GlennWest Posted March 5, 2017 Author Report Share Posted March 5, 2017 My thoughts also but 1/4" tube steel is heavy. 5.5# per foot. Side note, Teton sure has a robust chassis. My flanges are 1/4" thick at thinnest, and gets heavier in middle like I beam. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted March 7, 2017 Report Share Posted March 7, 2017 idea, would using 120 wall DOM work? The round would be strong as the tube and less prone to vibration damage I would think. Less weight than 1/4" tube too. But I'm not an engineer, just hack fab. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GlennWest Posted March 19, 2017 Author Report Share Posted March 19, 2017 Took off this weekend to get welding and catch up on install. Had to come out far enough to get 12" wall clearance. This is what Pioneer recommend. Have deflection, would cause vibration towing. Main beam connecting chassis is 2X2X1/4. So is all the frame. My question, is there any good wood generally behind rear cap? Area at license plate, at very bottom. Need to put a strap there and lag bolt to wood, if anything there. I could start drilling small holes but hoping some has been there. t 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted March 19, 2017 Report Share Posted March 19, 2017 What about using the ladder mounts? I think you said you removed the ladder. There are bottom, mid, and top mounts already there. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GlennWest Posted March 20, 2017 Author Report Share Posted March 20, 2017 I decided against that. Can find no way to mount a interior unit in bedroom. Well actually I can but TV in that location and don't want to loose it. So only 1 unit so put it in the middle above license plate. There is what I thought to be very thing metal between rear cap and underneath area. Drill hole and tapped it with 1/4X20. Tightened it up real good and held. Surprised. Ticker than I thought it was. Will put a small piece of angle iron on each side and bolt to it. Was going to put a picture on here but it won't let me. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Jimalberta Posted March 20, 2017 Report Share Posted March 20, 2017 Glenn ...been following your thread here. Your install seems to be going along well. I feel the pain on the rear location for the condensing unit...these fifth wheels whip around pretty good at the rear and its a good thing you are mounting it solid. Unfortunately there arent many locations to choose from. Keep on keeping on...you will get there. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
budeneighe Posted March 20, 2017 Report Share Posted March 20, 2017 I have a 40 ' King of the Road 5th wheel. All aluminum superstructure on 3 7000lb Dexter Torqflex axles. I have found that at the rear of the RV there are a lot of "drop" forces created by coming off bridges and such that put a lot of vertical deflection forces on whatever is at the back of the RV. I have strapped my PC case (vertical tower case) to the back wall for travel and found that these forces are enough to rip all my Hard drives out of the quick access holders inside of the case. I have 4 HDs in the PC + an SSD. The SSD was the only one that lacked the mass necessary to cause it to pull out of its mounts. Just saying; Overbuilt mounting might be enough but don't underestimate the forces involved. My RV rides exceptionally smoothly and I have had a glass of water left sitting on the kitchen counter still there and unspilled at our destination but the cantilever action on the things at the rear of the unit are serious. I previously had a Steelcase lateral file sitting on the floor across the back and lashed to the wall but these vertical forces kept ripping the steel pendaflex hanging rods out of the folders due to the weight of the files in them. Finally, I had to junk the lateral file because the welds in the rails in it were ripped apart and the drawers would no longer open and close. Steelcase filing cabinets are like tanks. Good luck with this but keep a close eye on your mountings for early signs of distress. RVBuddys Journal Our progress into full-timing.Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogsClifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise Link to comment Share on other sites More sharing options...
GlennWest Posted March 20, 2017 Author Report Share Posted March 20, 2017 I will, but we see no such problems as you are posting. Which my Teton rear axle very close to rear. We tow with freightliner and have the et hitch also. I only have left, supporting lines, cut and flare, hook up. Connect wiring, it is run. Vac system and check for leaks. Will have to call heat/air tec to add some Freon. I can't buy it. Bummer. It came charged for up to 20' of line. I will have 40ish. Will post some pics on photo shop in a few days and supply link. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted March 20, 2017 Report Share Posted March 20, 2017 Glenn if you want to send me the pics, I'll post them for you. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GlennWest Posted March 26, 2017 Author Report Share Posted March 26, 2017 I have been bracing and scratching my head over this flexing I have with my mount. I added a simple piece of flat bar to the rear metal I referenced in an earlier post and it helped greatly. Still not satisfied. I would be solid until a hard bump now. If anyone else tries this use heavier steel. Possibly 2X4. Have been searching for a flex hose to use at unit. Can find complete flex hose but short jumper, not. .RotoFlex have a flex jumper but it is bend and form only. Not for a vibration type situation. Finding a lot of commercial flex hose but tubing size but same. Everything is done except this. I could put in service now but would have to address this problem before towing. