 120 VAC present in that receptacle?? In the same rear compartment there are two wires that should have 12 VDC present, is that so?? You need the 12 VDC to make it work in any mode and the 120 VAC outlet to be good for 120 VAC operation. Do any lights work on the top of fridge eyebrow panel??? Check fuses and circuit breakers to insure both 120 VAC as well as 12 VDC is present. John T Link to comment Share on other sites More sharing options...