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted March 26, 2017 Author Report Share Posted March 26, 2017 Ok, forget remark about 2X4. Doubled tube steel and still deflects. At my license plate location, it is half inch thick. Feels like wood maybe. Removed a screw and run mig wire in. Anyway it measures half inch. Considering bracing there. Lag screws, hollow door screws, etc? Plenty of area there for this. Also have option of long bit and drilling through to back side where 1/8 metal is. Your thoughts on this 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted March 27, 2017 Author Report Share Posted March 27, 2017 Well, Lag screws don't feel too good. Going to put in hollow wall screws. It was solid though. Need to do a little more welding but coax got gummed up from the flux core wire. Gas and solid wire mostly that problem goes away. I don't like the idea of carrying around a bottle though. Buy gas, carry bottle or replace coax regularly. In the long run, the 110/220 Miller stick welder might not be as expensive at 2k. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted March 28, 2017 Author Report Share Posted March 28, 2017 Got some flex hose coming. Ordered today. Finally got with company and he assured me good for our application. Retorseal NoKink. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted March 29, 2017 Author Report Share Posted March 29, 2017 http://s1083.photobucket.com/user/glenn_west1/library/Mini split install on my Teton 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 29, 2017 Report Share Posted March 29, 2017 Looks good so far. Hopefully not too much vibration on that..... Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
GlennWest Posted March 29, 2017 Author Report Share Posted March 29, 2017 My original plans were about 7-8 inches out. Pioneer manual stated 12. I almost wished I had stayed with original idea. With all the extra bracing I did, you can't see all of it from photos, it is solid unless you really, like using your weight, pull down on it. Then little and stops quickly. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Jack Mayer Posted March 29, 2017 Report Share Posted March 29, 2017 Yeah, I probably would have stuck to your original plan. It likely would have been enough.... but that is just a guess. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
GlennWest Posted March 29, 2017 Author Report Share Posted March 29, 2017 I'm going to talk to some installers. Got to get one to add gas. If they feel sure it could be closer, it would not be a lot of work for me to shorten. Advantage to be a welder 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
lockmup68 Posted March 30, 2017 Report Share Posted March 30, 2017 looking good. 2003 International Eagle 9200i, Cummins ISX, Freedomline 2007 Teton Scottsdale XT4 Link to comment Share on other sites More sharing options...
GlennWest Posted April 15, 2017 Author Report Share Posted April 15, 2017 Finished install today, at least my part. Got it very solid. Can move it barely and takes a lot of effort.Seems to cool fair but needs additional Freon.It is cooling better than the Demotic now. I do have an F3 error display though. Pioneer manual states open circuit or short at compressor discharge temperature sensor, T5. Now the communication cables color didn't match what was in manual. So I connected 1 to 1, 2 to 2, 3 to3, ground to ground. Anyone know about this before I call a repair shop 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
GlennWest Posted April 15, 2017 Author Report Share Posted April 15, 2017 Went to HighSeer web site..That is where I bought the unit. Clicked on library documents and found u2 link to F3 error. Took cover off and found sensor, plug. Unplugged and found bent pin. Straightened and it is fixed now. We have been with only 1 ac for a few months. Granted it has not gotten real hot here yet. We have seen upper 80's and it was sorta uncomfortable in here. Not real bad. Older unit has compressor fan failure and it is old and didn't want to spend money on it. Especially with my plans for this mini split.Well yesterday we saw 80ish and high humidity and were very comfortable, actually got cold in here. This was with the mini split running only. And according to Pioneer website with this error it was in default mode only. Our bedroom was sorta warm and we will experiment with fans for additional circulation. We turned on the fan only on the dometic and it helped with bedroom but it is noisy and want it to go away. I must say we are very optimistic. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
Jack Mayer Posted April 15, 2017 Report Share Posted April 15, 2017 Glenn, your experience is what I would expect. I have one of the Mitsubishi mini-splits in a rental property (now sold) and it was amazing what it could do. You might want to put another unit in the bedroom. That is my plan - one in the bed, one in the living. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted April 15, 2017 Report Share Posted April 15, 2017 Glen and Jack, Would it be possible to mount the unit in a basement if the basement was designed for it? If it had air flow from the bottom and at least 1 side would it be sufficient for cooling or? Jim's Adventures Old Spacecraft.... Who knows whats next Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted April 16, 2017 Report Share Posted April 16, 2017 I don't believe any manufacturer would approve a basement installation. They are adamant about getting the proper air floe through the condenser. I am not sure how you could 'design' a basement compartment for the correct air flow. Link to comment Share on other sites More sharing options...
GlennWest Posted April 16, 2017 Author Report Share Posted April 16, 2017 The outside unit, compressor, needs to pull air and discharge air. The fan doesn't turn very fast though. Mine isn't pulling a lot of air. Really believe I could have put mine closer to the back of unit. If where you put it, if it has good air supply to back of unit and open discharge to air, it should work fine. I highly recommend one. It is cold in here now. Our bedroom is comfortable but not cool.This is just 1 12k unit running on a 15 amp breaker. 2003 Teton Grand Freedom towed with 2006 Freightliner Century 120 across the beautiful USA welding pipe.https://photos.app.goo.gl/O32ZjgzSzgK7LAyt1 Link to comment Share on other sites More sharing options...
